Which lenses to buy?
1961 23 2017-1-27
Dr Jon
Flight distance : 463012 ft
The X5S is shipped with a reasonable 15mm lens which i find is a reasonable "standard" lens for everyday videos etc...
Now the qustions is what other should i add to extend the range ?
I like the Panasonic 14-42 / 3.5-56 HD on the specification and has good reviews on a terestial based camera. Any comments on its abilities on the drone?
Second question ..
If i have both of the above in my case what other lens are worth adding and why?
Most of my videos / photos are simple aerial landscapes / sites of interest.
Any opions on the LAOWA 7.5mm f2 MFT i saw a good review when used on an I2?
2017-1-27
aviscomi
Subscribed...I'm also looking for lens options along with what's needed for balancing.  Seems like every thread I read whether here or on another forum I can't seem to get a consistent answer.
2017-1-27
Dr Jon
i agree... i'm so confused and lens are not a cheap item , i see many have boxes of different lens but i don't want many a good prime and something else...
2017-1-27
DJI-Jamie
Flight distance : 112405 ft
Dr Jon Posted at 2017-1-27 04:56
I mentioned on another thread of yours that DJI Ranen made a lens comparison thread when the X5 first came out for the Inspire 1. If you're new to these DSLR lenses, this may give you a decent start:
http://forum.dji.com/thread-55912-1-1.html
2017-1-27
Dr Jon
China
DJI-Jamie Posted at 2017-1-27 16:35
Thank you Jamie a very informative Thread.
2017-1-27
Cougar1
Flight distance : 924393 ft
I use 15, 25 & 45mm Olympus lenses, might look to ad a wider lens next.
Used to have the 14-42 Olympus but did not really like it, great to have zoom but fixed lenses is better for my use.
2017-1-27
DJI-Jamie
Dr Jon Posted at 2017-1-27 17:26
You're welcome, best of luck to you.
2017-1-29
Gybo102
Flight distance : 2426230 ft
I have the Oly 12mm/ 25mm/ and 45mm... between those 3, you have everything covered. I will agree the 12mm is a bit expensive, but its a nice piece of glass.
2017-1-29
Gybo102
DJI-Jamie Posted at 2017-1-29 15:25
Jamie, can you give me some information on something? Why is the EZ version of lenses "not supported" on the X5s? If I was to get one, get it properly balanced, would it work? or is the electronic control removed from the X5s?
Thanks in advance!
-Andre
2017-1-29
Farnk666
Flight distance : 1711394 ft
OP, it's not a matter of "which lens should you buy?" the question is "which lenses do you need?"
You're not giving us any indication of the type of work you're looking to do and in what circumstances it will happen.
Just as with a terrestrial camera, lens choice on your UAV is entirely driven by the desired outcome, i.e. what your customer will pay for.
2017-1-30
Aeromirage
Flight distance : 1778045 ft
Gybo102 Posted at 2017-1-29 18:00
I recently got an Olympus 17 mm and love it. Basically $200 less than the 12mm and not much narrower. I also have the 12mm which I am considering selling as I think the 17 shows better detail and opens a bit wider also. F1.8 vs F2.0.
2017-1-30
DJI-Jamie
Gybo102 Posted at 2017-1-29 18:01
Thanks in advance!
-Andre
Could you happen to specify which lens you are referring to?
2017-1-30
Gybo102
DJI-Jamie Posted at 2017-1-30 20:29
like the Olympus electric zoom lens that was supported by the x5 and the x5r:
https://www.amazon.com/Olympus-1 ... rds=olympus+ez+lens
is there a particular reason we cant use them on the X5s?
2017-1-30
Gybo102
Aeromirage Posted at 2017-1-30 19:28
hmm... interesting... I like the way you think I may have to take a look at that one as well
2017-1-30
DJI-Jamie
Gybo102 Posted at 2017-1-30 20:33
https://www.amazon.com/Olympus-14-42mm-f3-5-5-6-Interchangeable-Panasonic/dp/B00HWMOZEG/ref=sr_1_3?ie=UTF8&qid=1485837165&sr=8-3&keywords=olympus+ez+lens
That lens is supported, but not recommended. I believe it's mostly due to how finicky that it could be to balance, but some have used this particular lens before.
2017-1-30
I 2 Fly
Flight distance : 8176 ft
On this topic - I'd like to have a wider (than 15mm X2 Crop = 30mm) lens.  Any suggestions?
In the X5S box is a rubber band / strip...  What / how is this used?
2017-1-31
Gybo102
I 2 Fly Posted at 2017-1-31 03:17
So there are 2 options (availbe right now, with 2 others coming down the road) the oly 12mm (24mm after crop) and the oly 9-18mm (18mm at the wide end, but only f/4)
that is the dust "blocker" it goes around the 15mm lens (where the aperture ring is) to keep it nice and clean. Guessing its not dust proof? I dont think any of the DJI approved lenses are dust proof, so its a nice thing to have.
2017-1-31
I 2 Fly
Gybo102 Posted at 2017-1-31 04:28
So there are 2 options (availbe right now, with 2 others coming down the road... the oly 12mm (24mm after crop) and the oly 9-18mm (18mm at the wide end, but only f/4)
OK - that clears the rubber up.  There is talk of "balancing rings"  What are these?  To do what?
2017-1-31
thomasakira
Flight distance : 921693 ft
How is distortion on the 12mm?
2017-1-31
Gybo102
thomasakira Posted at 2017-1-31 06:20
None... (that I notice)
2017-1-31
Gybo102
I 2 Fly Posted at 2017-1-31 04:36
Every lens you mount to the X5s (or any camera/ gimbal) needs to be balanced. you want to balance everything for 2 reasons, accurate control, and longevity of the gimbal motors.  most of the time, mounting a ND filter is good (but they all do range in weights tho). For photos, I use step up rings. they are very light and the more you add, it acts as a sun shade
2017-1-31
I 2 Fly
Gybo102 Posted at 2017-1-31 08:01
Thanks!  How do I balance the X5S?  On my Sony I use small weights on the gimbal mounting plate till I get the correct balance...  but how on the X5S?
2017-1-31
Gybo102
I 2 Fly Posted at 2017-1-31 08:33
here is a vid, looks like it should have some good info ( cant hear it, at work)
either you buy the balance rings DJI sells for each approved lens, or go the route I went with and get step up rings. i just keep adding more rings till its balanced.
2017-1-31
I 2 Fly
Gybo102 Posted at 2017-1-31 10:00
https://youtu.be/zoOZu08F4qI
Much appreciated!!
2017-1-31
