SkunkWerxs
Flight distance : 231217 ft
hallmark007 Posted at 2017-5-15 16:46
Hi 204c5, your log is almost identical to the OP's, you also hit serious magnetic interference and went into Atti your aircraft was also responding to your stick movements, the odd yaw movements could be to do with the wind.
For a fair bit of your flight you were loosing radio signal. But I suppose lucky RTH worked.
Was there anything in your area that might have interfered with compass like steel roof or interference on the ground prior to taking off.
Hey Hall , What you said earlier in the thread about the Flying Environment area maybe the possible
cause for the issue and now almost the same issue with another op , I looked and zoomed
out at there satellite maps and found the two to be close to an Industrial and Land Development
areas and one was close to a airport also , Your Theory about there flying Environment
is strongly looking like this is the cause in my opinion .
FlySafe-FlyFree
