Why Are Videos Split at 9 Minutes
922 7 2017-5-25
DroneGuyEd
Flight distance : 1168140 ft
I video every flight.  On longer flights, the resulting videos are splt into multiple parts at about 9 minutes.  Why is this and is there a way to make it not split?
I shoot everything at 4K.
2017-5-25
Mobilcams
Flight distance : 2907674 ft
Because the file system used cannot handle anything larger than 4Gb files. It has to split them up.. There is no way around this. On the P4P the files are around 5 minutes long (higher bit rate)..
2017-5-25
fansa84fe8a4
Flight distance : 3 ft
My problem is that it seems to lose maybe 4-6 frames on the stop and resume with the 4GB limitation.  Never have been able to get a clean splice.  Have to re-fly and try and maintain a flight less than 8 minutes with the P4.
2017-5-25
DroneGuyEd
Mobilcams Posted at 2017-5-25 04:27
That makes sense as it traces back to limits of FAT32 and exFAT file limitations.  Its easy to forget this part...
2017-5-25
Mobilcams
fansa84fe8a4 Posted at 2017-5-25 07:13
Yeah I have noticed this too. Thankfully with the Pro they figured out how to do it without that limitation.
2017-5-25
fans015d3523
Flight distance : 467799 ft
I have the same problem, and my microsd is formated in exFAT.
2017-6-25
pasaytenpete
Flight distance : 47346 ft
fans015d3523 Posted at 2017-6-25 03:44
Doesn't matter how the sd is formatted...  The 4GB split is programmed in the DJI software.
2017-6-25
fansb1fe1104
Flight distance : 3372566 ft
It's not DJI that programs the 4gb limit, it is the file system that limits it. NTFS file system can have unlimited gb, but unfortunately the P4 cannot handle that file system.
2017-6-25
