Phantom 3 Standard firmware v1.8.10 is now available to download!
Gulfstream
Flight distance : 100659 ft
HLew Posted at 2017-2-15 23:00
I emailed them once and never got a reply back...I guess thats the "DJI way". Anyways Im not sure for how long I will keep using their products.
Yup... the American alternative is picking up steam. Once they get an awesome camera (the current isn't to bad) I'm in like flynt!
I'm in a business in which Service is far more important than Sales, and I have to perform or I'm replaced. Guess what?
2017-2-16
MADempC
Hoping for help from the team...  I cannot get this loaded to the aircraft to save my life.  The download works fine to the app, but while loading to the aircraft, the process stops at 40% and ultimately fails.  I have restarted the aircraft, the app, everything many times.  I even un-installed the app and reinstalled so that it would force a new download.  I contacted DJI support they said keep trying.  I have about 10 times.  The log file indicates that the file is corrupted.  Help anyone?
2017-2-16
Caribou
blackcrusader Posted at 2017-2-9 16:42
It appeared on my smart phone. Perhaps as I was already using version 581. My phone is now 582 version.
Where could I see the version  581 or 582 on the phone ?
2017-2-16
blackcrusader
Flight distance : 689774 ft
Taiwan
Caribou Posted at 2017-2-16 15:14
OK now you have 3.1.3 you can see it in Advanced settings but need to scroll to bottom of screen.
2017-2-17
Gulfstream
MADempC Posted at 2017-2-16 11:38
Same issue see my post above. Mine locked at 4% upload to the aircraft. DJI tech worked with me for almost an hour, just kept getting worse, and finally he said send it in. Good Luck to you - they are charging me $120 to "fix" an issue that occurred uploading "their" firmware. When I complained that I'm still under warranty, they said "sorry the gimbal is out of warranty" so you have to pay.
2017-2-17
CHUI_ERSH
Da Lata Posted at 2016-11-9 11:20
I did the update, check the txt file on SD Card (OK), I test flying the drone and like other user the version on app show 1.6.8+. Before was only 1.6.8 without +
1111dsdadaddadsadasdsaddsdasdasd
2017-2-17
Impulse
I made sure to format the SD card before I did the update. After this just used DJI Go to update and it worked fine first time.
2017-2-17
blackcrusader
Taiwan
I have three batteries. I thought I had upgraded all three but it seems one was on the 1.2.40+ firmware and asked for the drone to do an update.
I did that and now all my batteries are 1.8.10 app 3.1.3 and all working fine.
2017-2-18
fansc1a15f02
The drone is not connecting to the app.i have tried it on another device but still the same.
2017-2-18
Richmondjoe
I downloaded the software, installed it and now the P3P will not fly.  It comes on, my app says everything is connected but I get a message that my "RC Signal is Lost" and it will not fly.  Please help.  Thanks,
2017-2-19
Joeydints
Flight distance : 6929 ft
rr@jensen.mail. Posted at 2016-11-9 02:13
cant see any banner about new firmware in the dji go app??
had that happen to me too, but i restatrted the app and fixed it
2017-2-19
Microcyb
Flight distance : 1095955 ft
OK so I had no issues with both the firmware and updates.  Here are the steps I performed.
Using an iOS iphone 6 plus
Updated the phone to latest version.
Updated DJI Go to latest version.
Charged up the batteries on the controller and bird to 100%
Closed any and all apps on phone.
Did a "forget" to any local Internet WiFi connections (cell download of firmware) ****Optional***
Turned on controller and connected to WiFi DJI Controller
Started the DJI Go App and did not touch anything within the apps screens.
Turned on the Bird and waited.
New update notification showed up.
Did the update.
Closed DJI Go app
Turned off controller and bird.
Turned on the controller and the bird
Started up the DJI Go App
*** New Firmware notification message ****
Updated firmware and now good to go.
So in short the steps given are not quite correct as I have found out in order to update with the latest firmware.  you kinda have to mess around turning things on and off and then on in a certain order to get things going.
2017-2-21
Milty
gmsol Posted at 2017-2-6 01:14
WARNING!!!!! DONT UPGRADE YOUR FIRMWARE !!!! WARNING!!!!.
This update supposedly provides .... but does not really constitute and update does it.
My P3 advanced was working absolutely Fine until I did the latest firmware upgrade.  First 2 flights it spun out of control and starting beaping very loudly.  Next flight it crashed straight into the ocean 20 feet off the beach.  I was trying to ascend and it it just flew straight down.  Trying to post a new thread about the details, but I'm not allowed to yet.  I'm very poised about this and am convinced it is the firmware upgrade v1.10.90 .
2017-2-22
Milty
Dioden Posted at 2017-2-7 09:26
Well, I think it’s time for me to say something too, I have two PH3P, and the youngest one has flown twice, only.
Both of them was working fine, until this last upgrade of the firmware. I have only been using the old one because the newer one is a spare if the **** hit’s the ***, as you might say.
