DJI Gamora
vigil314 Posted at 9-10 20:26
Hi Folks, I’ve just updated the firmware on my mini 4 pro yesterday.
Today I fly a little with the drone and noticed that after the update it’s not landing properly. It starts jumping around as soon as it’s touches the ground, moving approx 1m in diameter and it won’t stop the motors. Therefore it recently crashed into a nearby obstacle damaging the propellers. While flying everything is fine, smooth and stable. No oscillation.
Anyone has a suggestion? Ive calibrated the IMU twice, without success
Hi there,
Thank You for reaching out. We are truly sorry for the inconvenience you are experiencing. Please follow the troubleshooting steps below;
1. Please check whether the remote controller’s control stick mode and the control stick operation are correct. If the control stick mode is Mode 2, push the left control stick downward to land.
2. Calibrate the remote controller and ensure that the remote controller’s control stick can respond normally.
3.3. Check whether the landing ground meets the conditions (for example, whether the ground is flat, whether there is a water surface). For drones with a landing protection function, when the Downward Vision System works and the ground does not meet the landing conditions, the aircraft will hover and wait for the user’s further operation.
4. Could you confirm the flight environment and avoid flying through clouds or in a heavy fog environment, which will affect the Downward Vision System.
5. Check whether there are payload under the aircraft which may affect the Downward Vision System.
If the issue persists after the above troubleshooting methods have been tried, please provide flight records for further confirmation. We are looking forward to your response for further assistance. Thank You |
