New DJI Mini 4 Pro Firmware Released (11/23/2024)
89489 446 2023-9-25
Red_Dot
Flight distance : 760125 ft
Philippines
DJI Diana Posted at 11-26 23:53
Hi there,
thank you for reaching out.
Hi Diana,
I'm sorry, wrong information. It was not dronie, but the rocket quickshot mode. as it goes down, the gimbal suddenly tilted up while it's going down.
I have not recorded it or screen recorded it since I am not into screen recording.
But I will do it again with screen record on. and I will give you the update.
Regards,
GTL
2024-11-27
Red_Dot
Philippines
Hi there,
Hi Diana,  I sent you a link via PM.
2024-11-27
SeenMavic
Banned
Flight distance : 6177746 ft
2024-11-29
Serg SSA
Flight distance : 13283327 ft
Russia
SeenMavic Posted at 11-29 05:27
I always like when DJI releases a new firmware that fixes "known issues" but it is totally unclear, what issues... e.g. blocking DJI Plus batteries from use in Europe because of C0 (they did already block third market batteries).
DJI, give us more info, please!
They should write "Added new errors" )
2024-11-29
Red_Dot
Philippines
Hi there,
Hi Diana,
I figured something out. As I tested again regarding the Rocket shot, the gimbal tilts up while descending after the shot. If I will track a human size subject, it will show the issue. But when you track it on the ground, it will never show up the issue.
I guess this is something to do with the tracking feature. as it cannot track human size above 15m-ish height. I hope you can relay this to your devs.
Thank you very much.
Regards,
GTL
2024-12-5
fanscb0a559a
Flight distance : 21650 ft
we need capability to enable RID for standard batteries!
1-7 17:21
Marcello57
Good morning, why are the non-DJI 3850mAh batteries not recognized on the mini 4 after this latest update? Before this update the drone didn't have any problems, let me start by saying that I have the C1 and not the C0, so in addition to the height of 120m unlocked, the weight should also be unlocked with the possibility of mounting a larger battery.
1-9 03:10
