New Mavic Air 2 Firmware Released (11/18/2021)
12Next >
7653 52 2021-11-18
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2021.11.18
  • Aircraft Firmware: v01.01.06.90
  • Remote Controller: v04.11.00.16
  • DJI Fly App iOS: v1.5.0
  • DJI Fly App Android: v1.5.0
What’s New?
  • Fixed some bugs.
Notes:
  • If the update fails, restart aircraft, remote controller, and DJI Fly or DJI Assistant 2 (Consumer Drones Series), and retry.
2021-11-18
Frontliner 2020
Philippines
thank you for these info...
2021-11-18
DJI Stephen
Frontliner 2020 Posted at 11-18 02:08
Hello there Frontliner 2020. You are very much welcome and thank you for the reply. If you have any inquiries with the new DJI Firmware update for the DJI Mavic Air 2. Please feel free to post it here at DJI Forum. We are all here to help and assist you. Thank you.
2021-11-18
virtual
Flight distance : 5161677 ft
Czechia
I hate description "Fixed some bugs" but I updated drone and all my batteries successfully (and Fly safe database as well). I'm not able to make test flight today...
My Android app sais DJI Fly App 1.5.1 (1980) BTW
2021-11-18
DaMa
Flight distance : 889662 ft
Same for iOS, 1.5.1
- Fixes certain issues and optimizes overall app quality"  Much more than just a few bugs eliminated.
2021-11-18
Bings Mavic Air 2
Flight distance : 1306624 ft
still can't use my Google Pixel 6 though......come on DJI  !!!!
2021-11-18
djiuser_wPZLuGktl6li
We need a firmware fix for black screen on pixel 6 phones
2021-11-18
DowntownRDB
Flight distance : ****
Thanks for sharing.  Wish you could be a bit more forthcoming with details of what's new other than just "fixed some bugs"
2021-11-18
me
Flight distance : 53091 ft
Black screen on my Pixel 6 and I still can't fly autonomous flight paths? I'm just about ready to return this thing.
2021-11-18
Yaros1
Flight distance : 25188186 ft
me@jeremywhittaker.com Posted at 11-18 17:25
Okay, try Litchi!
It supports Waypoints AND maybe will fix the issue with black screen, although it costs $25
https://flylitchi.com/
2021-11-18
KTM80PT
Flight distance : 743235 ft
As much as it sucks, maybe return the phone
2021-11-19
CQW
Flight distance : 125020 ft
A few days ago I upgraded my MAVIC AIR 2 firmware to 01.01.0670 and DJI Fly App to 1.5.0. Immediately after the upgrade I found the the camera's "pro" mode stopped working. No matter what speed I set the drone only take photos with 1/6400s shutter speed. I then upgrade DJI Fly to 1.5.1. No fix. Today I upgraded firmware to 01.01.0690 and hoped it will fix the problem. But unfortunately it is not "some bug" that has been fixed with this release.
2021-11-19
Encyclo
Flight distance : 1308340 ft
CQW Posted at 11-19 08:45
Sorry to hear you lost access to the Pro mode.
Just FYI, I have the same drone and same iPhone app configuration and same Firmware on the drone and I still have access to the Pro mode.
Good luck figuring out your issue.
Fly Safe, Always
2021-11-19
CQW
Encyclo Posted at 11-19 11:49
Thanks! I contacted tech support and uploaded a video clip to show the issue. Hope there is an easy fix. The video pro mode works. It is just the photo pro mode that gives me trouble.
2021-11-19
djiuser_25HmH74KCjHG
Flight distance : 123133 ft
Can anyone confirm if this has fixed the iOS15 USBC not connecting issue? DJI just seem to be ignoring this, no apple products with usb c will connect to the controller and they never give a proper response
2021-11-19
JodyB
Flight distance : 322005 ft
djiuser_25HmH74KCjHG Posted at 11-19 12:40
Im using an iPhone 12 Pro Max with iOS 15 latest update and it connects to the controller with no issues to report here.
2021-11-20
GCxCD
Flight distance : 119209 ft
Since I updated, when I start/connect my drone, the homepoint move on the compass as if my drone was flying and the distance display shows thats it's getting further and further. Even if I'm just beside the drone which is just sitting on the ground.
2021-11-20
CQW
I finally decided to reset the camera, and that fixed the problem.
2021-11-21
CQW
I tried with my iPad Pro (2nd gen) which has iOS 15.1, and the USB-C connection works fine.
2021-11-21
djiuser_gMo6QbYhdkXA
Flight distance : 29216 ft
Bulgaria
I updated everything today and unfortunately out of nowhere my drone (mavic air 2) doesn't work anymore. It used to fly just fine yesterday. Now it gives me all these error codes: unable to connect gimball code 40012, gyroscope initialization failed code 30045, barometer initialization failed code 30047. It says IMU calibration is necessary as well but it doesn't start to calibrate. I tried refreshing the firmware with DJI Assistant 2 and nothing changes. It doesn't give me an option to downgrade either. I still have 11 months of warranty left but I really don't wanna send it in. I'm pretty sure it's a firmware issue. Any help would be greatly appreciated!
