PICTURE OF UNZIPPED NEW FIRMWARE FILE ON SD CARD
4042 25 2015-3-1
rfrye
Flight distance : 309606 ft
Below is a picture of my unzipped new v1.2.017 firmware file as it shows on my aircraft SD card.
I'm using a Lexar 633x 16GB SD card (same which came with the aircraft)
Can some one tell me if this is as it should be???
Is it necessary to delete the PDF instruction file before installing it in my aircraft?
(can't figure out how to get it's picture on this new thread, so will insert picture directly below this post)
2015-3-1
rfrye
Here's the picture:
2015-3-1
UM305
Inspire 1 , just  need the bin  file (firmware)
2015-3-1
dundee
Flight distance : 33550 ft
rfrye Posted at 2015-3-1 20:42
Here's the picture:
Looks ok.
Have a look here, maybe this can ease the pain.
http://forum.dji.com/forum.php?m ... age%3D1&lang=en
2015-3-1
Clem2099
Just for laymen what is the root menu on the SD Card?
2015-3-1
Captain Obvious
Clem2099 Posted at 2015-3-1 22:17
There are many ways to get too Your* Inspire's memory card's root directory...
But if your using say a Windows based PC then you'd
  • Open "Computer" icon on desktop.....
  • Locate your Inspire's card and (if needed) FORMAT it.... Usualy called "Removable Disc" with a drive letter....
  • RIGHT CLICK on the ICON of the card and choose from the list... "FORMAT" >> FAT32...
  • Locate the "Unzipped" Update file "WM610_FW_V01.02.00.17.Bin" file..Move or Copy or Cut & Paste it too your inspires card
  • Upon opening your card You should see just the update file you placed there after formating it (If you formated it) this is also the ROOT Directory.
If not formated then it will have other folders in the root Directory "MISC and DCIM" that should be deleted. But will be replaced
by your Inspire 1 afterwards automaticaly.
Un formated card
Un formated card
Computer Icon
Computer Icon
Format FAT32
Format FAT32
Card Icon
Card Icon
2015-3-1
Clem2099
Captain Obvious Posted at 2015-3-2 01:57
But if your using s ...
Thank you. Nicely done.  :-)
2015-3-1
Captain Obvious
You may also want to delete the update file of the card After* doing the update if wanted
2015-3-1
pandppurchase
Captain Obvious Posted at 2015-3-2 02:08
Best to keep the update file until you have run all your batteries through the machine update process as the firmware is used to update each individual intelligent battery.
2015-3-1
pavel.present.s
Flight distance : 10641243 ft
Czechia
Small question. Why your unziped bin file is size 83.780 KB? My unziped bin file is size 85.789 KB.
Is different between files. I am downloading from DJI downloading site.
2015-3-2
rfrye
pavel.present.s Posted at 2015-3-3 01:48
Small question. Why your unziped bin file is size 83.780 KB? My unziped bin file is size 85.789 KB ...
pavel,
My first download was corrupted or something. It would not install, so I started over from the top with a new download ...and the second download of the new firmware installed just fine. You tell me what happened.....
2015-3-2
rfrye
I just checked my bin file size on my second download which worked. It was the same size as my first one i.e. 83780
2015-3-2
pavel.present.s
Czechia
rfrye Posted at 2015-3-3 01:56
I just checked my bin file size on my second download which worked. It was the same size as my fir ...
I cannot install update to Inspire. Install update to radio controler is ok. Bird upon power installed update, but then heard after about 10 minutes long tone, and the installation is over. Text file system reports fail. According to the instructions mam again try to install, but it is already doing so after the thirtieth. The same problem has user PANOX.
I thought that I must be a bad firmware file. It would send your bin file to me?
pavel.present@seznam.cz
2015-3-2
murph10375
Same. Getting fed up with this. It's taking the shine off. Thinking of Refund and waiting until it all gets sorted. I'm not prepared to wait 4 weeks to send it in for repair. They need to send me proper firmware so I can install or it's going back.
2015-3-2
Captain Obvious
I was flying mine around...Harder than I would normally do to. No probs.
And even after a "Failed" update...
2015-3-2
dundee
pandppurchase@g Posted at 2015-3-2 05:36
Best to keep the update file until you have run all your batteries through the machine update proc ...
Are you sure about that ?
2015-3-5
pandppurchase
dundee Posted at 2015-3-6 10:24
Hi Dundee
That's my understanding, apparently each intelligent battery is subject to a firmware update and will run through a quick update process if it hasn't been subjected to it before. However I checked on the 'About' update screen and firmware on both the different styles of batteries hadn't changed. I've adopted the policy which I think you posted which was to keep the original 16gb card and just use it for that sole purpose and run each battery through it.
2015-3-6
dundee
pandppurchase@g Posted at 2015-3-6 16:54
Hi Dundee
That's my understanding, apparently each intelligent battery is subject to a firmware up ...
Firmware comes in 1 package. (1 binfile)
Not sure (yet), but i believe battery is updated using the firmware already installed in the bird.
So with the sd, you update the bird.
Then the bird will update every battery as you put them in later.
Also realise that as new firmware is available, does not mean batterie firmware has changed.
2015-3-6
gwhiz2k
I don't have an option for FAT32, only exFAT. Is this going to be an issue with the firmware update?
2015-3-6
T J Gilbert
Flight distance : 74659 ft
dundee Posted at 2015-3-6 17:46
Not sure (yet), but i believe battery is updated using t ...
Here is what the latest instructions say at the DJI website...
2015-3-6
T J Gilbert
gwhiz2k Posted at 2015-3-7 01:07
I don't have an option for FAT32, only exFAT. Is this going to be an issue with the firmware updat ...
Not what I know, but what I just read...
Windows cannot format a card higher that 32G as FAT32.
If your card is larger, Windows defaults to exFAT.
2015-3-6
gwhiz2k
T J Gilbert Posted at 2015-3-7 01:34
If ...
Ah, ok.. Makes sense. I'll just use the one that came with the Inspire then.
2015-3-6
T J Gilbert
gwhiz2k Posted at 2015-3-7 01:45
I would think either FAT32 or exFAT will work for the upgrade.
2015-3-6
T J Gilbert
exFAT or FAT32 will both work for the upgrade...
And if your cards are larger than 32G, you'll have to use exFAT.
2015-3-6
dundee
If ...
correct, i read that before.
i keep a watch on that. thanks Gilbert
2015-3-6
dundee
If ...
yeach, firmware never that big
2015-3-6
