fans8950102a
Flight distance : 972884 ft
Portugal
I use an iphone 7 plus and experience the same as you: 1st Mavic using default micro usbb/lighting cable working ramdomly, using a USB cable from apple not working as well. All the time working randomly, connecting and disconnecting. Tried the micro sd card fix, nothing worked so I sent it back to DJI in Holland in order to be fixed. It come back after 3 weeks more or less, same disconnecting problem appearing randomly and it brought many more problems including "gimbal motor overloaded" and fixed wing mode not working, as well as drifting (before I sent it only hd disconnecting issues. Ok the second Mavic, again disconnecting issues with the default micro usb/lightning cable appearing randomly. Tried everything I could find like checking the micro sd card, IMU calibration, gimbal calibration, etc etc nothing worked. But using a default usb/lightning from apple seems to be working, so far. It has however other issues like drifting while hovering and moving forward and on active track mode instead of describing a circle while following you it flies in a ellipse going really far away and turning back so far it looses the subject. This happens frequetly, only time to time it works as it should - or at least they say it should on Mavics´s official documentations. Aw and the fixed wing mode still not working. At this moment I've been flying it using the mentioned apple's usb cabble, but I do not trust the mavic pro, simply because I willl never know when it will fail again.I paid mor or less 1500€ for the fly more combo. For this amount of money it should fly out of the box as they say it should, at least. And I know things just go wrong time to time but to have a repair service that actually causes more damage to your device than it was before you send it is something really unbeliveable!!! |
