GPS not being recognised
1584 7 2015-3-23
markyparky22
So i recently upgraded my phantom 1 with the PMU v2 and the GCU v2 so i could use a gimbal on it. but it seems as though it has knocked out the GPS. I though i must have just wired it all wrong so i did it all again and nothing changed the GPS isn't recognised when i go into the A2 software. Really really sucks as this means its really hard to fly when its windy... which being england thats quiet alot of the time. so it would be amazing to hear some responses if anyone knows anything about this probelem. gps.JPG
Dont know if i just need to install the GPS drivers again? but i couldn't find any... so im out of ideas.
2015-3-23
ShadyDealer
Flight distance : 983428 ft
Did you load the default configuration parameters like it advises you to do so?
2015-3-23
joe
Where do you have the GPS plugged into?
I don't see the main board in your screen shot so I am assuming that you have bypassed the main board and set this up as a Naza V2.
If this is true - the GPS should plug into the PMU CAN port.
2015-3-23
markyparky22
ShadyDealer Posted at 2015-3-24 01:54
probably not where do i get those? have you got a link
2015-3-23
markyparky22
joe@heliflightc Posted at 2015-3-24 02:34
I don't see the main board in your screen shot so I am assum ...
I have it plugged into the PMU V2 where it says to plug it in, and then that is pluged in to the naza and connected to the GCU
2015-3-23
joe
So to verify  the PMU is plugged into the "EXP" port on the Naza and the GPS  is pugged into the Can Port labeled GPS and the GCU is plugged into the PMU CAN port for Expansion.  Is this correct?
2015-3-23
markyparky22
joe@heliflightc Posted at 2015-3-24 04:39
So to verify  the PMU is plugged into the "EXP" port on the Naza and the GPS  is pugged into the Can ...
Yes correct.
2015-3-23
markyparky22
would anyone be up for going on skype or google hangouts to help me works this problem out? would be amazing if someone could,
2015-3-24
