Flight distance : 10186312 ft
I think it’s pretty accurate to say your problem is your compass. What can you do.
You could go to completely different area environment and test to see if you are having the same problems.
If they still exist you could try calibration in a completely safe environment follow instructions from your manual NO CFIXER , if after doing this you still have same symptoms, you will almost certainly have to return to dji.
Continually calibrating is a not a great idea whether this was the cause of your problems I cannot say for certain and added to that using cfixer to demagnetize is very strange, I have never heard of this before but I think it would be a good idea to scrap this, you have 2 other drones you say they are fine my advice is if these are fine don’t be calibrating them and don’t use CFIXER on them they don’t need anything doing to them.
It’s a pity that still so many advise others to calibrate when there is no need and this can be the most detrimental thing to happen to your drone if done incorrectly.
Again I’m not saying this is what happened because I have no way of knowing for certain, so try what I said and if it’s no better send it to dji, because this looks like an accident waiting to happen.
Let us know how you get on. |
