benji89
Flight distance : 411109 ft
Thank you so much for these info, it really helps understand better.
Unfortunately, after long search, I didn't succeed in finding the lost mavic... that really sucks!
DJI support replied explaining the following:
"1. Aircraft flew well with GPS mode, and responded to Pilot's command well. The aircraft was under the interference of wind during the flight.
2. At flight time 01'37'', H=51m, D=280m. Aircraft tilted 14.1 degrees forward and tilted 8.3 degrees to the right, and had a moving speed of 5.8 m/s to the left rear without command inputting , which indicated that the aircraft was influenced by strong winds.
3. At flight time 02'42'', H=49m, D=573m, the aircraft entered Go-home mode when the pilot triggered one-tap return-to-home with remote, but aircraft can't return home and was blown farther and farther away.
4. At flight time 03'53'', H=68m, D=664m, the flight record ended.
In the another flight record, the aircraft was blown farther and farther away. At flight time 07'23'', H=34m, D=1820m, the flight record ended.
According to the analysis, the incident was not caused by any product malfunction factors. As such, we could not provide warranty service."
What I do not understand is that when I uploaded the logs on airdata, it mentionned that the wind was around 13mph, which is far beyond the level 5 wind DJI mention (19 to 24 mph). How could the Mavic be blown farther and farther away with this 13mph wind ?
Thank you.
