VPS Calibration of I2 and that glass plate.
824 1 2017-7-3
fansa84fe8a4
Flight distance : 3 ft
New I2 and trying to calibrate with that glass plate and its dots.
I get the overlap of the red and green rectangle and then it jumps to the 1/3 screen with the blue thermometer scale.  It seems to stay with a few blue dots on the scale even though I move it side-to-side.  However, if I tilt it a lot then I can get the blue dots to climb or lower and move on from 1/3 to 2/3 or 3/3.
So is tilting required and not side-to-side?  Not well explained on the info on the Assistant 2 screen and I can't find a video on using it either.
Also, given the calibration is done indoors tied to the Assistant 2 on the desktop computer, are shadows a problem with the i2 being held over the glass plate and how much light is needed?  I thought the method using the laptop or ocmputer screen was easier and the light more even than this glass plate system.
If I get to 3/3 on the forward VPS and underside VPS and then it proceeds to do the calibration to 100%.  Do I assume it is correct even though fighting with the thermometer scale and the radical tilting?
Tia.
2017-7-3
fansa84fe8a4
Bump.
DJI?  Anyone with a video on using this new glass plate VPS calibration with Assistant 2 and the I2?
2017-7-4
