Using DJI FPV controller/goggles with any other drone?
67769 35 2021-7-23
fliegerben
Flight distance : 1918087 ft
Hi,
is it possible to use the controller and goggles from the DJI FPV combo with another drone not made by DJI?
I love the combo and the DJI FPV air unit is great, but I am thinking of using a smaller drone for practicing where a crash is not so costly… Would that work? Anyone tried this?
Thanks for your help!
2021-7-23
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Unfortunately, the DJI FPV Controller and DJI FPV Goggles only work with the DJI FPV Drone and DJI Air unit. Thank you for your understanding and support!
2021-7-24
frankymusik
Flight distance : 27904331 ft
... it's useable for the DJI Air unit too!
That's not the DJI FPV...
2021-7-24
Depp
Flight distance : 1868796 ft
You can use the goggles (but not the controller) for any drone that has a DJI Air Unit or a Caddx Vista. Those drones often have an "HD" or "digital" in the name. I fly the GepRC Cinelog 25 HD and the Rekon 5 digital with those goggles.
2021-7-24
fliegerben
Thanks for clarification, frankymusik. I meant the FPV drone...
And thank you very much for the info, Depp. So I could only use the goggles with any other drone but would need another controller? Maybe I'll go for that one day... Could I then use the controller with the FPV drone?
2021-7-25
40min
Finland
How about using of analog modules like URUAV 5.8G RX PORT 3.0-PLUS? Will it work with these goggles from combo?
2021-7-25
CoreyB10
Flight distance : 1665023 ft
40min Posted at 7-25 11:36
I use the British Drone Industries analog conversion and it works no issues. Just replace the faceplate and plug it in, switch to the analog module, alter the zoom level and away you go. Image quality is also better than most analog goggles too. Just a bit more cumbersome and more wires dangling off the goggles.
https://britishdroneindustries.co.uk/
2021-7-26
Joel S
Flight distance : 189902 ft
Just ordered one, so see how things go.
Felt funny spending so much money.
Hope it's worth it.
Good to know the goggles will work with other drones.
Following.
2021-11-11
bjr981s
Flight distance : 139895 ft
You buy the DJI FPV black controller V1 or V2. You can then fly the Flywoo micro and nano drones With the Controller and the Goggles. And any aircraft you build with the DJI or Caddx  Vista air unit.
2021-11-12
Joel S
bjr981s Posted at 11-12 23:58
Thank you.Many shops in US don't know controller works. I have V2 I guess. It's the fpv drone.
2021-12-2
bjr981s
Joel S Posted at 12-2 15:33
You will needs to set the goggles to DJI FPV air unit mode. Yours are V2 Goggles. They work for both the DJI FPV drone and the DJI air units. But you have to swicth modes in the goggles.
Then you can use the DJI Air units with the correct Controller. Your FPV controllers will not work with the air units.
Here is the link to the DJI Site for the FPV System. Only your goggles are compatible. You will need the controller and the Air unit. Or buy a FPV Drone or Wing with the Cadx or DJI air system. Or build one yourself.
https://www.dji.com/au/fpv?site=brandsite&from=nav
2021-12-3
SBD3
Flight distance : 7507 ft
What serial protocol does the air units use?  Is it Futaba S-bus?
2021-12-22
keith55
Thailand
Depp Posted at 7-24 09:39
I just watched this video on the drone you mentioned and he seems to be using both the controller and the goggles.
See the video at 3:37
2021-12-22
Depp
keith55 Posted at 12-22 21:53
This is the DJI controller that comes with their own FPV quad: dji-fpv-remote-australia-mantisfpv.jpg
You can NOT use it with the Vista or the old DJI Air Unit.
This is their older controller that can be used with the Vista/Air unit, but not with their own FPV quad:
And that's the one Steve used in the video you embedded.
2021-12-22
djiuser_vsgSywolwi1J
Can the Dji Smart remote work with a flywoo drone?
I know the goggles work.
2022-1-3
mbze430
Flight distance : 406775 ft
Are there any plans to make the DJI FPV's Remote Controller (the white one) to work with Air Units?  I have the DJI FPV drone and I plan to build my own custom FPV drone w/ Air Unit but don't want to buy another remote controller.
2022-3-23
Duane Degn
Flight distance : 622234 ft
mbze430 Posted at 3-23 06:05
"DJI FPV's Remote Controller (the white one) "
Do you mean the gray one?
The only remote which will communicate directly (wirelessly) to an Air Unit is the black controller pictured above.
