offtopic about drone regulations laws and smarthats
123Next >
3272 89 2017-9-16
Koppo
Flight distance : 191726 ft
Croatia
I am not kidding! I'm still totally shocked!I want to explain what happened. We have pretty cloudy and autumn weather. The clouds were low so I decided to try break through the clouds today.
I started my Spark normally and started to climb. On approx. 350m I already hit the bottom of the clouds. I observed that the altimeter in the DJI GO app started to go crazy, it jumped from different heights back and forth, I continued to climb. When I reached the inner cloud my altimeter showed 0m !? I could not see anything - because I was in the cloud. I could not descend anymore and then I started to panic! I tried to get more height and then I lost signal, and it randomly connected and disconnected. I could not descend as it always showed 0m altitude. It went to return to home and stuck in the clouds because it thought it's < 1m above ground.
I knew I am screwed. I was so worried and scared because I knew that thing will come down like a brick from over 400m (thats 1200ft!). I flew in populated area and there is a main road and a lot of houses...
When the battery went down I took cover and waited, hoping that thing will drop in the lawn. But then I heard a huge crash noise... It came down at my neighbours house, I already thought that thing went through his roof!
But I was lucky, that thing hit the concrete roof of his balcony...  I had a loc8tor but that thing flew off on impact... The battery flew off over 15meters on impact. I knew, my drone is gone. But when I climbed on the roof I saw the Spark with only the housing a bit open (the lid of the drone) and 2 props missing... I took it and pressed the housing together, it snapped in. I then put in 2 new props and started the drone with a fresh battery. Using my smartphone I could take off and this freaking thing IS STILL WORKING!
I CANT BELIEVE IT... It only got a scratch on the back left prop arm. That thing is working guys, the battery too...
BUT...
Now the question. Why the hell the altimeter goes crazy when going into a cloud or mist? How can I override the controls to descend when it says 0m?
Flight timeAltitudeHome DistanceTypeNotification
A00m 00s0.0 m0 mMode[url=]Mode changed to Motors_Started[/url]
B00m 01s0.0 m0 mTip[url=]Setting new Return-To-Home altitude to 30m (98 ft). Setting new Maximum Flight Altitude to 500m (1640 ft)[/url]
C00m 01s0.0 m0 mMode[url=]Mode changed to Assisted_Takeoff[/url]
D00m 01s0.0 m0 mTip[url=]Motors Started[/url]
E00m 03s0.0 m0 mMode[url=]Mode changed to GPS_Atti[/url]
00m 32s47.4 m4 m
[url=]90% Battery[/url]
F01m 28s160.6 m47 mData Loss[url=]Downlink data connection lost for 2.3 seconds[/url]
01m 46s194.3 m47 m
[url=]81% Battery at maximum distance[/url]
01m 50s202.0 m47 m
[url=]80% Battery[/url]
G02m 56s336.1 m46 mMode[url=]Mode changed to Sport[/url]
03m 05s362.6 m46 m
[url=]70% Battery[/url]
H03m 59s475.4 m46 mData Loss[url=]Downlink data connection lost for 2.7 seconds[/url]
I03m 59s475.4 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
J04m 08s478.3 m46 mData Loss[url=]Downlink data connection lost for 7.8 seconds[/url]
K04m 08s478.3 m46 mMode[url=]Mode changed to Go_Home[/url]
L04m 15s493.0 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
M04m 18s498.2 m46 mWarning[url=]Maximum Flight Altitude Reached. Adjust altitude in MC Settings if required.[/url]
N04m 32s499.9 m46 mData Loss[url=]Downlink data connection lost for 14.4 seconds[/url]
O04m 33s500.0 m46 mMode[url=]Mode changed to Go_Home[/url]
P04m 34s499.8 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
Q04m 34s499.9 m46 mMode[url=]Mode changed to Go_Home[/url]
R04m 35s500.0 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
S04m 35s500.0 m46 mMode[url=]Mode changed to Go_Home[/url]
T04m 39s499.9 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
U04m 57s500.0 m46 mData Loss[url=]Downlink data connection lost for 17.2 seconds[/url]
V04m 58s500.0 m46 mMode[url=]Mode changed to Go_Home[/url]
W04m 59s499.8 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
X05m 00s500.0 m46 mMode[url=]Mode changed to Go_Home[/url]
Y05m 00s499.9 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
