P4 PRO HORIZON TILT!
6619 27 2017-1-18
orlandotommy
Flight distance : 638212 ft
This is getting VERY annoying.  I do IMU calibrations and gimbal calibrations and get no errors, doing them on perfectly flat surfaces, again no errors ever.  Before i launch the horizon looks fine lined up with the grid lines.  When i get in the air usually the horizon it tilted pretty bad to the right or left, i can fix with the gimbal roll adjustment but a few minutes later its tilted again and setting gimbal roll back to 0.0 fixes it.
Any ideas about how to fix or should i just send it to DJI, i feel as if they wont fix it though and ill end up wasting a month waiting.
2017-1-18
SkyGarage
Everyone has this issue... Was also there with the P4 at the beginning.. they fixed it after some updates
2017-1-18
SHIPARCH
I have this issue as well and my P3 also suffers from it. From what I've seen everyone has the same issue. To me it doesn't always happen, only when the drone rotates. If I rotate it again it levels off.
It is annoying so I hope DJI fixes it in a firmware update.
You can clearly see it in the image attached.
2017-1-18
Visalia Califor
SHIPARCH Posted at 2017-1-18 08:51
I think Frank Wang is an old 1960's Batman fan and wants to see everyone's horizon tilted.
2017-1-18
orlandotommy
SkyGarage Posted at 2017-1-18 06:02
I dont think everyone has this issue, my P4 doesnt have this issue at all, just my P4 Pro... hopefully it gets fixed.
2017-1-18
Cobra44Magnum
Flight distance : 935135 ft
My P4 originally had some minor horizon tilt issues but a firmware update resolved that. My first P4P had multiple horizon issues like you described. I had to send it in for a different gimbal issue and the replacement also has the same issue. I'm hoping that a firmware update can address this as it did with the P4.
2017-1-18
sshorty
Common throughout all Phantoms.
Get the photo in Lightroom, and do an auto horizon tilt, or manual if the auto doesnt do a good enough job..
2017-1-18
marksy
Flight distance : 42792 ft
Yep I have this issue, and its still there after the firmware update just recently.
2017-1-19
DJI Natalia
Please try to calibrate IMU in a very level surface, then calibrate gimbal and adjust it.
Also you can upload several original pictures directly from SD card to Dropbox and provide us the link, we'll help you check it.
2017-1-19
fans7d4c3e61
Flight distance : 11827 ft
Same issue here. Horizon changes randomly while flying and when taking a picture. Amazing drone but that's annoying at the moment. Glad I kept my P4 for work because at the moment, that limits the P4P a lot.
2017-1-25
BendRealEstate
My P3 4K never had an issue, but my P4P was pretty bad for video.  The horizon was shifting, dipping, tilting and the rest so I went through DJI Support and sent it back for the Camera Main Board replaced under warranty.  Hopefully that solves it.  I'll follow up when it arrives.
2017-1-25
robert.outbackd
Flight distance : 1360433 ft
sshorty Posted at 2017-1-18 13:51
What about video correction?
2017-4-9
punkie
same issue here, doesn't seem so bad on tripod mode, but any movements on pitch roll or yaw performed with any speed are producing horizon drift. It seems to be worse on the latest firmware than the one released in late December which I used for a long time. Only just 'upgraded' the firmware recently which is when I really started to notice it. Have Done an IMU and Gimbal calibration, seems to fix it until it starts flying... Come on Dji this is your flagship phantom.. you need to fix up the firmware
2017-4-19
punkie
how about getting your existing products working before you release new ones?
2017-4-19
StephenGSY
Flight distance : 814232 ft
Guernsey
I've tested the P4 horizon issue and it appears to be linked to the compass.
If compass goes out slightly or you rotate to quickly that's when mine gets tilted.
You can confirm this by moving P4 close to a magnetic field the gimbal will move.
2017-4-19
Punchbuggy
Flight distance : 573054 ft
StephenGSY Posted at 2017-4-19 15:59
Interesting observation - the IMU sensor output definitely guides the off-set of the gimbal angle, but I wouldn't have imagined the compass. Perhaps thats how it knows how to adjust it's X axis?
Regardless, my P4P is better after the latest update (which was supposed to incorporate 'gimbal optimisation'). So I'm not seeing a worsening of the horizon levelling, as someone reported here earlier, and I imagine that this optimisation will be released in the upcoming P4 firmware release (when it's finally released...).
2017-4-19
StephenGSY
Guernsey
If it finally released. We've been waiting since forever. {:4_142:}
2017-4-19
HiTechRob
Flight distance : 14065 ft
Hmmm.  I have a P4P+ (new is Feb 2017) and I do not seem to have this issue.
2017-4-19
Punchbuggy
StephenGSY Posted at 2017-4-19 18:01
I've told you a MILLION times - don't exaggerate. (haha) Not forever, but 3 months since Beta testing anyway.
Hey Stephen, I'm of mixed minds about this myself. Sure, DJI's ongoing insistence to keep delaying the new P4 firmware release is poor-form and frustrating, but I'm confident that it Will be released - eventually. In the meantime, the more fixes and improvements developed for their other craft, the more stable the P4 release should be. However, at some stage they need to stop making changes in individual hardware controller modules and ensure it all works together prior to release - this should be what DJI are doing now.
2017-4-19
djiuser_GdzJ403
Several months and firmware updates later, a warranty return and I am still getting the same problem. I have also meticulously leveled a surface and performed all calibrations.
2017-10-31
Zatx
Flight distance : 158166 ft
djiuser_GdzJ403 Posted at 2017-10-31 03:19
I totally agree that can be very frustrating.
Were you able to remove the horizon tilt with video editing software? (I realize you shouldn't have to do this, but wondered if it was an effective fix.)
2017-11-2
truthseekers
Flight distance : 3684 ft
FIXED as of firmware 1.05.0600 it is 1000% times better... you can throw the drone around and the horizon is more solid than even the Mavic now. WOW... The drone flies better now too with yaws being smoother... its a great improvement and I refused to use this drone for a year because I just thought it was baaaad. Now its on par with the mavic for flight stability and controlability and has a better camera... so im going to use it more. Phew
I want then to remove the 500iso DLOG and then we will have a great platform for cinema log colour... I dont like having to noise clean in post with 500iso... yuk.
2018-6-6
andix
Had the same issue. Tilted horizon on the DJI4Pro.
2018-9-6
RedHotPoker
Flight distance : 165105 ft
andix Posted at 2018-9-6 13:26
Yeah, why not start your own thread?
Have you already done an IMU and gimbal calibration?
RedHotPoker
2018-9-6
Force Aerial
Flight distance : 11286 ft
Is this the issue you are having?
2019-5-3
timd14
Flight distance : 403816 ft
That's exactly what I began to experience with my P4 Advanced. Any solutions?
2019-7-1
AntDX316
Flight distance : 3394731 ft
This happens to me too, but I've noticed it's not one side dependent.  It depends on how you were flying, how the wind is, etc.  I've noticed if I do nothing, it stabilizes itself gradually.
2019-7-1
AntDX316
wow, that's like the problems I have times 15x
2019-7-1
