brent.browningh
On the fourth flight of my DJI Inspire 1, I went to connect my Samsung S5 to the controller just like I had done previously. This time, however, the DJI Pilot App just shows "Disconnected" at the top center of the screen. It looks the same way if you enable your DJI Pilot app without any conenction to the controller.
Maybe something was wrong with my DJI Pilot App? I uninstalled, reinstalled and tried again. Same result.
Maybe my phone needs to restart? Rebooted phone, tried again, same result.
Maybe USB debugging got turned off somehow? Nope. Toggled it and tried again. Same result.
Maybe it's my S5? Tried with my iPad Air 2 using the latest DJI Pilot App from the AppStore. Same result.
Maybe it just needs an iPhone to love on? Tried it with borrowed iPhone. Same result.
Maybe I need to try a firmware update? Copied latest DJI firmware to formatted (FAT32) SD card. Placed it in reader and put on controller. Nothing happens other than the controller powering on and showing one red dot on left and 4 white dots to right (same dispaly as when the Inpsire 1 is off but the controller is on). Left it this way for well over 10 minutes. No change.
Maybe my SD card or card reader is bad? Tried with two different USB sticks...same resutls.
Got on chat with DJI support. They had me redo some of the above...same results. Asked me to send an email into DJI support with details...which I've done and I am now in the back-and-forth with DJI support to try and resolve. Thought I would ask the community for some help now via this post.
My thoughts: the USB port/controller on the Inspire controller has gone "bad". I can still use the controller to cycle the landing gear, power up the rotors, and even took it up for a few batteries worth of manual flying with no Pilot App attached. Still flies great. It will still activate and control the onboard camera and all seems great except that it won't attached to DJI Pilot App.
I'm tempted to crack open the controller and see if something has just become disconnected internally given how it went from working to non-working without any other changes in between. I also noticed that my S5 receives a charging current from the controller when it's plugged in via USB...still no communication to DJI Pilot App but it does make the S5 chirp and enter charging mode.
Anyone else having this issue and possibly now of a fix or next steps to try? Overall, the rest of the Inspire 1 experience has been great.
Thanks!
-brent