Z05m 00s499.9 m46 mMode[url=]Mode changed to Go_Home[/url]
a05m 01s499.9 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
b05m 03s500.0 m46 mMode[url=]Mode changed to Go_Home[/url]
c05m 04s500.0 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
d05m 06s500.0 m46 mMode[url=]Mode changed to Go_Home[/url]
e05m 07s500.0 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
f05m 07s500.0 m46 mMode[url=]Mode changed to Go_Home[/url]
g05m 08s500.0 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
h05m 10s500.1 m46 mMode[url=]Mode changed to Go_Home[/url]
i05m 10s500.1 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
j05m 11s500.1 m46 mMode[url=]Mode changed to Go_Home[/url]
k05m 12s500.0 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
l05m 12s500.0 m46 mMode[url=]Mode changed to Go_Home[/url]
m05m 13s499.9 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
n05m 13s499.9 m46 mMode[url=]Mode changed to Go_Home[/url]
o05m 14s500.0 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
p05m 14s500.0 m46 mMode[url=]Mode changed to Go_Home[/url]
q05m 15s500.0 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
r05m 16s500.0 m46 mMode[url=]Mode changed to Go_Home[/url]
s05m 17s500.1 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
t05m 18s500.1 m46 mMode[url=]Mode changed to Go_Home[/url]
u05m 18s500.1 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
v05m 19s500.1 m46 mMode[url=]Mode changed to Go_Home[/url]
w05m 19s500.1 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
x05m 20s500.1 m46 mMode[url=]Mode changed to Go_Home[/url]
y05m 21s500.2 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
z05m 22s500.2 m46 mMode[url=]Mode changed to Go_Home[/url]
A05m 22s500.1 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
B05m 25s500.1 m46 mMode[url=]Mode changed to Go_Home[/url]
C05m 26s500.1 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
D05m 26s500.1 m46 mMode[url=]Mode changed to Go_Home[/url]
E05m 27s500.2 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
F05m 27s500.2 m46 mMode[url=]Mode changed to Go_Home[/url]
G05m 28s500.2 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
H05m 29s500.1 m46 mMode[url=]Mode changed to Go_Home[/url]
I05m 30s500.1 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
J05m 30s500.1 m46 mMode[url=]Mode changed to Go_Home[/url]
K05m 31s500.1 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
L05m 53s499.8 m46 mData Loss[url=]Downlink data connection lost for 18.3 seconds[/url]
M05m 53s499.8 m46 mWarning[url=]Signal Lost. Aircraft Returning Home[/url]
N05m 53s499.8 m46 mMode[url=]Mode changed to Go_Home[/url]
O05m 54s499.9 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
P05m 56s499.9 m46 mMode[url=]Mode changed to Go_Home[/url]
Q05m 56s500.0 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
R05m 57s500.0 m46 mMode[url=]Mode changed to Go_Home[/url]
S05m 59s499.9 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
T05m 59s499.9 m46 mMode[url=]Mode changed to Go_Home[/url]
U06m 01s500.1 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
V06m 01s500.1 m46 mMode[url=]Mode changed to Go_Home[/url]
W06m 02s500.1 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
X06m 04s500.1 m46 mMode[url=]Mode changed to Go_Home[/url]
Y06m 05s500.1 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
Z06m 06s500.2 m46 mData Loss[url=]Downlink data connection lost for 1 seconds[/url]
a06m 07s500.1 m46 mData Loss[url=]Downlink data connection lost for 1.1 seconds[/url]
b08m 15s500.0 m46 mData Loss[url=]Downlink data connection lost for 123.8 seconds[/url]
c08m 16s500.0 m46 mMode[url=]Mode changed to AutoLanding[/url]
d08m 18s500.0 m46 mWarning[url=]Descending. Exited Visual Avoidance System. Critically Low Power. Aircraft Landing[/url]
e08m 20s500.0 m46 mData Loss[url=]Downlink data connection lost for 1.8 seconds[/url]
f08m 20s500.0 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
g08m 22s499.7 m46 mData Loss[url=]Downlink data connection lost for 1.2 seconds[/url]
h08m 36s497.4 m46 mData Loss[url=]Downlink data connection lost for 14.3 seconds[/url]
i08m 36s497.4 m46 mWarning[url=]Warning__The remaining battery is only enough for RTH. Return home now.[/url]
