Calculating Kinetic Energy?
8904 7 2017-6-5
CHEUCKLATE
The country I am visiting (Croatia) requires ceritifications for drones that have a Kinetic Energy greater than 79 J.
Given the specs that I've pulled:
Mass: .3 kg
Velocity: 3m/s
plugging in the equation   that comes out to 1.35 J... that seems incredibly low, is my calculation wrong?
For instance the DJI Mavic specs:
Mass: 7.34 kg
Velocity: 5m/s
That comes out to 91.75 J
Thanks in advance.
2017-6-5
Cravenfan
Flight distance : 125256 ft
My head just exploded...
2017-6-5
fans68a19c4d
Try 0,734kg instead of 7,34kg for the Mavic
2017-6-5
GCBrent
Flight distance : 66286 ft
Your calculation is correct. 1.35J
2017-6-5
Griffith
Flight distance : 98537 ft
the mavic is 0.734 kg, not 7.34
2017-6-6
Galchanto
Flight distance : 101066 ft
Hi CHEUCKLATE,
Your calculation above is correct but unfortunately, your initial figure for velocity is wrong.  I think you need to input the highest potential energy the drone has in flight which is 13.89m/s (50KPH) not 3m/s.  If you do this you should get a figure closer to 29J which makes more sense and is below the regs in Croatia.  The Mavic would top out at 121J which would indeed fall into the regulations.
Hope that Helps.
2017-6-7
fansee09f0a3
Flight distance : 37740 ft
Croatia
Use this calculator for calculation. For Mavic is needed registration in Croatia.
Aprox 117J produce this unit.
Calculator
Cheers
2017-8-6
Dronason
Flight distance : 5689042 ft
fansee09f0a3 Posted at 2017-8-6 04:36
The main question is what case is applicable:
  • Spark hitting something horizontally at full maximum speed
  • Spark falling down after a catastrophic total power loss at a high altitude
The second is more likely the main question of flying regulator.
2017-9-24
