nig_smith
Hi Carl
When you swapped the flight controller over did you update it, via the flight assistant software, with the proper profile and receiver type?
Eg. Quad X, Quad +, Hexacopter, etc... And receiver type: Traditional, D-Bus, PPM.
If you haven't already done so it might be worth connecting up to the Flight Assistant software and check that it is responding correctly to the inputs from the transmitter. This can be done in the "Basic" section under the"RC" tab. If you make any alterations in this section you need to reboot your multirotor for the changes to take affect.
Regards
Nidge |
