Nigel_
Flight distance : 388642 ft
WilliamM Posted at 2017-2-25 10:43
Just like the other, this sounds all normal. The batteries auto discharged at some point because you charged them to far in advance of flying. Next, once you noticed that out in the field as hard as it might have been, the best option was to go back home and charge the batteries before flying. NEVER fly on partially charged batteries. You will have people post that they have flown on a partially charged battery and everything was fine. But in my opinion it's a flip of a coin if you might or might not have an issue, so why chance it.
" You will have people post that they have flown on a partially charged battery and everything was fine. But in my opinion it's a flip of a coin if you might or might not have an issue, so why chance it."
Flying on partial charge is fine as long as it has had a full charge since the last auto discharge. Eg, If you start off the day with a full charge, then use it down to 20%, then recharge using the car charger to 50%, then use it again down to 10% it will work fine. You must start off by charging to full before your first use after it being in storage though. |
