Spark does not climb in Dronie mode
123Next >
8901 99 2017-6-24
Bertybassett
Flight distance : 2520 ft
https://www.youtube.com/attribution_link?a=Dnfs9VATbFCSV5yN&u=/watch%3Fv%3DkzxvHPYxRoI%26feature%3Dem-upload_owner
here is a good example of it not working or do I have my expectations wrong on how this works?
2017-7-6
Bertybassett
looking at the attitude on the screen it is rising but very slowly.  Maybe that is how it should work?
2017-7-6
ktula
Same issue here. Just got my combo package a few days ago. Spark does not climb in Dronie mode.
2017-7-6
quint7
Flight distance : 518455 ft
I've tried re-installing and getting the black box data, etc. But no luck. It's been going for 20 mins and no black box info yet.
I'm wondering if I should return mine as others are suggesting. Is it a FW issue or what? Circle works fine. Rocket works fine. But the helix and dronie don't work. Drony just goes straight back without going up. And Helix is like 100 yard helix. I don't know cause I have to cancel every time. I purchased mine through DJI store on Amazon. Should I return it? Or wait for a firmware update???
Q
2017-7-7
QHovey
Supong Posted at 2017-7-5 20:31
Well... Dronie works for me. It does fly backward and goes up high depending on the initial angle between Spark and Me.
See this.
Can you post which firmware version you are on?
2017-7-7
quint7
DJI Diana Posted at 2017-6-29 20:04
Please restart or re-install the DJI Assistant 2, then try it again. Normally, it does not take much time to export the black box data, but it may take longer to export the flight log.
Natalie/Diana:
Here is my black box file as requested. Dronie acts like everyone else is describing. It goes back without lifting at all., And Helix is like so huge you can't even tell it's a helix. I have to stop it. I have to stop both of them any time I try. I know how to adjust distance, but it doesn't do anything.
I'd like to know if I should return it or not. I purchased through the DJI store on Amazon.
https://www.dropbox.com/s/paooqb ... kboxExport.zip?dl=0
Quint
2017-7-7
GIdoc
yes... latest ios with iphone 6plus... just goes backwards forever.. doesn't climb.
2017-7-7
barryg
Same issue with Dronie here.  Using remote control- doesn't angle up as it goes back and seems to go back way too far... definitely a glitch in the firmware .  Also it would be great to be able to select the angle it assends and how far back it goes ...  Dronie is one of the things that I was really going to be using on my upcoming trip.  Hope it gets corrected quickly.
2017-7-7
GIdoc
Just contacted DJI.
2017-7-7
FineBrian224
Flight distance : 19902 ft
I see the same behavior with my dronie not climbing. However, my spark wont connect to my PC. issue with the drivers i am guessing.
2017-7-7
FineBrian224
FineBrian224 Posted at 2017-7-7 15:07
DJI Assistant now connects with PC reboot
2017-7-7
leaksguy
Flight distance : 253 ft
Just want to share that so far, at least in Dronie mode flying wifi with an iPad mini the drone does not climb and does not stop going away at the distance i tell it to.
thanks,
dave
2017-7-8
fans266080cd
Flight distance : 71759 ft
Any idea when the next firmware update will be out? I got the same dronie issue. Tried to download blackbox data using mac but failed...
2017-7-8
Mimus
Flight distance : 284770 ft
+1 on dronie issue.  Helix also has same issue . Does not stop at defined distance. iOS iPhone 6s
2017-7-8
Scotty S
Flight distance : 182884 ft
+1 - Picked up Spark yesterday. Updated to latest firmware. No climb with Dronie.
2017-7-9
DerOnkel82
Flight distance : 806470 ft
For me the Dronie works most of the time. It seems to require a minimum height of roughly 2 meters at the beginning to work fine. otherwise it doesn´t climb. Another thing is the distance setting for Dronie. it seems to ignore the settings and always does 40 meters and then stops. i´ve tried to set it to 60 meters but that doesn´t change anything.
2017-7-10
DJI Diana
Flight distance : 2408 ft
quint7 Posted at 2017-7-7 13:36
Natalie/Diana:
Thank you for your info, we've transferred it to our engineers, they are working on it now, will let you all know once we heard from them.
2017-7-10
jiri.stibor1-sp
same for me. Nearly crashed into a sign when I expected it would fly up...
2017-7-10
Jibers
Same here in the UK.  With iphone 6S+
2017-7-10
J.G
Flight distance : 172562 ft
Same here, dronie and helix not working using iPhone 6s Plus.
2017-7-12
FloodC
Flight distance : 190 ft
I'm getting the same. Dronie just flys straight back and also doesn't stop. I haven't tested how far it can go back incase something happens. Also helix doesn't work. Circle partially works and rocket works about 80% of the time.