j08m 36s497.4 m46 mMode[url=]Mode changed to AutoLanding[/url]
k08m 40s496.9 m46 mMode[url=]Mode changed to Confirm_Landing[/url]
l08m 44s495.3 m46 mWarning[url=]Warning__The remaining battery is only enough for RTH. Return home now.[/url]
m08m 45s494.9 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
n08m 45s494.8 m46 mMode[url=]Mode changed to Confirm_Landing[/url]
o08m 47s494.1 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
p08m 48s493.9 m46 mMode[url=]Mode changed to Confirm_Landing[/url]
q08m 50s493.3 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
r08m 51s492.9 m46 mMode[url=]Mode changed to Confirm_Landing[/url]
s08m 51s492.8 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
t08m 51s492.6 m46 mMode[url=]Mode changed to Confirm_Landing[/url]
u08m 52s492.3 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
v08m 52s492.2 m46 mMode[url=]Mode changed to Confirm_Landing[/url]
w08m 54s491.5 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
x08m 54s491.4 m46 mMode[url=]Mode changed to Confirm_Landing[/url]
y08m 56s491.0 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
z08m 58s490.4 m46 mData Loss[url=]Downlink data connection lost for 1.1 seconds[/url]
A08m 59s490.0 m46 mData Loss[url=]Downlink data connection lost for 1.4 seconds[/url]
B09m 08s487.4 m46 mData Loss[url=]Downlink data connection lost for 7.2 seconds[/url]
C09m 08s487.3 m46 mMode[url=]Mode changed to Confirm_Landing[/url]
D09m 08s487.3 m46 mWarning[url=]Warning__The remaining battery is only enough for RTH. Return home now.[/url]
E09m 17s484.4 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
F09m 18s484.2 m46 mMode[url=]Mode changed to Confirm_Landing[/url]
G09m 18s484.0 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
H09m 19s483.9 m46 mMode[url=]Mode changed to Confirm_Landing[/url]
I09m 34s479.2 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
J09m 34s479.1 m46 mMode[url=]Mode changed to Confirm_Landing[/url]
K09m 35s478.9 m46 mMode[url=]Mode changed to WiFi_Reconnect[/url]
L09m 35s478.8 m46 mMode[url=]Mode changed to Confirm_Landing[/url]
M09m 40s477.7 m29 mMode[url=]Mode changed to WiFi_Reconnect[/url]
N09m 40s477.6 m28 mMode[url=]Mode changed to Confirm_Landing[/url]
O09m 42s477.0 m26 mData Loss[url=]Downlink data connection lost for 1 seconds[/url]
P09m 42s477.0 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
Q09m 44s476.3 m26 mData Loss[url=]Downlink data connection lost for 1.3 seconds[/url]
R10m 00s471.0 m26 mData Loss[url=]Downlink data connection lost for 16.1 seconds[/url]
S10m 00s471.0 m26 mWarning[url=]Warning__The remaining battery is only enough for RTH. Return home now.[/url]
T10m 00s471.0 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
U10m 01s470.8 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
V10m 01s470.7 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
W10m 02s470.5 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
X10m 02s470.5 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
Y10m 02s470.3 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
Z10m 03s470.1 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
a10m 04s470.0 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
b10m 04s469.8 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
c10m 05s469.7 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
d10m 06s469.6 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
e10m 06s469.5 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
f10m 06s469.5 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
g10m 09s468.5 m26 mData Loss[url=]Downlink data connection lost for 2.5 seconds[/url]
h10m 09s468.5 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
i10m 11s467.7 m26 mData Loss[url=]Downlink data connection lost for 1.3 seconds[/url]
j10m 24s463.7 m26 mData Loss[url=]Downlink data connection lost for 13.6 seconds[/url]
k10m 27s462.9 m26 mData Loss[url=]Downlink data connection lost for 3.1 seconds[/url]
l10m 30s462.2 m26 mData Loss[url=]Downlink data connection lost for 2.1 seconds[/url]
m10m 30s462.2 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
n10m 32s461.4 m26 mData Loss[url=]Downlink data connection lost for 2.5 seconds[/url]
