DJI Goggles! See a different world
123456789Next >
43031 346 2017-4-24
DJI Forum Admin
Flight distance : 405039 ft
China
The DJI Goggles are comfortable goggles designed for seamless FPV flying with DJI products. [1] They combine a pair of large ultra-high quality screens, long-range, low lag wireless connectivity, and direct control of photo and video capture. With Intelligent Flight Modes like ActiveTrack, TapFly, Terrain Follow, Cinematic Mode and Tripod mode, a totally new flying dimension is created.
Low Lag Transmission
DJI Goggles are able to offer both 720p/60fps and close range 1080p/30fps viewing [2] with an extremely low latency of just 110ms. [3] Through DJI’s OcuSync wireless transmission system, up to four devices can be connected to the Mavic Pro simultaneously. [4] Antennas built into the headband ensure 360° of coverage, offering a reliable connection even if the aircraft is flying behind you. [5] Share the fun of immersive flying with friends by giving them a bird’s eye view of the world as you pilot their experience.
High Quality Optics
No Latticing: Each screen packs its pixels together tightly so you see a clean, cohesive image with no latticing. DJI Goggles can be used non-stop for a maximum of six hours.
High Resolution: Typical “2K” screens inside the goggles are split into two 1280x1440 sections, one for each eye. When viewing a 16:9 image, some sections are further cut off, leaving only a quarter of the available pixels. DJI Goggles have two 1920x1080 screens providing more than twice the amount of pixels of a typical 2K single screen.
Optical Design: DJI Goggles use a beam splitter to display an image in front of each eye, as well as polarization to prevent any image overlap. This allows it to create genuine Full HD 1920x1080 resolution per eye. When used with the large aperture aspheric lens, an 85° field of view per eye is created for maximum immersion.
Head Tracking[1]
Your head movements control both aircraft yaw and camera tilt in Head Tracking Flight mode as with remote controller sticks. All you need to do is turn left or right to yaw left or right, and straighten your head to stop turning. In Head Tracking Gimbal mode only the gimbal will move without affecting yaw.
Touchpad & Remote Controller[1]
Access to key intelligent features through a touchpad integrated into the DJI Goggles or 5D button on the Mavic Pro controller makes navigating the internal menu system easy and intuitive.
Power Button: for turning on/off the Goggles
Touchpad: choose a menu and confirm
Function Button: enter Focus Mode and other functions
Intelligent Flight [1]
DJI Goggles are a perfect pair with DJI's new Intelligent Flight Mode: Fixed-Wing Mode. In this mode, the aircraft doesn’t turn left or right but instead flies forward with enough rotational movement for realistic flight simulation. Combined with Head Tracking Mode, you can use your head to control the Mavic Pro for a fully realized flight experience.
An AR trajectory prediction feature in Fixed-Wing Mode makes using this mode in complex environments safer. Other Intelligent Flight Modes include Terrain Follow, ActiveTrack, TapFly, Cinematic Mode and Tripod Mode.
Comfortable and Flexible
A unique solid headband design balances and spreads the weight of DJI Goggles around the head evenly, minimizing pressure on the face and keeping them comfortable to wear for hours. People who wear glasses are also able to wear them comfortably. The screen portion of DJI Goggles can be flipped up to glimpse the real world, or detached entirely for easy storage and portability.
Connect Your Devices
A range of built-in interfaces allows DJI Goggles to work with a wide range of devices.
Micro USB Input[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[/img]
[1] DJI Goggles supports Mavic Pro, Phantom 4 series and Inspire series. Some functions will be adapted for different DJI Products.
[2] HD mode: 1080p/30fps: near-field with no interference; 720p/30fps: at long range or with interference; Smooth Mode: 720p/60fps
[3] Using the Mavic Pro, stream wirelessly at 720p/60fps and record video at 720p/120fps
[4] For Mavic Pro with two pairs of DJI Goggles and two RCs only
[5] The use of a spotter is essential when wearing DJI Goggles. The aircraft should not fly beyond the spotter’s line of sight. [6] DJI Goggles can only play content downloaded from DJI drones.
2017-4-24
SkunkWerxs
Flight distance : 231217 ft
In the picture for the ---Touchpad: choose a menu and confirm does this mean the exterior side of the goggles is being a used for mapping of the screen by touch ?? That would be definitely different and a good selling point for them if described that this is actually how it works --- The description is somewhat Vague
The price is good, not that expensive for a set of goggles with all of the capability's it has
Good move DJI
2017-4-24
Maverikster
Flight distance : 24672 ft
Ordered...!
2017-4-24
DRONE-flies-YOU
Flight distance : 1638323 ft
My wallet hates you, DJI!!!  LOL...  ORDERED!!!
I've been waiting 7 months for these.  The ability to accept ANY HDMI input is a huge surprise!  Awesome stuff.
2017-4-24
Maverikster
DRONE-flies-YOU Posted at 2017-4-24 08:08
I was actually also pleasantly surprised by the price. Thought it was going to be at least EUR 700, but 550 is pretty good, especially since it has more features than I expected...
2017-4-24
Alex Assenmache
Flight distance : 216430 ft
Lovely
2017-4-24
gilly4
Flight distance : 73369 ft
Like many on here, been waiting for months. Ordered!