2021-11-21
mavicSD
CQW Posted at 11-21 10:52
Air 2: Reset only work for that session, when restarting the app and drone the photo PRO mode shutter speed (SS ) does not work, and the camera does an auto SS setting.
I found changing the ISO activates the SS.  E.g. in photo PRO mode setting the ISO from e.g 100 to 200,  SS works again then set ISO back to 100.  However this needs to be done every time you start the app and connecting to the drone. Must be a Bug
2021-11-21
djiuser_pVzOCZcKi0X6
Flight distance : 120361 ft
Indonesia
What’s New?
       Fixed some bugs.
Useless
2021-11-22
CQW
mavicSD Posted at 11-21 23:08
I found changing the ISO activates the SS.  E.g. in photo PRO mode and the SS does not work, setting the ISO from e.g 100 to 200, SS works again set ISO back to 100.  However this needs to be done every time you start the app and connecting to the drone. Must be a Bug
Yes you are right. The problem is still there and your workaround works.
2021-11-22
CQW
djiuser_gMo6QbYhdkXA Posted at 11-21 12:04
Turn on DJI Fly app today and see that there is another firmware update. Not sure if the updates you installed yesterday are the same as mine. And I am not sure whether this new update will fix my problem or give me your problem. I am going to wait.
2021-11-22
Muchmore
Flight distance : 568714 ft
Anything on Pixel 6 fixes yet?
2021-11-22
ILS
Muchmore Posted at 11-22 19:07
No DJI substantial  reply yet? How poor is that?
2021-11-23
ILS
No substantial DJI reply yet? How poor is that?
2021-11-23
gdfaini
Flight distance : 532359 ft
V1.5 no longer lists Samsung Galaxy S7 as a compatible device.
Guess I don’t have to worry about updates until I get a new phone.
2021-11-23
djiuser_OiCjQhV5oqfv
djiuser_wPZLuGktl6li Posted at 11-18 11:36
I would like to join the statement. Pixel 6 Pro, Andoird 12 user.
I would also like to know whether the update resolved the problem with the Air 2's low rate of descent. My Air 2 loses a maximum of 0.4m / sec in height until I have come close enough to the ground, then it also sinks at 3m / sec.
2021-11-25
HAIRGIRLSC2012
My Air 2S started shaking intensely at about 4 meters while coming straight down then nose dives on the front right arm almost every time I fly. It started after this firmware update!!!!
2021-11-26
yerneni
Flight distance : 20902 ft
Hello, I upgraded to this latest version and find that I am not able to see the controller signal direction and the drone orientation display in the bottom center, as it is shown in some of the videos. Also, I don't see the zoom functions in video mode at all.
I have the Air 2
2021-11-26
FEGPC
Question.  I did the firmware update via my phone connected to the controller.  It asked for firmware update and i clicked yes on phone.  Did the same for my remote controller.  Do i still need to do it in the DJ assistant too?   Or is this just showing how to do it via phone and by pc too.
2021-11-26
yerneni
Hello, I am a newbie and still navigating through the feature set One thing I notice is that all the YouTube videos show this controller/aircraft signal direction/orientation(see the pic) in the bottom center. I can't seem to get that to work. How do you get that to display?
2021-11-26
virtual
Czechia
yerneni Posted at 11-26 15:46
[view_image]
This indicator was removed in latest Fly app version. Upgraded indicator can be turned on in bottom left corner...
2021-11-27
virtual
Czechia
FEGPC Posted at 11-26 15:23
I do updates with my phone only. Don't forget to update all batteries. You can check in Fly app if everything is up to date.
2021-11-27
djiuser_RafEUW1sSTrI
Romania
Hi. I just update my samsung s21 ultra to the latest android version and after this the dji app is not showing me image any more.  Is just turning on and conect to the drone and I don't have image. Can someone help me please??
2021-11-27
engelo2
Flight distance : 3715837 ft
Israel
It is look that dji app still not support  ADNROID 12 ...... some one need to wake up in DJI company !
2021-11-27
Ronnie.Choy
Flight distance : 1261211 ft
Singapore
HAIRGIRLSC2012 Posted at 11-26 08:37
Maybe you can test with 4 new propellers to see if the same issue still happens.
2021-11-28
Muchmore
Pixel 6 support, please!!
2021-11-28
fansb7cdecaf
Singapore
I updated the drone software to the following latest version, and now I can't fine the digital zoom feature ( which you announced on August 10,2020 that zoom feature is available).Please let me know the solution quickly so I can get on with my work.
Kindly Regards.
2021-11-29
12Next >
