Mavic AIR vibration - shake - shaking - cavitating POSSIBLE SOLUTION
123Next >
8801 104 2018-2-5
maihem.rc
Flight distance : 2076335 ft
RepKK Posted at 2018-2-5 15:28
Here are two videos.  I put my Spark and Mavic Air outside in 22 degree weather (no batteries) for about 10 minutes.  So 10 degrees below freezing.  I then put batteries in and raise them up and see the difference.  I am going to agree with the cold drone theory for the Mavic AIR.  But why doesn’t it do same thing to the Spark?
Yeah, my MA does exactly what yours does in the video...when it's cold.  I sort of haven't been able to fly again between rain, the Superbowl, and the acquisition of an MP that someone was getting rid of for cheap.  Will try to fly the MA some more tonight.
2018-2-6
fansc460d8a2
Flight distance : 1472283 ft
Denmark
DJT_MVSP Posted at 2018-2-6 09:14
Spark's motors doesn't have any brakes..
While Mavic Air's motors have brakes: those vibrations you're seeing is just the motor quickly speeding up and braking constantly. Probably in cold conditions, the motors are slower to be detected and to react..
Have the same issues with shake and vibration - tried changing the gain settings for Roll and Pitch to 90% but still see the issue - after approx 30 sec. it seems to disappear, like the electronics has a comfort operating temperature.  (Outside temperature in Denmark -4dg celcius.)
2018-2-6
djiuser_VAjAMtRSIPs0
Did anyone had the issue when correctly warming up the drone for 1 minute ??
2018-2-6
Tadango
Flight distance : 232359 ft
I don't understand that it will take-off when it is not warmed-up. This warming-up is important to reduce gyro drift and overall stability. It is the one thing i like the best about the Naza-M, and the only reason i still use those. With the warming-up the performance is rock solid.
2018-2-6
Malzuko
Flight distance : 1961969 ft
I am also having the same issue - I am going to try warming up the unit first for a couple minutes before take off
2018-2-6
Acenspades
i live in Los Angeles,,,haven't had that problem,,,tho it never gets colder than 65 degrees so i'll report if i have that issue
2018-2-6
$gambino$
Flight distance : 1563980 ft
So mostly what we know is this happens in the cold...and is related to gain, imu... I don't know if it's related to so much the new ESC's user a few pist back DJT suggested brakes were the reason well guess what the mpp does not do this soooo....dont think thats it. All I know is something is up and ALL other dji aircraft do not do this. Yes the manual does State not the fly below 32 degrees Fahrenheit but all of my other DJI aircraft have been flown in way lower temperature
2018-2-6
$gambino$
For clarity on my post above mpp and mavic air have same esc's ....mpp does not do this in cold temps mavic air does. So "brake theory " is out the window
2018-2-6
Epyonz
Happens as the IMU is located differently in it's design compared to the spark or pro. The heat-sink is not near the IMU so it warms up slower. This is apparently better for the longevity for the unit. Regardless, it's int he manual to warm it up so it's an intended design that DJI is aware of I'm sure.
2018-2-6
exos
Flight distance : 425486 ft
Mine also does the same exact thing. I've flown today at -4C and same thing. I've even let the props turn for about 45 seconds before take-off.
2018-2-6
fansc460d8a2
Denmark
$gambino$ Posted at 2018-2-6 12:53
No shake in the promotion video - assume it was cold here too ;-)
2018-2-6
slyfox0
Flight distance : 118 ft
Mexico
Over at MavicPilots
“changing pitch and roll to 90 as was suggested in the link at the beginning of this topic. No more vibration for me.”
https://mavicpilots.com/threads/vibrating-motors-in-cold-temperature.34247/#post-400441
2018-2-6
Mark Blaide
Flight distance : 246014 ft
I hope one of the moderators forwarded this issue to their engineers for analysis. I believe a little feedback from the company can build strong customer relationships.
2018-2-6
fans6d0133cb
Flight distance : 400 ft
So does anyone have a conclusion on this issue? Is this ok in cold weather or should we be concerned? It seems the majority of people are having the same issue.
2018-2-6
$gambino$
So slyfox this worked for u? It does not happen anymore?