o10m 32s461.4 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
p10m 36s460.2 m26 mData Loss[url=]Downlink data connection lost for 3.4 seconds[/url]
q10m 47s456.8 m26 mData Loss[url=]Downlink data connection lost for 10.6 seconds[/url]
r10m 47s456.6 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
s10m 48s456.5 m26 mWarning[url=]Warning__The remaining battery is only enough for RTH. Return home now.[/url]
t10m 50s455.9 m26 mData Loss[url=]Downlink data connection lost for 1.1 seconds[/url]
u10m 50s455.9 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
v10m 53s455.1 m26 mData Loss[url=]Downlink data connection lost for 2.8 seconds[/url]
w11m 08s450.3 m26 mData Loss[url=]Downlink data connection lost for 15.2 seconds[/url]
x11m 08s450.3 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
y11m 08s450.3 m26 mWarning[url=]Warning__The remaining battery is only enough for RTH. Return home now.[/url]
11m 09s450.1 m26 m
[url=]10% Battery[/url]
z11m 11s449.5 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
A11m 11s449.3 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
B11m 14s448.4 m26 mWarning[url=]Landing Failed[/url]
C11m 18s447.0 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
D11m 18s446.9 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
E11m 26s444.5 m26 mData Loss[url=]Downlink data connection lost for 2.8 seconds[/url]
F11m 26s444.5 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
G11m 33s442.2 m26 mData Loss[url=]Downlink data connection lost for 6.1 seconds[/url]
H11m 35s441.5 m26 mData Loss[url=]Downlink data connection lost for 1 seconds[/url]
I11m 37s440.9 m26 mData Loss[url=]Downlink data connection lost for 2.2 seconds[/url]
J11m 37s440.9 m26 mWarning[url=]Warning__The remaining battery is only enough for RTH. Return home now.[/url]
K11m 37s440.8 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
L11m 38s440.6 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
M11m 40s440.1 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
N11m 41s439.6 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
O11m 42s439.3 m26 mWarning[url=]Cannot enter the selected flight mode. Try again later.[/url]
P11m 42s439.1 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
Q11m 43s438.6 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
R11m 44s438.4 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
S11m 46s437.7 m26 mData Loss[url=]Downlink data connection lost for 1.8 seconds[/url]
T11m 46s437.7 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
U11m 47s437.2 m26 mData Loss[url=]Downlink data connection lost for 1 seconds[/url]
V11m 58s433.8 m26 mData Loss[url=]Downlink data connection lost for 7.7 seconds[/url]
W11m 58s433.8 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
X11m 58s433.8 m26 mWarning[url=]Warning__The remaining battery is only enough for RTH. Return home now.[/url]
Y12m 01s433.0 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
Z12m 01s432.8 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
a12m 07s431.3 m26 mTip[url=]Critically Low Voltage Warning__Land as soon as possible, or battery will be damaged.[/url]
b12m 09s430.7 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
c12m 09s430.6 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
d12m 11s430.2 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
e12m 12s429.9 m26 mData Loss[url=]Downlink data connection lost for 1 seconds[/url]
f12m 12s429.8 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
g12m 13s429.5 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
h12m 15s429.0 m26 mMode[url=]Mode changed to Confirm_Landing[/url]
i12m 16s428.5 m26 mMode[url=]Mode changed to WiFi_Reconnect[/url]
j12m 20s427.2 m26 mData Loss[url=]Downlink data connection lost for 3.7 seconds[/url]
2017-9-16
Flight distance : 10186312 ft
Looks very strange, can you upload log to link below, just click on link and follow instructions this log may give some more information.
http://www.phantomhelp.com/LogViewer/Upload/
2017-9-16
Koppo
Croatia
hallmark007 Posted at 2017-9-16 08:49
Here you go... I don't know, it all looks very odd
- link removedSeems its a spark error ??? Would be great if some DJI employee takes a look at this!