I did an upgrade on the one I’m always using, the first one I bought, after this upgrade I can’t barely use it. Loss of videofeed and a lot of pixels on the screen, however, the controller seems to work as it should.
Its Definatley the new firmware  v1.10.90.  Same happened to me and crashed into the ocean.  no issues before firmware upgrade.
2017-2-22
Milty
Gulfstream Posted at 2017-2-9 09:47
This update bricked my P3S .   It's on it's way back to the Mothership today.
2017-2-22
Milty
120ccpm Posted at 2017-2-9 14:12
Upgraded to 1.8.10 from 1.7.9 the other day using DJI GO app 3.1.4 on iOS, followed instructions to the letter, it failed at 40% exactly like someone else reported above. On second attempt it started beeping like crazy, but it was able to complete the process. Did a full IMU and compass calibration before sending it up in the air, everything seemed to be ok although it was just a short flight at close distance.
2017-2-22
Lexst
I cannot seem to get the firmware installed in my P3 pro. Neither the bird or controller. I was a preorder when these came out and did the first update only when I put up my machine. Now I cannot get any of the updates to the controller and only managed to get the 1.3 something to work on the drone. All others failed 10+ times. Downloaded the DJI go and was able to update that via Ipad app store but no new ground station, and no other updates.
2017-2-23
Spappy
Flight distance : 28107 ft
Well, let me tell you MY story: I ordered the ARGtek range extender kit last week and it showed up Saturday.  I installed it 1st thing Sunday and took it for a test flight.  The range was WORSE than stock!  I contacted the seller (ebay) and told them the problem.  They responded the next day and informed me that they have a skype page for technical support, so I thought I'd give it a shot.  Long story short, I re-did all the connections (skyping pictures back and forth the whole time) only to find out the connections were fine in the 1st place.  THEN, the tech suggest that it's a FIRMWARE issue and not a hardware issue, as 1.8 just came out and people have been having problems with the new update.  Sorry, but it's my bedtime by now, I'll have to tackle this tomorrow.  The next day, after watching several videos on several ways to downgrade the firmware, I give it a go... with no success, so I'm back on skype with tech support.  He walks me thru the process that HE used.  It did downgrade, but when I launched the app, I was greeted with several warnings and failure alerts (funny, it worked fine on 1.7 just a couple days ago!)  He had me try the downgrade again, and calibrate everything, to no avail.
I have a few questions for the folks at DJI: why would you endorse a 3rd party manufacturer (ARGtek to be specific) if there are known compatibility issues?  What was done in 1.8 that is now causing the drone to lose signal (sometimes completely) after only a few hundred feet?  Are you aware that 1.8 is seemingly picking up far more interference than previous versions?  Is there going to be a fix for this?
I ask these questions because I just wasted $70 on the kit and a week's worth of time only to figure out I'll have to go back to the stock antenna and hope it works as good as it did before the 1.8 update.
2017-2-23
Johnnyv
Flight distance : 2798707 ft
Should I be using the P3 standard updates for my P3 4K or does it have its own updates? Also. why is there not a separate separate category on this site for the P3 4K?
2017-2-24
Gulfstream
One has to wonder if they are "crippling" the P3 line on purpose? IIRC when I bought my P3S it had a stellar reputation for being a rock solid performer at the price point, and perfect for those who needed "good quality" photos from an aerial platform. The P3A of course was the "cream of the crop".
It just seems to me that almost every category of the P3 line is reporting serious issues, and P3S users are getting hammered on repair costs to fix failed firmware updates.
Failed firmware updates are NOT the fault of the end user, and if following the manufacturers instructions, and following the instructions of the phone support staff bricks your bird, you should not have to pay. Furthermore there have been many horrific examples of Repair Quotes posted that are all over the web for a unit that was sent in for Firmware Support.
I saw one tonight for $493.00 he original price paid from DJI was $479.00 Think he's a happy camper right now? And oh... guess what? He's still under the 120 month warranty, but like they did to me, they've have conveniently found a problem with the gimbal which is out of warranty. More and more of these scenarios are popping up everyday.
This is getting ridiculous.
2017-2-24
Microcyb
Spappy Posted at 2017-2-23 18:39
Did you seal the connectors?  I have the latest firmware and app for the PS3 and had awesome range for a while now.
2017-2-28
KNOTENOUGH
Flight distance : 142687 ft
Would this be for the 3 pro as well?
2017-2-28
Killrod
Can you upgrade the firmware in a phantom 3 standard without a camera I purchase a phantom 3 standard without a camera but it doesn't seem to allow to me to update the firmware
2017-2-28
SW MISSOURI
Flight distance : 1297927 ft
so what is the deal? i own 3 p3 standards and a p2vision, all were awesome until this update, now, 142m out at 52m altitude is average on the p3's. bad gimble, bad sensor, bad controller, high WiFi noise environment my ass. ive been to FOUR separate locations and the results are exactly the same. anyone have a clue? down grading the fw isn't working. it refuses to downgrade regardless of the method i try. im 4 days into this now and im getting pretty disgusted. im gonna fly the p2 tomorrow and see what it does. havent flown it since this bs started.
