New firmware for Phantom 4 Pro/Pro+ --- 04/12/2017
38795 206 2016-12-9
bsett
Due to lousy weather I have had my 3 P4 pro batteries on the charging dock in storage mode and they are now holding at the 50% mark. Do I need to bring all 3 batteries back up to 100% before doing this update? Guess what I'm asking is the firmware updated on the Drone itself or on the batteries as well?
2017-1-13
P4P+
Airwolf13 Posted at 2017-1-13 14:03
Not the reason. They have so many issues with DJI, that they had to start a special division to handle the issues.  I asked them ..they just don't drop carrying their products...their answer..'they're thinking about it"  Too many returns for 'chinese quality control" problems!
Wow, I didn't know that. They should not that along with the description. There is one P4P listed on their site and it has a note in red that it is not returnable. No other Phantom has a note like that.
2017-1-13
HuibN
How to update the 4 Pro remote controller? The controller has no Micro SD card slot
I downloaded and extracted the file GL300E_RC_xxx.bin
2017-1-14
plexus
Flight distance : 79833 ft
The SDcard is only on the P4P+ and the firm you have downloaded is for the P+. That is not for P4Pro. The RC is not the same.
2017-1-14
PhantomPhil
Flight distance : 44731 ft
bsett Posted at 2017-1-13 14:07
The update is for the drone and the batteries. You will need to charge batteries to more than 50% otherwise firmware will fail - 75% charge would be adequate. After the initial update using DJI Assistant 2 it will update the drone and the battery that is in the drone - take about 15 minutes. Then quit DJI Assistant, Turn off drone and swop out battery battery, reconnect to DJI Assistant 2 and this will then just update that battery - take about 3 minutes per battery. Repeat for next battery.
2017-1-14
quadslo
Slovenia
Did previous version had live video freezing and glitching with built in LCD? I received new one yesterday and only tested it with the latest FW.
2017-1-14
vidwiz
Fixed here too.
2017-1-14
vidwiz
Sorry for duplicate post elsewhere but after update, some stills do not get written to sd card.  It's random.  One of my 5 exposure bracketed pics made the shutter sound but the icon did not 'circle' and the files were not written.
2017-1-14
vidwiz
PhantomPhil Posted at 2017-1-14 08:24
That's brilliant man.  I needed those instructions.  Not sure how I was supposed to know to update batteries separately.  When using the drone with the updated controller and old battery firmware, it did not notify me.  Thanks.
2017-1-14
BashP4P+
P4P works with P4P+. My understanding is all the P4 range of batteries will work with the P4 range of Air craft. The higher the capacity the higher the time to fly.
2017-1-15
BashP4P+
Please ignore the above message.. My iphone playing up. It was a reply to a question 4 days and somehow its posted now.
2017-1-15
bsett
Thanks for the info. I'll probably just hold off a bit until the weather here makes a change for the better. Then I'll bring the batteries back up to a 100%, do the updates on all batteries and get some flight time in .
Thanks again for replying.
2017-1-15
ACA87
Just got the Phantom 4 Pro+ and was able to create a DJI account and login on the built in screen. When trying to activate the drone I get the Activation Failed (ServerBackFail) contact DJI support if error persists after restarting. Have restarted several times, reset the controller multiple times, tried using a different email and the same message keeps popping up. Any ideas of what I can do to fix this?
2017-1-15
fanscd099a2f
Flight distance : 2148865 ft
my phantom 4 pro never lands near its take off point , 10 to 20 feet away everytime .
2017-1-15
fans833db9c9
Flight distance : 1099472 ft
Update bricked my remote control. after trying the update with the app and failed I used the DJI assistant 2 software. Updated P4P successful. Tried to connect remote to Assistant software and remote does not respond to software. Also remote has purple light on left of leds. Not red/green/blue.
2017-1-15
Punchbuggy
Flight distance : 573054 ft
fans833db9c9 Posted at 2017-1-15 13:59
I have seen this LED sequence myself, but not while connecting to Assistant 2. Cleared by clearing the RC using the C1-C2-shutter button sequence, then power cycling the RC.
2017-1-15
XoR
Flight distance : 94738 ft
Romania
gvgeorge Posted at 2017-1-12 10:21
Thank you.
With the DJI download page still stuck on Phantom 4 Pro+ Remote Controller Firmware v01.01.01.01 where did you find the update?
You need to upgrade using Assistant 2 ver. 1.0.9 if you're upgrading using your PC (which I recommend)  or through DJI Go App.
2017-1-16
XoR
Romania
fanscd099a2f Posted at 2017-1-15 12:57
When you take off, wait 10-15 seconds until you hear the message Home point updated. After that it should be fine.
My P4P+ misses the home point by no more than 20-30 cm.
2017-1-16
kingstonphoto
Flight distance : 160197 ft
Im still experiencing the lose of settings each time I power up
2017-1-16
rlarsen462
kingstonphoto Posted at 2017-1-16 09:02
I may also be having this issue, will need to confirm.
2017-1-16
fans833db9c9
Punchbuggy Posted at 2017-1-15 16:38
Tried you suggestions no help.
