paulsheaves
Hi All,
So, I have got the p3p back from the dealer. They gave me a new controller, and after one test flight it appears to have helped somewhat.
There were no disconnections, but the live feed to the ipad did scramble a lot towards the end of the flight - it would flash black and then slowly come back to me bit by bit from the top of the screen to the bottom inch by inch, and then go black again; this cycle repeated. I also found that the ipad was getting very very hot - however no warning of overheating messages came up.
I have tried to order the short Anker cable, but when i get to the check out on Amazon it says it cant deliver to the UK :-( So i went to the mall and bought the best i could find which unfortunately was only a 0.5m apple one. It's shorter than the one that comes with it, but not as good as the Anker. I did use that in the test so maybe it helped.
To help with the scrambling, I would like to set the live stream to the ipad to a crapper quality, does anyone know how i do that?
Also, do you think i should have hardware decode enabled or disabled? There is some debate on this for the ipad mini 2 which is what i use.
Many thanks for all your help,
Paul |
