JBSonic
Flight distance : 1050335 ft
thanks for the feedback guys, appreciate your thoughts too barry.
As it stands I am unsure wether the white and black pixels flashing is normal or due to a faulty sensor of the X5S,
Keep in mind that these ONLY show up when recording RAW, since by shooting in 4K already, the image is "blurred" in comparison to the raw video and these pixels disappear.
I read that DJI would be releasing some sort of tutorial soon, I hope this happens because it would help a lot of people I am sure.
Yet to figure out whether my X5S is malfunctioning....
Edit:
I have spoken to support both online and on the phone. They said that if I am shooting in Auto mode, automatic exposure, this problem should not be showing up. The fact that it is means the camera is most likely not working correctly.
I have refreshed the firmware of the drone prior to the below re-test according to advice by support.
New Test Shot, low light, auto exposure, DLOG, Cinema DNG 5.2K, Linear to Rec709 conversion, Davinci Resolve:
https://ibb.co/e0X0Qk
New Test Shot with Cap on. same settings as above:
(using 2.4 Gamma) https://ibb.co/gd4KJ5
Could anyone try what happens when you record with the cap on, then load the Cinema DNG files into Davinci and choose these settings:
![](https://image.ibb.co/cM5td5/Capture4444444444444.jpg)
![](https://preview.ibb.co/eq3qQk/Capture22222222.jpg)
I know that this is the wrong gamma setting, but it bring out the worst in the image. Does anyone's footage turn into what you see here above?
(Using Linear to Rec709 conversion)
https://ibb.co/gjdeJ5
![](https://preview.ibb.co/hGDDd5/damn_1_2_1.jpg)
(Using Blackmagic Film Gamma)
https://ibb.co/k4pmy5
![](https://preview.ibb.co/gxux5k/damn_1_2_2.jpg)
The Blackmagic Film Gamma almost entirely removes the noise, however it is a very flat profile, so as soon as you grade it the noise returns.