2017-9-16
Koppo Posted at 2017-9-16 08:59
http://www.phantomhelp.com/LogViewer/MV4WJOCII6YMIEX933L0/
First it got to 475 metres because you were pushing up on the throttle, it was then that it seemed to gradually increase height after first RTH kicked in.
I think what might have occurred is VPS was showing height at 1.5 metre it may well have locked on some clouds, from there it tried to climb to whatever RTH height you had set and then descend but you kept moving sticks which can result in stopping RTH it was doing its best to land but I'm thinking it thought it could land on a cloud so this had the effect of continually halting RTH until it ran out of battery and fell from the sky.
You should sync your flight to dji cloud and get their analyses .
While cloud seems low it's probably not quite as low as you imaging. Climbing to 475 metres is not a very wise thing to do, you are very clearly in manned airspace plus you have no VLOS , putting other aircraft in danger is not acceptable and will not help drone flying.
2017-9-16
Koppo
Croatia
Thanks for the info. The only aircraft that flies here are above 25000ft so I doubt I put other aircrafts in danger. BTW I am totally sane and I don't need such common sense advices.. I would not fly if there are other aircrafts around.. I mean, I am not an idiot thus I dont like to be treated like one.
2017-9-16
Kloo Gee
Flight distance : 16783757 ft
My guess is that the Vision system couldn't see through the moisture/particle content of the cloud and assumed it was a solid surface and thus thought it was on the ground.  I can see very easily how this would happen.  Not a very common scenario I would think.  However, we did have a really big fog come through the other morning and hang around for a few hours.  I actually thought about trying to fly in it, but after your experience, I'm glad I didn't!
That is amazing that your Spark survived a fall like that onto a solid surface!  I know everything seems to be working now, but I'd personally recommend taking baby steps over your next few flights to make sure that things are definitely working 100%.
2017-9-16
Koppo Posted at 2017-9-16 09:33
Well i think you will find that flying above 120 metres is illegal in your country, also I'm confused if you could not see above the clouds how did you know for certain there were no low flying aircraft I'm sure that they have helicopters and small aircraft using airspace in Croatia.
Nobody called you an idiot, and if it's common sense then maybe you should use it.
2017-9-16
ernieken
Flight distance : 547641 ft
I don't think you should fly over places where some kind of risk exists when the drone comes down (buildings, people, ..). Personally, I'll never do that. I and other drone users don't like to be in the newspaper with the message that the spark has hit somebody. And from that heigth, it might be lethal.
I'm not saying you're an idiot but please be more carefull before starting your next flight.
2017-9-16
Oracle Miata
Flight distance : 3759829 ft
You are not helping the hobby at all.  This is ignoring the rules.  Period.
2017-9-16
Koppo
Croatia
Kloo Ge will do so. I am still sceptical that the drone works flawless after that impact.
Hallmark, I live here. And I really doubt that someone will fly on VFR between mountains when there is 0 visibility. No helicopters here either, not in this conditions. Maybe we have other understandings what common sense means.
2017-9-16
Koppo
Croatia
Oracle miata, my opinion about government rules is not the topic here, hence I will kindly ignore your post.
2017-9-16
Koppo
Croatia
ernieken Posted at 2017-9-16 09:57
Ernieken, I wont do that again. Thats for sure! Lesson learned. But no matter if 150 or 500m, kinetical energy is the same. I lost my confidence into the Spark.
