I.Dan
![](https://forum44.djicdn.com/data/attachment/common/1c/common_35_usergroup_icon.png) New
So, very late reply, but people might still stumble onto this topic ever so often.
I haven't used my ronin-s for a year or so due to lack of events since covid, but recently started using it again and i had these jitters especially on the tilt axis. My solution was to reduce the motor stiffness, to under 20, on all axis. Ever since, my camera has been buttery smooth, except outside when the wind blows pretty hard, the lack of stiffness means the wind can push the camera quite a bit.
My setup is quite medium on the weight side, i have a nikon Z6 with a fixed 24mm and a Rode mic on top, so it seems like the high stiffness ( around 30-40 since auto-tune ) makes the micro adjustments too aggressive, so if the camera is tilted -1°, the motor will twist too hard and it would actually go to positive 1°, then it twists back and it ends up in -1° again, and so on, resulting in vibrations / jitters, or at least that's my theory. ( also, 1° of error is a lot, but it's just an example to explain my theory )
I haven't seen this in any posts so it might be something slightly different to try, but from a lot of reviews i've read, just don't use auto-tune |
