Grumpy Old Man
Flight distance : 37795 ft
Sorry guys, but mine is flying perfectly after the upgrade. Even better than when I first bought it many months ago. The smart return home is fantastic too, you can see it correcting as it descends and lands within an inch of take off (from over 1km away).
I had the same problems as some when upgrading with it locking at 99% for ages, then reporting upgrade complete but the controller still beeping, then bricked after restart. Followed forum instructions to reset and it upgraded fine after that.
After reading all the horror stories, before I flew I reset everything I could reset to factory, deleted / cleared all logs etc. Basically scrolled through every menu option and cleared / reset everything.
Then I calibrated the IMU with that fancy new method where you manually lean the craft in all axis, then calibrated the compass. Then and only then I went for a fly.
FANTASTIC!! Flies like a dream, had no disconnects, no jerking or correcting. The idle speed before takeoff is nice and quiet (slower props), Hovered perfectly at different heights and flew straight with no issue.
The APP is at 4.1.3, the RC is 1.9.2, the Aircraft Database is 01.00.01.04 and the APP Database is 01.00.01.04.
GOM |