2017-9-16
HomePoint
Flight distance : 776007 ft
Koppo Posted at 2017-9-16 10:00
This says it all:  "And I really doubt that someone will fly on VFR between mountains"
You doubt, so you do not know for sure.  You said it yourself.  If you break rules and come on here highlighting so, then expect what comes at you and do not take offence.
2017-9-16
Anuvis
Flight distance : 1976736 ft
I have seen this altitube errors several times in app.When climbing in 100 meters ,height shows 5,13,50,23 ....When stop iclimbing it stops in right values...Its a bug...
2017-9-16
Lian82
Flight distance : 796775 ft
read the manual.
DJI speaks very clear in the clouds and fog ... not fly inside is not recommended !!
beginner's mistake. I'm sorry, I lost 1 hour to read it all ... and still I do not know the spark potential yet.
fly to 500mt? yes, but with cloudless sky ...
good luck for your next flights!
2017-9-16
Wachtberger
Flight distance : 261509 ft
Dear all, can you please explain to me why we are discussing a case where somebody has not only intentionally breached all European laws concerning the flying of drones, has put other people at serious risk,  confirming just all the prejudices we have to continuously struggle against, lying to us about air traffic in his area which is anyway not his business to control or oversee, going out of RC range with the Spark if he has been in CE mode and then complaining that the Altitude meter was not working properly and requesting our time to answer this question?
What comes next would be my only question...
2017-9-16
ImHereToCrash
Flight distance : 5381368 ft
hallmark007 Posted at 2017-9-16 09:53
its a common sense thing.  out where my farm is lot of helicopters (medical/emergency) that fly a specific paths and routes, and most small planes fly similar paths..  but they almost always crossing  several miles over to the  east/south east and south..  so it is possible to know where they are and will more then likely be going.   doesn't mean they wont or can't cut across and cause issues, but not impossible to study it..and feel comfortable taking a small drone up for 10 minutes with "limited risk"   if its like 30 minutes up there then i would side with the more shouty people.  but spark isn't going to be staying up there for very long...
2017-9-16
ImHereToCrash
Kloo Gee Posted at 2017-9-16 09:50
i agree! it is the VPS kicking in causing the spark to "panic"  once the VPS kicks it it usually 'correcting" the altimeter as well..  meaning you wont have a clean reading in such cases.
i cannot remember for life of me if the spark allows you to turn off the VPS/downfiring sensors or not..  i know it doesn't have landing protection so it can't distinguish a cloud from the ground like the mavic has...   would be stupid if DJI didn't give the spark a toggle to disable VPS/downfiring sensor..  not like the spark has ultrasonic sensor to test if cloud if ground or not..
2017-9-16
fans9ea9c44f
Flight distance : 22129 ft
Just wondering if we can draw any conclusions for our benfit. If altitude reading suddenly goes to zero, is this because visual control has been automatically invoked?
If so the ability to turn it off might be a life saver. Since gps is still in control, (since no atti indication registered), one could then descend as required.Might be useful in other scenarios.To prove this, all one needs to do is fly at say 35 ft over a 25 ft building and watch the height reading.
Just an idea.
2017-9-16
Wachtberger
ImHereToCrash Posted at 2017-9-16 12:57
That cannot be the point. In the US you probably have no idea (and very likely can't, unless you would read European newspapers or watch European TV) how hard times are getting for us drone pilots here. We have got a really negative image because of few insane persons who have decided that no laws or regulations apply to them. And the guy at stake reports himself that he realised that his Spark was falling down from high altitude and with high speed in a densely populated area (see post #1) and he has intentionally taken that risk. There is nothing more to say in my opinion.
2017-9-16
SuperCurro
Flight distance : 2357828 ft
I had similar problem one day with light fog (not inside a cloud). When the sensor gets wet start to fail. If it is completely wet it marks 0 and you cannot go down. So, the first opportunity I had I returned home. Never fly with fog, even very light fog.
It is incredible that the dron supports that fall, I imagine the propeller guard were installed.
