It will not let you, and you can't override it.
Those 6 cameras need light.
Fly when your drone can see clearlyYour Skydio 2 navigates using 45 megapixels of visual sensing from six 200 degree color cameras, building a 3D map of its surroundings that includes trees, people, buildings and more. Because it needs to see clearly to navigate past these obstacles effectively, Skydio 2 can only fly in normal daylight conditions. Its advanced computer vision won’t work at night or in other low-light conditions. The Skydio app will warn you of low-light conditions and may suggest you land if there isn’t enough light to fly safely. When low on the horizon, the sun can temporarily blind the Skydio 2 cameras depending on the angle of flight. Note that your Skydio 2 may be cautious or jerky when flying into the direct sun. https://support.skydio.com/hc/en-us/articles/360000935174-Where-can-I-fly-my-Skydio-2-