Receivers for other radio systems can be very small and inexpensive. A lot of people use an EdgeTX compatible radio with their Air Units and Caddx Vista devices. Currently the RadioMaster TX16S appears to be one of the favorite controllers used by people flying FPV.
2022-3-24
ENTY8
Flight distance : 12159 ft
So if an FPV drone has the DJI Air Unit or a Caddx Vista, is it controllable with the (Black) DJI Controller?
2022-4-20
TTV-VoidGG_
Flight distance : 138051 ft
Philippines
DJI Paladin Posted at 2021-7-24 00:52
Is the DJI FPV Remote Controller 2 compatible with the DJI Build of this drone?
Drone with DJI Receiver
https://rotorriot.com/products/rotor-riot-cinewhoop-built-and-tuned-fpv-drones?variant=32565141274698
Controller
https://store.dji.com/product/dji-fpv-remote-controller-2
2022-7-4
TTV-VoidGG_
Philippines
Controller
2022-7-4
DJI Paladin
TTV-VoidGG_ Posted at 7-4 13:11
Thank you for your response. The said remote controller only works with the DJI FPV drone and DJI FPV Goggles V2. Thank you for your understanding and support.
2022-7-17
NGC-Drones
The Goggles can be used with any drone.
2022-8-11
djiuser_zftkChTeISzf
Does Occusync connect the white goggles directly to the drone or does occusync connect the goggles to the drone Through the Remote Controller? If I getting an antenna booster for the remote controller will the upgraded reception be noticed with the goggles?
2023-7-25
The Saint
Flight distance : 6260171 ft
djiuser_zftkChTeISzf Posted at 7-25 15:07
I don't remember for sure (it's been awhile) but I seem to remember the white goggles connecting directly to the Mavic 2 meaning you could use the goggles to fly the drone....without the remote.
2023-7-25
djiuser_0i3xtaz92cAw
Poland
Hi. Few months ago there was a post asking DJI to develop digital video input through USB-C port in FPV Goggles V1 and V2. These goggles are very popular and we’re still waiting for this improvement :-). Please don’t kill these products and keep updating the firmware. Think about the  planet. Updating the firmware you’re helping keep the Goggles life.
2023-7-26
DJI Paladin
djiuser_0i3xtaz92cAw Posted at 7-26 01:44
Hi there. Thank you for your feedback. We acknowledge that we have received the same concerns and suggestions from other DJI Pilots before. What we will do is continue to record such feedback and ensure that it reaches our related team. We are sorry for any inconvenience this has caused you. We hope this will be considered soon. Your understanding is greatly appreciated.
2023-7-30
djiuser_d8o34cJJ6qa5
How can u tell what remote goes with what drone no marks on either
2023-9-12
2023-9-12
The Saint
djiuser_d8o34cJJ6qa5 Posted at 9-12 15:23
If your equipment has no markings on it (doubt it) then you have no choice but to go with pictures of the equipment and try to match it up that way.  Or else you can power it up and see if you can read the model number or serial number from the software.  Just post a photo (of the newer remotes) here, someone here can tell you what drone it works with.
2023-9-12
djiuser_VkZf2b5sLyO8
Will goggles 2 connect to gopro?
2023-9-13
DJI Paladin
djiuser_VkZf2b5sLyO8 Posted at 9-13 19:28
Hi there. Thank you for reaching out. Unfortunately, we don't have an option to connect the DJI Goggles 2 to a 3rd party camera like gopro. Feel free to reach us if you have other inquiries or concerns. Have a nice day ahead!
2023-9-24
djiuser_dPXeeOILpU3u
India
Can i bind new dji Avata 1
With my old dji rc 2 and googles 2
Actually my old avata got damaged
2024-6-13
India
By other drone i want to mean other avata which is not connected to this controller and googles
2024-6-13
djiuser_XVKNBcFtp5M5
Is the DJI Avata 2 compatible with the DJI FPV controller 2, I was watching a youtube video and it said that it is not compatible with the DJI FPV Controller 2 and DJI RC Controller 2 as well. I also wondered if I could use the DJI FPV Controller 2 with the DJI Goggles 3, or if it is only compatible with the DJI Goggles 2 and Integra.
2024-6-29
djiuser_FJF1Y7tvZJdC
DJI Paladin Posted at 2023-9-24 05:10
Yes you can use goggles integra and controller 2 with iflight drones that have the 03 air unit. I have mine bound to the iflight defender 25
2024-8-1
SBD3
You can also use the Xreal glasses with any of the smart controllers with a display.  This is not published, but because it is android the operating system outputs display port over usb-c.  I have the original RM500 and the DJI RC 2.  Works great in all environments and bright sunlight.
1-23 13:45
