RAW Upgrade
12
7854 43 2019-6-13
AntDX316
Flight distance : 3394731 ft
GetHigh Posted at 7-21 16:36
Just like people "tweak" to get more performance out of their cars, some of us would like to achieve more from our existing Spark. A firmware upgrade is along the same idea. Don't replace the car...improve it.
I think it takes more processing power that the Spark does not have.
2019-7-21
AntDX316
I just think if the computer gets overloaded it will drop the drone out of the sky.
2019-7-21
GetHigh
Flight distance : 163619 ft
AntDX316 Posted at 7-21 17:59
I don't believe that is correct. It takes LESS processing power, to just keep the RAW file. By it giving us a .jpg image, it is processing the RAW file, it has already captured, then modifying it to what it believes is the correct white balance, dynamic range, toning, compressing it, etc.  If it just gives us the RAW file, it is merely giving us everything the sensor captured and letting us use the variables we desire. RAW is an unprocessed images.  It does take more storage room for the files. however as far as still photos, storage capacity is not an issue. Most of us are not shooting that many images in the 15 minutes, to fill a decent sized SD card. Then when we change battery, we can exchange SD cards too.
The above is simplistic as a certain amount of processing is always needed to convert the sensor DATA into anything we can use but RAW is less conversion than jpg.
2019-7-22
AntDX316
GetHigh Posted at 7-22 03:40
I think they should make it allowable then if it can be done.  It's not like the Spark is better than the Mavic 2.  The Spark feels 3x Slower which is bad in the air and the HD feed is unbelievable in comparison.
2019-7-22
12