2018-2-6
RepKK
Flight distance : 58780 ft
Epyonz Posted at 2018-2-6 13:02
Ok... so the next question is this: If this is just how the Mavic AIR works and the units are NOT to be run in cold weather and it is just about allowing unit to warm up before flying... then why is everyone that opens up a issue report with DJI being told to send the unit back?  If we are all just not following the directions - why are they taking the units back when they just should be saying "don't do that and follow the written directions!"
2018-2-6
RepKK
fansc460d8a2 Posted at 2018-2-6 13:14
No shake in the promotion video - assume it was cold here too ;-) [view_image]
THIS IS AN EXCELLENT POINT!!!!!
2018-2-6
djiuser_6iP3cwXVxAgq
Similar initial vibration here in New England where it was in the 20's (F) here.  This is my first drone so I didn't think much of it.  It only lasted a few seconds and everything was fine afterwards.
2018-2-6
DJI Thor
Flight distance : 13602 ft
Hi there, for those who have the issue, could you please provide me with the flight data from the drone so I can forward to our engineers to confirm this? Please connect the drone to DJI Assistant 2 v1.2.2 and export the Flight Records and Sensing, upload to Dropbox and paste the link here. Thank you for your help.
2018-2-6
JayRaff
Flight distance : 11499 ft
SSFRIH Posted at 2018-2-5 17:22
It seems to be a IMU problem causing this but the manual said you should not fly in such cold but a Mavic Pro and Spark and Phantom 4 pro can with no problems. Why?
Hey, can you link where it says this in the manual? I'm having the same issues with the mavic air. Never had this issue with my spark or mavic pro.
2018-2-6
Tee
I did not notice any shaking before but after reading the post, I did a test in my house again. I took it off and let it hovered. The Air was not freezed but move a bit continuously (like rebalancing), not sure if it is normal in a small indoor room in which the drone is disrupted by the airflow it generated. Or it is the shaking problem you guys experienced too.
And yes the props with white mark can be moved a very bit if I hold the motor but it is tight and force is needed to move
2018-2-6
slyfox0
Can someone reply to DJI Thor with their flight log? I haven’t opened my Mavic Air yet.
2018-2-6
drown84
Flight distance : 176312 ft
DJI Thor Posted at 2018-2-6 18:28
Here is one of my logs that has this issue. Its about the first 30s of my flight or so.
https://1drv.ms/u/s!ArhBrHsy5VUwkULkcdf84o1bRcjp
So I have a replacement ticket open on this...considering it seems like all Mavic Airs are affected, im assuming there is not point in returning the drone for just this issue alone?
2018-2-6
WhiteLightning
Flight distance : 71791 ft
/de-lurk
Just wanted say I experience the same thing. I can normally just 'fly through' it. Meaning , get a touch of air, move around a bit then things seem to stabilize. I did try a second set of props and they def suffer less from this issue.
WL
\re-lurk
2018-2-6
slyfox0
I’m hesitating to open mine until this situation is clarified.
2018-2-6
Crazyant
Flight distance : 852392 ft
Switzerland
Thinking of canceling my order.  If this is due to cold weather, then why are all other DJI products dont have the same issue? On my P4 I have never experienced this.
2018-2-7
Cameleon
Flight distance : 60394 ft
I hadn't seen this on my MA, but up until I saw this thread yesterday I hadn't started the MA and taken off straight away. Doing a manual takeoff I haven't seen this phenomena but then its probably because the MA was warming up a bit first. Yesterday I did a test and turned the MA on and straight away did a auto takeoff  and just after it launched it did do the shake. I will try again when I have more time over the weekend perhaps and see if I can nail down what circumstances it happens in.
2018-2-7
Malzuko
I tested warming up the MA prior to flying and It worked. I experienced no shaking whatsoever.
- I let the MA internals warm up inside for a couple of minutes, I waited till I heard the higher RMP fan speed engage
- Turned it off and went outside
- Turned it back on and was able to fly immediately without the scary wobble
I am ok with doing this, and I havent tested letting the MA warm up while outside, I may try that today
2018-2-7
Single Lens
Flight distance : 55636 ft
Crazyant Posted at 2018-2-7 04:25
It's a bit forward to be thinking of this IMO. It's a drone that has just been released, only has one or two firmware updates, is still being worked on and no doubt will have an error or two.
