JJB*
Flight distance : 12686732 ft
djiuser_YwNCHXrm1FW5 Posted at 1-27 02:58
Hello both!
Installing the app on another phone did the trick. Thanks for the tip. I replayed the flight on the app and... voilá! the flight log was suddenly there, in the expected path. I uploaded it to PhantomHelp, as instructed, and here's the URL: https://www.phantomhelp.com/logviewer/9UFCUJISS23WS92JEYRB/ Let me know if you're able to find anything. I was manually returning home after the second "Max Power Load Reached" message. Unfortunately, I never made it, as the drone fell on these coordinates: 63.4451390, 12.7413016
Many thanks once again for all your kind support.
Hi,
Indeed, its a cool trick ;-)
Had a look at your log.
First warning at 3m20.1s in flight :
"Motor error. Check propellers and fly with caution"
Second at 3m43.0s : "
"Max power load reached. Fly with caution"
"Aircraft max power load reached. Decrease altitude and fly with caution. If this issue persists land immediately"
Next:
At 4m11.3 :
"Motor unable to rotate. Check for objects blocking motor"
"Motor stuck. Check for objects blocking motor"
See your data in my charts : Top blue line in chart = baro height line ; coloured red where your mini is going down with no down RC input!
So it looks like a motor failure, or indeed blocked/stuck or as this message is also seen when rpm drops belows certain level this due to low volts.
But your 2 cells did not really dropped too low, well it dropped just below 3.3 volts, not the reason imo for going down.
See the chart with the drone Pitch and Roll data, rapidly abnormal values....did your drone hit something in flight ??
cheers
JJB |
