Smart Controller last firmware update steps to follow
12
10691 53 2020-9-25
Roety
Flight distance : 38579 ft
djiuser_dOWzAgogS9RK Posted at 1-12 05:12
Have you solved the problem? I also have the same issue.
I managed to update mine,  I think erasing storage helped.   erased/deleted files.   mostly images / videos
then flashed from an SD  card.
1-22 12:55
djiuser_xh6ad50BQgpp
Flight distance : 499 ft
Remote Id does not show on DJI GO4. I have a smart controller that as we all know is stupider than the phone. I got suckered. I go under the remote ID section and it wants me to fill in my remote ID? It says less than 10 characters and then it wants me to put in flight info? What flight info?
1-30 09:51
FloridaNext
Flight distance : 62320 ft
Didn't know the Smart Controler is stupider than the phone. Mine just works fine. But to answer your question: On SC in the "General Settings" menu tap the three dots -> scroll down and tap "About" -> pretty much at the buttom of the screen you can read the RID as it should be entered into the FAA page. It has nothing to do with the 10 character ID, this is a different thing, confusing and useless for us. Please connect and start your Aircraft first otherwise the RID won't show up.
1-30 12:59
todd
ZeuS-FL Posted at 1-15 12:24
Some information I want to share about the upgrade progress and why happens.
1- The reason why you need to reset to default setting erasing everything before upgrade is because the internale memory or storage that the Smart Controller has is very poor specially after has the operating system installed. There are not too much space left for cache or upgrades.
2- the reason why you can not connect the controller to the WiFi during the process is because the controller will try to download the new update leaving the limited space on the storage even worse. In other words will fill out the almost empty space you need to the upgrade proceed. In order to install updates or upgrade free space is needed to be use as cache or temporary files and if this heppens will be no space to installing and will fail the upgrade.
I didn't erase anything and just hit the update button. It didn't go to sleep and said it was complete. However I went to my remote ID section, and it didn't put the remote ID number in. It ask me to?  Well where do i get that. Or should I erase everything and start over? Sorry didn't join this until I already updated.
1-31 13:44
Flight distance : 948 ft
Indonesia
Roety Posted at 1-22 12:55
How do you flash via SD card? I can't find a tutorial about it, especially for the smart controller RM500
2-19 16:01
DJI Gamora
djiuser_dOWzAgogS9RK Posted at 2-19 16:01
Hi, there. Thank you for reaching out. May I confirm if you're having a problem updating the firmware of your DJI Smart controller? If so, please provide further details regarding the problem for further assistance. I hope to hear from you soon.
2-21 23:47
Indonesia
DJI Gamora Posted at 2-21 23:47
this is the error display. I have tried to update it from Settings -> System Update, removed the SD card, Factory Data Reset, but it is still stuck at 15%.
2-28 16:25
DJI Gamora
djiuser_dOWzAgogS9RK Posted at 2-28 16:25
[view_image]
Thank you for the reply, djiuser_dOWzAgogS9RK. Can you please confirm the current firmware version of your Controller? Also, please try to reinstall the DJI Assistant 2 (Consumer Drones Series) from this link.
3-4 04:18
Indonesia
DJI Gamora Posted at 3-4 04:18
Current firmware is V01.01.0064. I have reinstall the dji assistant 2 (Consumer Drone Series), but the update process is still stuck at 15%. The same thing happens when I try to "Refresh" the firmware.
3-5 08:43
DJI Gamora
djiuser_dOWzAgogS9RK Posted at 3-5 08:43
Thank you for the reply, djiuser_dOWzAgogS9RK. We'll forward this to our relevant team for further checking. We'll keep you posted.
3-9 07:17
DJI Gamora
Hi, djiuser_dOWzAgogS9RK. Please check my DM regarding the topic we discussed.
3-20 07:12
ZeuS-FL
Flight distance : 5782297 ft
Any update?
4-9 08:27
serjy
Flight distance : 169242 ft
DJI Gamora Posted at 3-20 07:12
Did you find a fix for this?  I'm having the exact same error they are describing.
4-25 12:15
DJI Gamora
serjy Posted at 4-25 12:15
Hi, serjy. We're sorry to read about that. We suggest using the internet on RC and updating on APP for testing, and also you can try to use DJI Assistant 2 For Mavic software for updating (uninstall the consumer DA2 software). If the issue persists, please send back the product for checking. You may submit an online repair request through this link: {https://repair.dji.com/repair/index}. If you need assistance with creating a ticket, you may contact DJI support at (https://www.dji.com/support).
4-26 07:46
12