The Mavic pro had an issues or two when it also came out, and they got fixed by DJI. Pretty sure the same will happen here with the Air, as DJI would  be risking too much loss if they didn't sort this out pretty quick. I'd say hold for now and see what happens. But of course, its your call
2018-2-7
Crazyant
Switzerland
Single Lens Posted at 2018-2-7 04:59
I agree, if this is an issue that can be fixed with a firmware update. If this is not a firmware fixable issue but more of a hardware issue, then it means that we would have to wait for the next production batch.
2018-2-7
Tadango
I will test mine as soon as possible (just delivered). It really sounds like an IMU / gain issue. Has anyone tried it with a lower gain? It currently is around 0c here so it should be testable. A lower gain could mean a slight reduction in power consumption also....
2018-2-7
AIister
Flight distance : 626647 ft
i remember when i had to put my p3p in the fridge for an hour then do an imu calibration soon after.  otherwise the drone would take a few minutes to warm up before being able to fly, agonizing when even a battery swap means waiting again.
i just did my first flight test indoors and hovered and learned to fly when the drone didn't want to move anywhere because of obstacles lol... i will try outdoors when the sun comes up , only -10c right now.
2018-2-7
Crazyant
Switzerland
Tadango Posted at 2018-2-7 05:56
Let us know buddy.
2018-2-7
fans6d0133cb
Is this issue a faulty batch or something that can be corrected via FW update? I only have a few more days for return.
2018-2-7
Surface2Air
Flight distance : 167441 ft
Here's my contribution, first flight (brief) with the Mavic Air which showed the issue.
https://www.dropbox.com/s/kg61l6 ... 7_10-26-06.DAT?dl=0
2018-2-7
iceman#1
Oh dear, this is bad news. I didn't counted the people having issues in here, but to me this thing seems like a common behavior in the cold.
It could be either software or hardware related. Maybe software, because the regulation of sending power to the motors is not calibrated. Hardware issue might be that the IM unit (IMU) is allergic against cold temperature. That would mean, the electronics are too cold to compute the right way. After they got warm, they are working fine. I'm very very scared that this can't be solved by firmware updates. This seems to be like a hardware flaw (let's hope I'm wrong).
Another video I saw is leading me to my assumptions:
here he flies in very cold weather. But if you know this youtuber, he knows how to deal with cold weather and is preparing his drones before flying in the cold. So basically he puts the batteries and drones in a warm place until the point he starts to fly. So when he was taking of, the drone and IMU was fine. But after some minutes of flying he got various IMU errors, so I think the drone cooled down too much.
So for me, the IMU is the one to blame, and this seems hardware related. Please proof me wrong.
Like already said, DJI lists their drones with operating temp of 0° up to 40°C. This would mean, we can't really blame them if the drone is acting weird outside that corridor. But for sure, I will return it if it's acting that way. Glad I bought the drone now to make sure it flies in low temperature. Imagine the drone would be released in summer and you'd need half a year to find out, there is such a flaw. So basically I'm happy to be able to test this.
2018-2-7
iceman#1
did anyone try to calibrate the IMU outside when being in the cold?
2018-2-7
Surface2Air
iceman#1 Posted at 2018-2-7 08:47
Ya. My first flight after I landed because of the 'wobbling' - the app asked me to calibrate something, I'm pretty sure it was the IMU calibration, but my memory could be amiss. And second take off didn't show the issue, but that could also possibly be attributed to the craft being warmed up at that point.
2018-2-7
$gambino$
I wonder if a cold imu calibration would solve this...like we did in our p3 and p4 days basically just let the aircraft sit outside in the cold for 20 minutes then bring it inside to the warm and calibrate it although I don't know if this will work worth a shot..... honestly I think it's more of a gain issue so you guys should be trying to lower it 10 or 20 points on the roll and Pitch axis..... I do also think this is software related and can be fixed in firmware
2018-2-7
fans6d0133cb
I hope you are right gambino. I'm concerned about this.
2018-2-7
123Next >