2017-4-24
Levurmion
Flight distance : 182710 ft
Indonesia
Head tracking doesn't work with Inspire 1... what a bummer
2017-4-24
fans802e59b3
Flight distance : 327352 ft
It's like Christmas as been waiting ages for these bad boys.. I love flying FPV and now I can once again ... thank you and ordered..
2017-4-24
tokenbrit
Flight distance : 384094 ft
At last! The order is in - I can't wait to try out fixed wing mode
2017-4-24
13MStang
Flight distance : 892749 ft
I have placed my order!
2017-4-24
DRONE-flies-YOU
Alex Assenmache Posted at 2017-4-24 08:12
Lovely
https://www.youtube.com/watch?v=F8BysgNR6a0
Curious if this would help mitigate the DJI GO app disconnect that can happen.
Do the goggles still receive the liveview even when the app has disconnected/crashed??
2017-4-24
Mavrick
Jamaica
I Placed my Order 24th April 2017 at 1:30pm
Now my fingers are crossed that DJI really comes through by May 20th
2017-4-24
Mafia16
Flight distance : 26591677 ft
Dominican Republic
I will love to play with these SOON also place my order.
2017-4-24
hyderja
Ordered!! Dang you DJI!!!
Order time: 2017-04-24 18:02:07 (UTC)
2017-4-24
DevonDrone
Flight distance : 71716 ft
Will these also work wirelesly with the p4p or will they require connection vire a wire?
2017-4-24
dronist
Order Time:        2017-04-24 18:03:48 (UTC)
2017-4-24
dronist
tokenbrit Posted at 2017-4-24 08:25
You can try it now. Really, really cool. You will enjoy better with the goggle but still when you watch your video is almost serene.
2017-4-24
Danny-B-
Flight distance : 306640 ft
Ordered !
The price is a big suprise, i assumed it would be a fair bit more. Watched the video and the only thing i'm not keen on is how sensitive they seem to be with head tracking. I hope they include (or will in the future) a configurable sensitivity, other than that, specs are amazing
Ohh .. they are pretty obnoxious too compared with fatsharks etc, but i guess they will be fine
2017-4-24
Maverikster
Order Time: 2017-04-24 16:02:47 (UTC)
2017-4-24
FPVJunkie
Flight distance : 66421 ft
Ordered: 4/24 @18:42UTC.
Oh man, my wife is going to kill me!!! Better to beg for forgiveness than to ask for permission though! HAHAHA. Dang you DJI!!!
2017-4-24
z4k4tt4ck
Flight distance : 535 ft
Would these goggles be able to be used in VR pc games ? .... maybe a stupid question ...but i have no idea thanks
2017-4-24
dustout
Is the video downlink with the Mavic Pro limited to 720p? It's a bit unclear from the footnotes and FAQ since they are talking about latency. I'd like to know if I can get the full resolution out of this thing's screens with the Mavic, at least under ideal circumstances.
Also, I assume with this I can have the downlink being seen in both the goggles and on the phone plugged into the remote? That will be really great for flying with friends so it's less boring for them.
2017-4-24
DJI Joe
dustout Posted at 2017-4-24 11:19
Live view modes are 1080p30, 720p60, and 720p3 according to the manual.
2017-4-24
tokenbrit
dronist Posted at 2017-4-24 10:11
I have tried it on the phone - just not the same with the small screen
2017-4-24
fans04099d0a
Flight distance : 99695 ft
Tried to order, sold out
2017-4-24
JaseUK
Can you use these if you wear glasses?
2017-4-24
Masemoto
Flight distance : 5137425 ft
JaseUK Posted at 2017-4-24 12:04
Yes. #2 in the FAQ >> http://www.dji.com/dji-goggles/info#faq
2017-4-24
Masemoto
You sure?  I am still able to add to cart and start checkout.
2017-4-24
DJI Joe
Yes. The DJI Goggles can be worn over glasses.
2017-4-24
JaseUK
DJI Joe Posted at 2017-4-24 12:12
That's awesome, thanks
2017-4-24
fans04099d0a
Masemoto Posted at 2017-4-24 12:10
Yep, got them in my cart, click place order - message "Sorry, this item is currently out of stock.: DJI Goggles"
Also if I go to the product page now it's - "Sorry, this item is currently out of stock" no add to cart.
Very sad...
2017-4-24
fans04099d0a
fans04099d0a Posted at 2017-4-24 12:19
Very sad...
Sold out seems to be region related. If I choose US shows as still available. Not happy.
2017-4-24
dronist
tokenbrit Posted at 2017-4-24 11:38
I know but, download the movie to your computer or big TV screen!
2017-4-24
dronist
fans04099d0a Posted at 2017-4-24 12:23
I got confirmation on one order and the other order being processed???
2017-4-24
dronist
FPVJunkie Posted at 2017-4-24 10:47
Just tell her it is BETA unit and DJI will refund me 90% later...
2017-4-24
TechShizzle
Flight distance : 273730 ft
Sold out for me in U.S.
2017-4-24
fans04099d0a
Snooze you lose I guess, it did say limited supply. It just hurt that little bit more getting to the "place order" part with credit card in hand
2017-4-24
DevonDrone
Ordered still showing stock for UK
2017-4-24
TechShizzle
Worst part is I just happened to look at the DJI store earlier this morning looking for info on Goggles (first time in a couple of months), and must have just missed the announcement by minutes. Damn!
2017-4-24
123456789Next >