2017-7-13
JT-SkyHigh
Flight distance : 319662 ft
I'm having the same issue, dronie flies backwards with very little altitude increase. Also when you set it to only go 10 metres is just keeps going and going. An update on when this might be fixed would be great!
2017-7-15
WiredGuy
Just wanted to add my 2cents, same issue as well. I get minimal altitude gain in dronie mode, the drone will lock on me and back up but gains extremely little altitude. It would also be great if the angle can be programmed in addition to the height.
2017-7-15
fanseda089b2
Flight distance : 39852 ft
Indonesia
Same here ... my spark crash to a tree becoz it does not gain altitude ...
any updates here?
thanks
2017-7-16
fans8146a2ad
Flight distance : 22411 ft
purchase 2 sets of the Spark combo and here are the issues
1. Dronie no climb
2. Helix not working correctly
3. Video lag
4. Not responsive when connected via wireless
Disappointed!
2017-7-16
LeChuck71
Flight distance : 68786 ft
fanseda089b2 Posted at 2017-7-16 17:58
any updates here?
thanks
Just out of curiosity:
If you see your Spark does not gain altitude why didn't you stop the "Dronie" and take over control instead of watching your craft fly into a tree?
2017-7-16
djiuser_OGfNeCQ
+1 - same issue - I tried a Dronie yesterday - I raised it up to clear some trees and hit go. It set off and slightly lost altitude so I stopped it before it hit the tree. I tried again in an open area and instead of stopping at 20m it kept going - I let it to see what happened (started to worry but the area was under my control). It reached the maximum distance (I don't have a controller) and just stopped instead of returning. I had to manually return it. Other than that, I haven't had many problems (no sudden drops etc...) . The only other problem I have is with connecting. I have to reset the wifi (hold down the power button until it beeps three times) before my Samsung Galaxy S6 will see the wifi signal from the drone.
2017-7-17
flashoser
Flight distance : 7972 ft
I am having the same issue, I finally got around to trying Drone Mode and it just went backwards, I had plenty of room, till a tree was coming close so i Stopped it...it is now July 17th and this started since June when they got shipped...mine was one of the first ones, Mine shipped June 14th... I wish i would have tried it sooner, and there still is no fix for this yet?
We have not heard from DJI on this in this group?
2017-7-17
flashoser
DJI Chat just stated to me today that they believe it's problem with the APP and to wait for an Update, I am on IOS iPhone 7+
2017-7-17
pingywon13
Flight distance : 63724 ft
flashoser Posted at 2017-7-17 08:32
yay! I cant wait
2017-7-17
Scotty S
Great.... so those of us on Android can expect a fix about Christmas time.....  considering the Android app doesn't have full functionality (gimbal tilt).
2017-7-17
Bluebus19
I am having the same issue; sparky is not gaining altitude while in performing a dronie
2017-7-18
fanse40ffd8b
Flight distance : 211946 ft
fans3c3673db Posted at 2017-6-27 18:16
After experiencing these same problems and noting a large percentage of responders on the forum have some sort of issue with Quickshot, why don't you guys just pull a couple Sparks off the shelf and go fly them yourselves and record your own fails.  I sent the Black Box folder zipped to tech support.  Your wanting something in Dropbox is totally foreign language to me...I go there and see nothing about building a link.  The problem in Quickshot is so prevalent you should be able to get the data yourselves!!!
Same here even backwork 100m away, so bad. You can see the  percentage on the recording button only 2% but other quick shot working fine.
2017-7-23
Nixtoo
Flight distance : 6562 ft
Mine doesn't climb or limit itself if you change the distance.
2017-7-23
fanse27ab49d
Flight distance : 46886 ft
Here's me crashing into a hedge while attempting the Dronie quick shot
https://www.skypixel.com/videos/crash-dronie-mode-quick-shot-first-attempt?utm_source=url&utm_medium=copied&utm_campaign=share
2017-7-24
fansb2aa3b28
Flight distance : 61033 ft
Singapore
IS DJI DOING ANYTHING TO RESOLVE THIS ISSUE ?
2017-7-24
Thor1
Flight distance : 196837 ft
fansb2aa3b28 Posted at 2017-7-24 09:08
apparently if you adjust the max distance to under 40 meters it then goes up. which in my opinion is not even close to enough distance for a dronie shot but worth a try?
2017-7-24
JT-SkyHigh
New firmware out today that will hopefully fix it!
2017-7-26
fans07aae7d8
Flight distance : 32516 ft
Well... I tried the dronie mode with the new firmwares & DJI GO 4 apps today in my backyard. It went up higher than the starting hight about 1.5m? but it didn't stop at the distance of 15m which I set. I have to try it again in a open space. But anyway, it seems it went up
2017-7-26
ronnbizzy
*Following this post*
I updated my spark today and it still doesn't climb on dronie mode, it also didn't stop at the 20m i set it to.
It's quite concerning to be honest.
Has anyone else had better luck post update?
2017-7-29
123Next >
