DJI Go 4 App freezes using with the Samsung Galaxy S7 Edge
3789 14 2017-3-20
b0n3
Flight distance : 21083 ft
I and my friends have faced with the issuue of freezes DJI Go 4 app during a flight while using Intelligent Flight Modes on Samsung Galaxy S7 Edge.
After starting one of the Intelligent Flight mode, for example Active Track, DJI Go App freezes and react on a touch once in 20 or 30 seconds also it is conjuction with the high baterry drain. As a result I forced to restart GO App during Mavic flight, which is not safety. The issue is not constant but unfortunately happens quite frequantly. Dji please adapt Go 4 App to the Android's flagships, cause a lot of peaople using them all around the world with your drones.
2017-3-20
chalde
Flight distance : 668314 ft
What's the OS on your S7? If you're using Nougat, you're definitely going to run into a lot of problems. The S7 with Marshmallow OS is working a lot better.
2017-3-20
b0n3
chalde Posted at 2017-3-20 04:40
Yes, I have updated my device to the latest Android version.
Seems I should not have done it
2017-3-20
b0n3
Did anybody else try to use intelligent flight modes with the Samsung Galaxy S7 Edge?
Thank heavens that it is stopped to crash after the last app update....
I and my friend have the similar issues....
2017-3-22
digitalintruder
Flight distance : 3652379 ft
b0n3 Posted at 2017-3-22 06:18
[Galaxy S7 Nogout] I get app crashes the first time I try to do point of interest - other modes haven't crashed like that on me. Once the app reboots, then intelligent modes seem to start working fine.
2017-3-22
Lemonsorbie
Flight distance : 3809 ft
Hey.
S7 Edge is not supported by DJI as a preferred device.
{:4_142:} I KNOW!
2017-3-22
Aerial Gopher
Flight distance : 331906 ft
I have an s7 Edge, latest firmware on phone and Mavic, and no problems.  Used active track, point of interest.  Follow me feature worked, but stopped following, but I think I was driving too fast. Have not tested it more than 3 times.
I would guess that you have something on your phone that is causing issues.  Try closing all apps that you are not using.  ( I am making an assumption here that the DJI go app is what is doing the processing for the intelligent flight modes? rather than image processing on the drone itself?  I'd like to know that, but I have not researched it yet )
2017-3-23
Bintryin
Flight distance : 164406 ft
None Edge version of S7 working fine with latest updates
2017-3-23
Scaido
Flight distance : 3366 ft
Latvia
It was working fine on s7 edge with Android 6.0 Marshmallow. Then I did updated to phone to 7.0 Nougat and i still did fine. But couple of days ago new minor system update came out and after that update DJI app keeps crashing on launch
2017-4-8
rsands
Same problem here. Was working great until latest version came out.
It works fine most of time but after alot of recording it starts to really lag. You press a button and the drone doesn't react. Controller works fine but the app is messed up badly. It then starts to go into record mode by itself. Somethings not right with update. Really wish DJI would test things a bit better
2017-4-25
spoonlamp_
Flight distance : 301506 ft
Romania
I'm having the exact same issues here. S7 Edge updated, but I've held off updating the DJI Go 4 app recently due to a fear of having it locked down while on my travels (the rumoured NFZ restrictions).
I've found the same problems - The app starts fine, but after a little while of recording it begins to get very laggy and the phone quickly becomes extremely hot. Eventually the record button stops working or becomes so laggy that I don't even know what's going on. I also get parts of the display disappearing and split second disconnections. I'm going to assume that the problem stems from poor compatibility with the latest Android update, but in order to be sure I think I'm going to have to update the Go 4 app...
  You would have thought that DJI would be pre-emptive with it's updates and roll out changes as and when Android do their updates. It always seems like one is trailing miles behind the other...and they definitely put the blame on each other. DJI say the app is fine, Android need to correct the system to run it, but then Android say that  DJI need to just make their product work on the platform...
2017-6-6
baghera41
Flight distance : 44665 ft
Hi everybody with this issue.
To solve this go into developer options (google;) ), then change minimum width from 390 to 490.
This should solve the problem with crashing and lagging. Hope this helps.
2017-6-7
b0n3
baghera41 Posted at 2017-6-7 08:54
Hello )
Could you please tell a bit more about this tweak?
What does this function for?
2017-6-9
carlodf
Having installed my Galaxy S7 Edge both Dji GO 4 and Dji GO, to manage my OSMO, the two applications were in conflict and the mavic controller did not detect my smartphone. I disaggregated this and everything has returned normal.
2017-6-11
baghera41
b0n3 Posted at 2017-6-9 03:11
Hello )
Hi there
This just changes the width(pixels) of the screen so Dji can run
Don't worry, you can easily change this back afterwards if you want to.
2017-6-12
