Battery Over charge current?
5047 19 2017-2-2
fans825c0532
Flight distance : 341355 ft
Saw this video, and it seems this person on youtube experienced something called battery over charge current with his mavic, he had a first flight, but then, the second battery somehow did this and it went descending into the water.
Anyone with similar case? what might have caused this? Preventions?
2017-2-2
fans825c0532
2017-2-2
BarrettF77
Flight distance : 565459 ft
DJI quality FTW
Sorry for your loss.  Always sucks
2017-2-2
Vixus
Had the same problem when I was flying in cold weather and I didn't preheat the battery. Exactly the same thing happened. It started decending and I couldn't even steer it. Check the logs. My battery life dropped super fast (from 100% to 30% in 3-5 minutes). Luckily the drone landed in the neighbor's backyard and managed to recover it. Make sure that you preheat everything before flying in cold weather.
2017-2-2
AlanOne
Flight distance : 2163468 ft
Had the battery over charge current error today, too. But I was able to continue flying. Quickly returned home and changed the battery.  This was in cold weather @ 3°C or  37°F and high winds. Never had that error message coming up before and I flew at colder temperatures. DJI any idea?
2017-2-2
D_jan_i
Flight distance : 562802 ft
I had the same issue several times but I never had a severe situation  - got it today at 50% and I was still flying till 24% without any fast battery level dropping - was cold and very windy
2017-2-2
fans759a36b6
Flight distance : 242133 ft
Feel really sorry you, i am worried same thing happens to me to, as i think the software DJI GO4  still have many bugs that have not been flatted out yet!
2017-2-2
AlanOne Posted at 2017-2-2 15:21
Were you flying aggressively like full throttle when this occurred?
Did you fly in Sport mode or P mode?
2017-2-2
fans06b77ccc
Flight distance : 1905381 ft
This error message appears to be caused by a combination of flying in very cold weather and aggressive flying.. In same cases it was questioned if prop icing was also a problem. If you look at the dat files, typically GPS (slower)  flight total current is around 8 amps. Flying aggressively in sport mode,, may hit a bit over 20 amps. Sport mode with a cold battery when flying very aggressivly could exceed close to 30 amps giving this message.
2017-2-6
fans825c0532
fans06b77ccc Posted at 2017-2-6 05:59
interesting.
2017-2-6
shirty
I had the same error over the weekend, different end of the temp spectrum. I was flying in hot weather, mid 30's c (about 95'ish F) I think I was flying in sports mode at the time, nothing seemed to change in terms of the Mavic flying. From now reading this, maybe it was just saying it was too hot, and I was pushing it too hard?? Very thankful (and lucky) it didn't result in a crash
2017-2-6
fans06b77ccc
shirty Posted at 2017-2-6 17:49
Ahhh....I envy you with th warm weather!  Your error may have been the result of a combination of fast flying and turning or climbing at the same time. If you twke a look at you dat file, current in the high 20amp range seem to trigger this error. Not sure exactly what the threshold is.
2017-2-6
Bent Kangaroo
Flight distance : 362510 ft
I think icing would give the result in the video.
As AC losing alt with less efficient props,, the system feeds more juice to try to correct.
Iced props also need more power to rotate as they are less aerodynamic.
2017-2-7
fans90d4f438
Flight distance : 451335 ft
Flying outside of DJI's documented temp ranges are a big factor in this occurring
2017-2-7
Angelo26
Flight distance : 799718 ft
Austria
GUIDELINES ON HOW TO FLY IN COLD WEATHER:
(I flew my Mavic without ANY problems in P and Sport-mode at  -10°C for 25 minutes several times, a Canadian -search on Youtube - at -20°C)
1. Keep the batteries as close as possible to Your body under the warm coat when You leave home
2. Fire up RC and smartphone so that they are ready for connection to Mavic. You have bad luck if You own an iPhone: it will be empty and batt quits after some minutes outside, so You can only fly by RC
3. Take out the Mavic-battery from Your coat, insert it into Mavic and switch Mavic on immediately.
4. Make Your preflight checks (system status OK), wait for GPS-lock ("hompoint recorded") and then T/O immediately.
Battery will keep temp at about 20-25°C by using it to fly, Your iPhone will stop working and You will freeze Your hands to numbness .........
HAVE FUN !
2017-2-7
Bent Kangaroo
Angelo26 Posted at 2017-2-7 05:02
Icing of blades is not helped by a warn battery.
What was the humidity when you flew at -10C?
Did you fly over water like the video above in such temps?
2017-2-7
Angelo26
Austria
Bent Kangaroo Posted at 2017-2-7 06:51
I had rotor icing in flying at around 0°C in dense fog and got a warning message regarding battery overload.
See: rotor icing
No icing at -10 °C on a frozen lake .......... too dry air as it uses to be at -10°C
2017-2-7
M.C. Pilot
Flight distance : 10278435 ft
Had the same message while flying the other day in sport-mode. Weird b/c it wasn't cold but it was a bit windy. Lost a lot of power on the stick ...working with 2-5% power in sport-mode..really weird. I kept flying and controlling the AC while still going slowly. Flew it closer to home base, then it began to regain power to normal levels. Warning message box never came back up again. Been reading that it might have been caused by flying to aggressive in high winds? anyways wanted to share my experience.
2017-10-16
M.C. Pilot
Wow just viewed the video and with that guy, his Mavic began to descend? what a nightmare. Mine thank goodness did not descend but only had some loss of power to move horizontally. Anyone else had this issue as well?
2017-10-16
DJ Enertia
Flight distance : 614065 ft
Angelo26 Posted at 2017-2-7 07:02
See: rotor icing
Makes sense as the blades ice up they get heavier and stiffer and the motor needs more voltage to spin faster for more lift hence the over voltage warnings.Sorry to hear bout your Mavic loss
2017-10-16
