pc3
Still in 2021... have issues with update process.
Similar experience. Purchased Mavic Air 2 - supplied controller does not work with my phone (this should be much much clearer prior to purchase). Then purchased smart controller. Out of box, it wanted to update - that failed every time at 16%.
Followed DroneZoneDE's instructions using the PC app and got close.
Download will be very, very slow (not my connection, either)
Controller will shutdown at about 50-80% on the download because of no activity. So restart the device or press the power button to disrupt the auto shutdown.
btw, every restart of the update process has to redownload the image - even if download was previously successful. A simple hash check could confirm this step already completed rather than starting over on every failed attempt. Big time suck.
Transfer might be slow, too if coming through a USB2 port. Controller will signal power off due to inactivity, so distrupt it by pressing the power button.
Controller will also complain if power level too low to recharge the device, so ensure you start with a full battery.
btw, looked for sleep and auto shutdown setting on the controller and couldn't find it.
Update step (after the download and transfer steps) will get to about 75% before it restarts the controller. This isn't the auto shutdown, so leave it alone. ;)
At 99%, the PC app will complain that the update took too long and to restart the controller to see if it updated correctly. Check the controller screen first. If it is still updating, let it do its thing. It will restart twice. Then you can disconnect from PC and reconnect. Update should be successful.
After all that, finally had an updated controller.
If phone manufacturers can update Android without an external computer, the controller should be able to as well imho. Definitely need better update experience - and better instructions. |
