col2022
Flight distance : 287224 ft
col2022 Posted at 3-6 03:44
Hello thanks for taking the time to look into this,
Yes i powered the drone up then walked over to the takeoff point, took off and im sure i set it to the minimum 80ft, i set the home poont further than the 20meter homepoint restriction was at the end of a field but i thought that wouldnt matter as long as was somepoint safe from the road, will do another test flight today and will use the takeoff homepoint to simplify the data. Thanks Right some additional test, i lifted off, home point was set where i lifter up from, went forward the right then backwards in a sort of square patter, was about 6ft high, then turned controller off, the drone then retraced its flight, went forward at same heigt (this is where i would normally panic) then went left then went backwards to home point position, it looks eratic when flying like this and sort of cuts corners but went back to home, did the same thing but i moved the home point on the map to the drones position by dragging map and set, so the home position was right by the drone after if flew the square, swithed controller off and it flew back in the same way to its original position set by takeoff, it then started raising to the rth height then went to the new set position i set on the map,
Did the same test, flew the square but this time set the home position by clicking on the controller position on the map, flew the square switch off and it come straight to me |
