Gizmodude
Flight distance : 49213 ft
MDSimpson Posted at 1-30 17:54
I just downloaded the DJI Assistant 2 Mavic version, it installed without issue on my 2009 MacPro running OS Catalina (high spec machine, 64Gb RAM, dual 3.3Ghz CPU's, 8Gb Radeon RX560 GPU, 512Gb SSD). However, the Mavic Mini wont connect. Even Unplugging the device, reboot it and reconnecting within 20s. I know it is connected as the drive comes up in Finder. I have turned off, Google Sync backup, so it no longer opens when I connect a USB device. I have also renamed the Mini in Disk Manager as there was no name. Tried rebooting it all, after all these setting changes, still nothing. What else can we do to get this working, please? FYI, the drone will not turn on with the USB cabled connected..
This is what worked for me...
1) Launch DJI Assistant 2 for Mavic
2) Remove the Micro SD Card from the MINI & gimbal cover ( DOH , yeah I know I just had to put that in there )
3) Make sure your battery is at least 50% or more
4) Power on the Mini and AS SOON as you hear the start of the startup chime on the MINI plug in the MicroUSB connection and give it a few moments to hand-shake and connect..
5) if step 4 fails , power off the Mini and repeat Step 4 ( DJI says 20sec , you actually have to do it within 5 seconds ! )
Cheers and good luck |
