Aircraft totally unstable and aggressive after recent firmware up...
Crazyant
Flight distance : 852392 ft
Cyprus
Duchunter Posted at 2017-7-23 11:47
I just got a replacement refurb p4. I did not update it or the controller. It has the firmware that came on it. It flies beautifully. Is that what you are saying you want?
If u got the previous firmware then yes. Pls post the file.
2017-7-23
Duchunter
Crazyant Posted at 2017-7-23 11:53
Ok, I will. Give me a little while to do it. I have to use my wifes laptop. Mine is running linux so I cant do it with mine. As soon as she gets done using hers Ill install DUMLdore and pull the firmware off of it.
2017-7-23
Duchunter
How do I get the firmware off the controller, the same way I do the MC? From what I understand the tweaking out is coming from the controller firmware. Somebody posted that they updated their controller but not their MC and they were experiencing tweaker mode after that. So I imagine a controller rollback is necessary as well.
2017-7-23
Icer
Flight distance : 431079 ft
Latvia
Hi,
Yes! exactly! Please, make your firmware backup by using tool that i link before (https://mega.nz/#!nJcAUICR!3OWhm ... zpovIqo_6In3VnHXu5M).
Download tool and extract it in some folder. Then connect your P4 to PC. Start file "DUMLdore.exe" . Then select "aircraft" and press button "backup firmware". Backup is very fast 1-2 min.
In folder you will see new file "dji_system.bin". Please share this file to be able download it. Then i will get it, i flash my P4 drone with it and write feedback is it all ok. If all is great, i will share you file together with flash utility to give possibility for EVERY ONE to downgrade his P4 to well worked firmware. Thank you.
2017-7-23
Icer
Latvia
Duchunter Posted at 2017-7-23 12:04
Hi,
RC controller is fine with last firmware. I have not issue. Anyway you can always downgrade your controller by using GO4.
2017-7-23
Duchunter
Icer Posted at 2017-7-23 12:11
Hi,
OK, ive got the file but it wont let me upload it here. Where should I upload it?
2017-7-23
Icer
Latvia
Upload it in any file sharing server and please give link to download. For example www.mega.nz file sharing server.
2017-7-23
Icer
Latvia
Duchunter Posted at 2017-7-23 12:44
Hi, that is the status of upload?
Thanks.
2017-7-23
Duchunter
Icer Posted at 2017-7-23 13:27
Thanks.
Unmolested firmware: https://mega.nz/#!FjZDyJbJ!Vpoae ... PXvgBbIDZwPQQrUSMhg
2017-7-23
Irate Retro
Note that in order to use that DUMLdore.exe utility, you must have Assistant 2 installed because of the COM port drivers it provides.  Worked fine for me on Win 7 64bit after I took care of that step.
2017-7-23
Duchunter
Look DJI, you see how easy that was! You could have done that 2 weeks ago but no, we have to count on other people to make a rollback possible.
2017-7-23
Icer
Latvia
Duchunter Posted at 2017-7-23 13:44
Unmolested firmware: https://mega.nz/#!FjZDyJbJ!VpoaeVAswq7seId3N_JOc1XpPXvgBbIDZwPQQrUSMhg
Thank you very much!
I will flash it on my drone, test it and give feedback.
Please cud you check one more thing: then you connect you drone to assistant2 (last version) and start calibrate VPS cameras, - calibrate is success? (do you see that small cameras working?)
Thank you.
2017-7-23
Duchunter
Icer Posted at 2017-7-23 14:01
To be honest, im terrified to do that. I dont trust assistant 2 and right now its working better than my old p4 ever thought about working. The senors are all showing correct information. Im afraid if I calibrate it I may loose that. Surly I cant calibrate the vps as well as it is from the factory.
2017-7-23
Icer
Latvia
Duchunter Posted at 2017-7-23 14:11
Yes, i understand you. It is OK. I also at this time not trust DJI.
Before 2 days i spoke with support and they was wondering that somebody (Natalia) promise some beta.
They says that DJI not have any info about any beta for P4 and they have not any plans to do new FW for P4.
That RC fw version you have now (1.6, or 1,8)?
Thanks.
2017-7-23
Duchunter
This is what's on my equipment.
2017-7-23
Duchunter
Icer Posted at 2017-7-23 14:21
I tried to backup the rc firmware as well but the app didnt see it. It could be that ive never used assistant to update my controller. I did use assistant 2 to update my old MC so the drivers were definitly installed for that. If anybody needs it ill see if I can make it work.
2017-7-23
fans0e00ebfc
Flight distance : 477851 ft
Alright, so thanks to Duchunter we have the WANTED FIRMWARE. Just some questions: Is this firmware Duchunter provided good for every version of Phantom 4 AC? I got the basic. How the hell you put the firmware back in the aircraft? I don't think DJI ASSISTANT 2 is letting us do it or yes? I own macs so I have no WINDOWS...Some light on to this topic would be SWEET.
