StefanoGinobili
![](https://forum44.djicdn.com/data/attachment/common/65/common_11_usergroup_icon.png) lvl.2
Flight distance : 422818 ft
Hello Cetacean,
yes, I was using the same USB cable to connect the P4P to the PC and to the Mac. I just unplugged to USB cord type-A connector from the (not working) PC and plugged it to the (working well) Mac.
After your suggestion I also tryed another cable... but the result didn't changed ![](//forum44.djicdn.com/static/image/smiley/default/sad.gif)
The strange thing is that, in previous days, the same P4P worked well with the same PC. When I installed the firmware 1.03.0418 I remember I calibrated the P4P vision sensors using the PC.
So today I tryed to lookup for previous versions of DJI Assistant 2 and, after googling a while, I found the following:
- DJI Assistant 2 - 1.0.8
- DJI Assistant 2 - 1.1.0
And... none of them worked! ![](//forum44.djicdn.com/static/image/smiley/default/sad.gif)
Maybe the following could be useful for DJI software engineers...
Sniffing (by Wireshark) communication between the Electron app and the underlying Root application (v1.1.0-2), I captured the following (until after the P4P has been powered on):
GET /general HTTP/1.1
Host: localhost:19870
Connection: Upgrade
Pragma: no-cache
Cache-Control: no-cache
Upgrade: websocket
Origin: file://
Sec-WebSocket-Version: 13
User-Agent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) DJIAssistant2/0.0.1 Chrome/47.0.2526.110 Electron/0.36.7 Safari/537.36
Accept-Encoding: gzip, deflate
Accept-Language: en-US
Sec-WebSocket-Key: ************
Sec-WebSocket-Extensions: permessage-deflate; client_max_window_bits
HTTP/1.1 101 Switching Protocols
Upgrade: websocket
Connection: Upgrade
Sec-WebSocket-Accept: *************
Server: DJIDeviceService
Access-Control-Allow-Credentials: false
Access-Control-Allow-Methods: GET
Access-Control-Allow-Headers: content-type
Access-Control-Allow-Origin: file://
Date: Sun, 11 Jun 2017 18:58:50 GMT
"APP_STATUS": "in_sync",
"EVENT": "app_ver_notify"
.w{
"APP_VERSION": "1.1.0",
"EVENT": "app_ver",
"HASH_SERVICE": "8fa2ce06a145ca4faf4e622067122fed53b49ec8"
"AUTOTEST_ENABLED": false,
"DEBUGGER_ENABLED": false,
"EVENT": "debug_status",
"FACTORY_ENABLED": false
"CONFIG_STATUS": "ERROR",
"EVENT": "app_ui_mode",
"IS_AUTO_UPGRADE_MODE": false
.Q{
"EVENT": "push_system_info",
"OS_TYPE": "Win",
"OS_VERSION": 192
.....e... ...G...\.......&..._................~.~{
"ERROR": "SUCCESS",
"LOGIN_EMAIL": "stefano.***@***.it",
"LOGIN_STATUS": true,
"SEQ": "nhs9mczp"
"EVENT": "login_success"
While uncommenting line "mainWindow.webContents.openDevTools()" in file "%ProgramFiles(x86)%\DJI Product\DJI Assistant 2\AppFiles\main.js:113", here is what the console is logging until after the P4P has been powered on...
Hope this helps.
Thank you all ;)