2017-9-16
ImHereToCrash
Wachtberger Posted at 2017-9-16 13:12
true, you are correct.  but i also feel like that shouldn't make the good people who are mindful be pushed away either..  idiots will be idiots, regardless..    sadly restricting drone pilots only does one thing.... limits good people, and allows idiots full freedom to be idiots and make it harder for us.
that's why i dont listen to limitations and restrictions and listen to common sense and common knowledge..  meaning obviously not going to fly over as hospital with helipad or push my aircraft up into path of a plane or anything..  and ill stay away from airports and military zones..  but blanket limitations are stupid if you know what you are doing..
its like the gun debate we sometimes have in the US and the media..  reality is, i carry a gun, i have a permit for consealed carry, i hate politics and all of that, im idependant on that matter, but its same logic, if gun laws got too strict too tough then that hurts good people like me and others that carry or have home defense..  and doesnt slow down people that are already out for bad, not like they are legally purchasing a gun anytime soon to commit crimes..  not like requiring us to have training with our guns, that gangs on the street any better or worse off.. etc etc..  so blanket limitations and requirments do litterally nothing to help anyone....idiots will be idiots reguardless
2017-9-16
fans9ea9c44f Posted at 2017-9-16 13:04
Just an idea.
I agree I think for many reasons option to disable VPS would make life a lot easier, I have thought about this and why we are blocked from doing this and my only conclusion is because of palm launch if you forget to turn back on you may have a lot of problems.
2017-9-16
ImHereToCrash
hallmark007 Posted at 2017-9-16 13:39
ah, i was struggling to remember if it is option or not.. so stupid you cant..  almost like dji wants people to crash..
if the spark has mini ultrasonic sensor then no option to turn off vps is ok..  because ultrasonic will see nothing there and stop it from being stupid..  like dji half assed it.. no ultrasonic and no way to disable vps..rip
2017-9-16
fans9ea9c44f
I agree, but even notifcation that the a/c had switched  to vps would be useful. All such  info for the pilot would be constructive. Maybe in fog it tries to climb a bit as altitude is zero, but continues to read zero even though it expects to have gained height. No wonder it gets confused.
Of course you should not fly in these conditions, but if this is the explanation undulating terrain might produce a similar situation.
2017-9-16
ImHereToCrash
fans9ea9c44f Posted at 2017-9-16 13:59
ya its stupid.. technically is a indicator VPS is used, but its tiny and easy to miss at the bottom of the screen..  need to be a popup saying potential issue and ask to disable VPS for you.
on my mavic pro i can disable VPS all together or just disable landing protection (i think is the ultrasonic sensors)
i think the spark needs a "pro mode"  just unlocks certain features, like disabling VPS and other stupid things DJi left out..
2017-9-16
Oracle Miata
ImHereToCrash Posted at 2017-9-16 13:26
Disagree with this entire post.  You are representing the entire drone community when you fly.   Act accordingly.  I don't even want to get into cowboys that need guns to feel safe...  but it's a free country so... your choice.
2017-9-16
Wachtberger
Legacy0ne Posted at 2017-9-16 14:31
"Koppo Posted:
Thank you Legacy0ne!
2017-9-16
fans9ea9c44f
Well I'm thankful to know there's a vps indicator on screen - I know I probably would have found out if I read instructions
2017-9-16
fans9ea9c44f
Also as an aside I saw a chap flying a phantom on the pavement of a 60 mph road here the other day. I don't suppose anything I could have said would have been the slightest use.
2017-9-16
ImHereToCrash
Oracle Miata Posted at 2017-9-16 14:25
so i am the entire representation as a whole of a community of potentially millions??   interesting logic you got there.  i behave myself but i do not obey blanket limitations and will never obey them.  i know how to fly, i use common sense, i have no intentions of causing harm to others...
this maybe the wrong thread to post my opinion on this since the OP did fly dangerously in an area if it crashed way it did it could have caused even more damage than it did..  but my opinion stands that with common sense and common knowledge you should be nannied into idiot level.. but my intial point was that he understood and studied flights around him.. not that he was right or wrong in what he did, (i agree he was wrong)
as for carrying a gun to feel safe, not at all why i carry, i carry for other people who maybe helpless in given situations that require deadly force.  the police take an average of 9 minutes to respond in america..  9 minutes is an eternity give the situations that require use of deadly force.  i have never had to use it, and i hope i never have to, but just incase, it is always with me..