THANKS DUCHUNTER.
2017-7-23
Jgrimmy
Flight distance : 90653 ft
Reflashed with the firmware provided in the link.  Flys great, no more warning messages about wind or resetting IMU.  The collision avoidance is not working, I tried to calibrate them in Assistant 2 and it can't seem to find the cameras.   The start calibration is grayed out and keeps asking me to reboot the aircraft.  The best part is it starts up and is ready to go in seconds!  I'd like to get the collision avoidance back though.  It says it is version V02.00.0106.
2017-7-23
Duchunter
fans0e00ebfc Posted at 2017-7-23 15:26
THANKS DUCHUNTER.
Your very welcome. As it stands right now you have to use the DUMLdore app to roll back. I dont believe that there is a Mac version. The files are small and can easily fit on a memory card. I downloaded DUMLdore with my Linux machine to a memory card and then unzipped them to a folder on my wifes Windows machine. So you can download the files and take the memory card to a friends or family members or even the library and do the rollback there. It literally only takes 2  minutes.
2017-7-23
Duchunter
On thing I should mention is that the video feed was a little sketchy so I took it off auto and locked it down on a green channel and its been flawless ever since so if the feed is not perfect just lock it on a good channel and you should be fine but the bird flew wonderfully. It was so smooth and responsive. It was like a huge weight had been lifted. It seems like the older the firmware the better they fly.
2017-7-23
Aardvark
Flight distance : 384432 ft
Jgrimmy Posted at 2017-7-23 15:42
Congratulations, you've just updated to the latest version of firmware. So is it latest version, or has it not rolled back correctly. Interesting times.
2017-7-23
fans0e00ebfc
Duchunter Posted at 2017-7-23 15:51
AWESOME JOB! I'll figure out a windows machine out there, but I'll have to install DJI ASSISTANT 2 (windows version) so that it takes the drivers too!
THANK YOU SO MUCH.
2017-7-23
blueDJ01
Flight distance : 407 ft
I updated the controller - the drone - reset to defaults everything.... I'm stable but definitely feel a change in all controls - some quicker some slower.
2017-7-23
Gablopez
Flight distance : 515679 ft
Reinstalled the firmware using Assistant, did the cold calibration of the IMU, VPS, compass, etc... still the same problem.
2017-7-23
Gablopez
Thank you Duchunter and Icer, I will flash my Phantom and post the results.
2017-7-23
Jgrimmy
Is there a method to downgrade the controller?  Its not recognizing the downgrade version and I think may have something to do with my front collision avoidance cameras not being recognized.
2017-7-23
Duchunter
I dont why the collision avoidance isnt working. Its definitely version 01.02.0602. You may have to use assistant 2 to take it back to factory first.
2017-7-23
Duchunter
I wonder if the rc firmware is causing the obstacle avoidance not to work?
2017-7-23
M109
New Zealand
After downgrading firmware does DJI GO4 warn you there is an upgrade to firmware available?
2017-7-23
Duchunter
Jgrimmy Posted at 2017-7-23 16:06
Yeah you can roll back the rc firmware. DUMLdore just didnt recognize my controller or I would have posted it. It may also help to reinstall the go4 app.
2017-7-23
M109
New Zealand
You only need to start the process to see if the cameras are working, once you see the screen with all the dots and you can move the AC to see it move on the screen, after that you can just unplug AC and it won't doing anything to your factory calibration
2017-7-23
fans0e00ebfc
M109 Posted at 2017-7-23 16:13
You may want to reinstall your GO App and restart aircraft and RC. Maybe that works for you.
2017-7-23
fans0e00ebfc
I see no downgrade file for P4's RC here... http://dji.retroroms.info/howto/firmware
2017-7-23
Duchunter
fans0e00ebfc Posted at 2017-7-23 16:26
Your not going to find it there. Ill see if I can pull 1.8.0 off of my new controller.
2017-7-23
Jgrimmy
No it doesn't.  When I go into About if GO4 it says aircraft version unknown.  Any tips on downgrading the controller?
2017-7-23
Irate Retro
Nevermind; misread the quoted post.
2017-7-23
fans0e00ebfc
Duchunter Posted at 2017-7-23 16:28
2017-7-23
fans026094f3
Flight distance : 54058 ft
Argentina
For that version installs the DJI GO 4 4.07 on IOS, on Android 4.06. You can also use the DJI GO 2.8 one of the best versions there was.
Use it in airplane mode. In android you can download the Firewall app, and prohibit the app from connecting to Big Brother DJI
2017-7-23
Duchunter
DJI assistant 2 doesnt recognize either one of my controllers. Clearly im doing something wrong. How do you hook the controller to the pc for update?
2017-7-23
Mugre
Argentina
Duchunter Posted at 2017-7-23 16:12
Calibrate the sensors with the Assistant without a network connection
2017-7-23