2017-2-28
blackcrusader
Taiwan
SW MISSOURI Posted at 2017-2-28 19:59
Suggest you do a factory reset of the drone.  There is a reset button on the drone itself.
I did that after my firmware upgrade, then re-calibrated my compass and IMU settings and all is good.
2017-2-28
Microcyb
Killrod Posted at 2017-2-28 13:48
Hope you got that Phantom 3 Standard super cheap as the camera is really a part of the bird and not intended to be sold separate.
2017-3-1
Pcnukem
Hi is there any distance issues with the latest firmware.
2017-3-2
Bourgeois
Flight distance : 229911 ft
blackcrusader Posted at 2017-2-28 22:59
Are you talking about the Controller (re)link button on the drone????
2017-3-2
Dead end theory
Flight distance : 39636 ft
South Korea
Did this update have anything to do with the relaxing of restrictions in S.Korea? it seems I am able to fly in places I wasn't able to earlier this year.
2017-3-3
Bourgeois
This (Phantom 3 STANDARD) thread is a mess.  People with Pro/Adv mixing their problems in with those updating their standards. Some of the same cant understand why FW 1.8.n isnt loading on their Pro/adv. Moderators, please close this thread or break it up into the three models.
2017-3-3
Brayan2134
Flight distance : 138205 ft
Will it fix more flyaway issue's on android? I have an ios device, but on the facebook forum it seems like the newer updates are worse than the older ones.
2017-3-3
fans9105b023
Flight distance : 108 ft
Argentina
rr@jensen.mail. Posted at 2016-11-9 02:17
where can i download the 1.7.9 file its not on the phantom help page where the other firm ware is??
Hi, where can I download the latest firmware? Thank you
2017-3-4
fans5339822e
Have updated to 1.8.10 Android djigo app 3.1.3 and losing transmission signal to remote at low altitudes. Also losing camera signal. All was fine before the update. Am I stuck with this now?
2017-3-5
Rene Jensen
uninstall the app and download it again and do a full install i had this problem and its now gone
2017-3-5
Steve-76
Flight distance : 175495 ft
it was the argtek. i had one and got half the range of stock. im an electronic tech know my way around a pc board and wires.
i was on 168 and 1500ft stock 700ft argtek.
went and got a dbs mod.now still using the argtek base usin the connectors (dbs wires need drilling) i got 3600 ft with it  was all happy till 1.7.9 then lots of disconnects and under 1000ft..
then got 1.8.10 and heard of bad home piint issue used go 2.91 and was about 3000 ft mark. but then they force the go update to 3.1.3.
so yesterday i took her out first time with go 3.1.3 and 1.8.1 and wow got my best 4200ft.......
2017-3-6
blackcrusader
Taiwan
Steve-76 Posted at 2017-3-6 09:42
I installed my Argtek 10 days after I got my drone P3S.  I've done 9920ft distance on a flight that did 24,500ft plus total mileage. Some people got fake made in China clones not the genuine Argtek which is made in TAIWAN. Argtek is a Taiwan company and well known for it's wifi antenna boosters not just for drones but for all sorts of equipment.  This flight on the latest 1.8.10 firmware and Go App.
The only reason I did not go farther was that I was spending time on this flight meandering around looking at the sights, flying into a 19mph headwind.  So my software gave me a low battery warning at 52% so I went full throttle back using RTH and sped to home point at 42mph and arrived with 35% battery.  I will try for a farther distance flight again sometime this week.  I have been flying in thick fog and clouds which also reduces range.
I doubt it was a genuine Argtek that had issues and if it did then warranty applies.
http://www.phantomhelp.com/LogViewer/Z6A7VZITUH4XUO3KFERB/
2017-3-7
MC13579
Flight distance : 203107 ft
Did the latest update to 1.10  and my copter would not start every time. Had to roll back and all is good. What is DJI doing to solve this issue?
2017-3-8
Nelsonlee
Flight distance : 2779203 ft
Malaysia
MC13579 Posted at 2017-3-8 06:37
I think you going to wrong section!
The firmware 1.10 is not for phantom 3 standard.
2017-3-8
Dioden
Milty Posted at 2017-2-22 18:42
I have done a resync between the PH3 and the controller but I have not tested it yet, quite busy with some other stuff for the moment, besides that, I’m waiting for a better weather, I don’t want to drop in the ocean. Lol
2017-3-9
JackA
Flight distance : 32057 ft
Johnnyv Posted at 2017-2-24 03:04
Your Phantom 3 4K is a Phantom 3 Standard with a 4K camera rather than a 2.7K camera.  So, yes you should track what DJI is doing for the Phantom 3 Standard.
2017-3-12