2017-9-16
Oracle Miata
Two things...
1.  Common sense dictates that you follow rules set by the powers that be. Blanket rules or not.
2.  Everything in your post dictates that you carry a gun to feel safe.  Bottom line.
2017-9-16
OneMatt
Flight distance : 155984 ft
Altimiter is a barometric sensor. Air pressure in clouds can be dynamic, resulting in inaccurate readings. Hence, dont do it, per the manual.
Also, OP is a fool. There is a thing aircraft have called instruments. It allows them to fly without seeing. Commonly known as IFR. You dont have common sense, or any sense. Just foolishness.
Do us all a favor, sell the Spark. Take up knitting.
2017-9-16
OneMatt
ImHereToCrash Posted at 2017-9-16 14:51
One fool with a gun decides to shoot an intruder in his home, turns out to he his son sneaking home late. Congrats, y'all got painted with the same stupid brush. So, yes, you do represent a community.
One turd decided to spy on his sunbathing neighbour, now we are all pervs with cameras and have rules created accordingly. Yes, you do represent the community.
Of course, you may be better than either example, but those are the colours by which the general public paint us, no matter how sane you are.
As for common sense in flying: unpopulated area, clearly visible, decide to go to 200m when the law says 100m? Well, you can see there is nobody around so that is good sense.
Flying into cloud over a populated area is senseless.
2017-9-16
Dji Community A
OneMatt Posted at 2017-9-16 16:28
i'll Agree to Disagree...  horrible examples by the way.
but ill change my Name here to better reflect what is being said
2017-9-16
Dji Community
OneMatt Posted at 2017-9-16 16:23
i dont think the baro was the cause, i think it was the VPS.   i understand your logic but VPS "corrects" readings if it is triggered, clouds and dense fog can trigger VPS...  the spark has no protection or redundancies to know for certain.
im not a cloud expert, but i have flown my mavic in come clouds a few times myself didn't have any issues, but that was with mavic pro not spark, i would be more cautious about skimming clouds in a spark for sure.
2017-9-16
RoyTeo
Flight distance : 45194 ft
Hmm..flying almost 400m, over populated areas, seeing clouds and still trying to climb and posting on the official forum, and still flying after a 400m drop...
I might be the only one but none of those seemed right to me.
In any case, clouds will cause the sensor to think you're at 0m altitude. The clouds will seem like ground to the sensor..it's all mentioned in forums and even dji says not to do so..
2017-9-16
Dji Community
RoyTeo Posted at 2017-9-16 17:20
ya i think everyone agrees what he did is stupid and a shame.   he did only one smart thing that was study the flight patterns over his area before putting his spark up in danger.
if he did that over an empty park during a time when no one will be walking over.. then that's "okay"  i'm ok with that.  assuming he made sure no possibility he was going to fly in path of any other aircraft and only person he will possibly hit was himself..
like i'm getting crap here right now, but i wouldn't go skim a cloud in a spark unless i could disable VPS...  even then i wouldn't go skimming clouds over populated areas, it would be at my farm or something equally remote.. i have skimmed clouds in my mavic, but i never did that over people or over vehicals.. i did it over an off limits area with underground mine fires... called centralia..
2017-9-16
fansa7dc5944
Flight distance : 50988 ft
One thing that I have learned from Spark is if the bottom sensor detects something very very close to it, it will initiate Palm Landing though you have not start Palm Launch nor enable Advance Geature. You may make a test. I have not test with other DJI model.
2017-9-16
fansa7dc5944
You all should not complain OP. He is just one among hundred thousands who buy Spark and DJI should be well aware about this. So, DJI should not build Spark to fly higher than 30 m. and further than 50 m. radius to make it safe in hand of most people like OP, ordinary people with average skill. Sell high capability aircraft only to people with licence only.
2017-9-16
123Next >