2017-1-16
bsett
Got a break in the weather and was able to get in 2 batteries worth of flight time using the new updated firmware and everything seemed to work well for me on my P4 pro using iPad air 2. One thing I noticed was that I was no longer getting that high wind warning I was getting before. Not sure if that was something fixed with the firmware update or if it was just my lucky day .
I the weather continues to give me a break I'll go out and do some more testing tomorrow.
2017-1-16
Murat82
Flight distance : 605873 ft
Finland
Motor startup feels different this time, now its starts/revs more like Inspire 2 motor startup
2017-1-16
Punchbuggy
Murat82 Posted at 2017-1-16 11:42
Yeah, and with props off (so no wind noise) I notice a single 'clack' made by the motors after a split -second of spin-up. Does it every time. I don't recall hearing that before.
2017-1-16
Grizz 1
Flight distance : 120066 ft
same here punch, I heard mine do it, after flight I brought it inside and removed the props and I heard it again, its internal cause I couldn't see anything else move but the motors
2017-1-16
rickthephotog
fans69a1db85 Posted at 2016-12-10 06:11
Please excuse what might be a stupid question but what exactly is the HDMI module used for?  I just sold my P3Pro and am awaiting my new P4Pro+
Thank you for the help.
Goggles! Or remote to a monitor.
2017-1-16
Steelinox
Flight distance : 168891 ft
Did the firmware update and now I have this little "red" gem appearing on my flight pack!
Any ideas?
Thanks,
Randy
2017-1-16
Steelinox
Steelinox Posted at 2017-1-16 22:52
Any ideas?
I kinda suspect the battery needs to be updated again...
2017-1-16
Steelinox
Steelinox Posted at 2017-1-16 23:01
On further investigation, DJI is getting the battery for repair/replacement.
2017-1-17
mooncusser
Flight distance : 3384501 ft
My aircraft will not acknowledge as connected in the DJI Assistant software or in the DJI Go 4 App.  It does however acknowledge as connected on the attached LCD screen with the update firmware message saying to download at the DJI website.  How do I get the aircraft to download this firmware update given these conditions?
2017-1-17
RichardHurst
Banned
Flight distance : 2342808 ft
2017-1-17
fans50c32a8d
Try rename it .mp4
2017-1-17
dan_joyce
Flight distance : 188983 ft
RichardHurst Posted at 2017-1-17 13:34
Since doing the update my Premiere Pro CC does not recognise the H265 .Mov files anymore???
H.264 continues to be the standard. Any reason (besides the additional compression) to not just stick with H.264? I know Premier Pro CC at least supports it.
2017-1-17
Punchbuggy
vidwiz Posted at 2017-1-14 19:29
'Not sure how I was supposed to know to update batteries separately'
A reasonable statement, as the Release doco typically doesn't mention it. Knowing that it's a possibility though, what I know do now is have the LEDs facing me during each upgrade. Should the battery LEDs go from all on (if fully charged) to the two middle ones flickering (signalling the battery firmware is updating), then I know to power down after completion and do it over again with each other battery.
2017-1-17
Steelinox
I "downgraded" the firmware to the last version and the battery passes !
2017-1-18
Steelinox
Steelinox Posted at 2017-1-18 05:23
DJI says that this is a known issue and that it is in R&D now for a fix that will come out in a forthcoming Firmware Release. Stay tuned as another Firmware vn is coming.
Thanks,
Randy
2017-1-18
Visalia Califor
Snowwolfwarrior Posted at 2016-12-10 04:08
I am surprised DJI ask people to send their drones back when they know full well it will be fixed with the firmware Update, I find it very odd they do that.
Around 1990 Companies realized they could save money and use the general public as their product testers. Never forget we are all just paying product testers. {:4_181:}
2017-1-18
tom.grizzlycree
I did the most recent firmware update for the P4P+ and controller with the built in display. Every time I try to launch DJI Go 4 it says, "Unfortunately, DJI Go 4 has stopped.". I've tried factory resets and downgrading to earlier firmware releases but I still get the same message when I tap "Go Fly".
Anyone else having this issue?
2017-1-18
P4P+
Airwolf13 Posted at 2017-1-13 07:34
They now refer issues to their distributors GRADUS BH will no longer accept returns on ANY DJI peouucts. Period
B&H does refund DJI drones. This is what they said:
Graham N: We do refund for DJI drones we just try to trouble shoot the issue first.
Graham N: If the unit is defective or the customer changes their mind within 30 days we do return and refund the unit.
Graham N: But if it flies away then you have to contact DJI support and they will issue a voucher if they determine the flight was not the pilot error.
Me: If the person opened the box, the return policy still applies, right?
Graham N: Yes you can still open the box and as long as everything is in the box you can still return it.
Graham N: There was some issue with the older units since they are discontinued but our policy for our standard 30 day return policy will cover DJI drones.
Graham N: If you would like to, I would also like to say that if any one has any questions they can always e-mail AERIALIMAGING@BHPHOTOVIDEO.COM.
2017-1-18
floridajustin
Steelinox Posted at 2017-1-17 06:42
Same exact issue. Rolling back firmware seemed to fix the issue.
2017-1-18
