Quick Transfer not working on iPhone? - "Downloading Work Failed"
12
47559 77 2022-5-31
Drone Jockey
onymar Posted at 8-14 14:30
If I sync the photos app, the date/time of all pictures and videos are set to the current time. I sync to the fly app and then to the photos app and date/time are as per then time taken.
Mmh, might be the same in my case ... needs further testing.
I furthermore found out, that sometimes the location data is missing in EXIF.
2022-8-14
KHew88
Flight distance : 20935 ft
Glad I am not the only one that has had this issue. I got my Mavic Mini 3 Pro last week and i was transferring via the controller and it kept prompting me to switch to QuickTransfer but then failing to connect to the WiFi of the drone to do so.
I tried the Cell fix etc but to no avail, randomly a few days later it started working and has done since. I am 100% confident that it is not related, but the only thing that I changed between it not working and working was changing the drones name, and not even the one for the WiFi SSID :/
2022-8-14
Drone Jockey
Drone Jockey Posted at 8-14 23:12
Ok, did a quick test ... when syncing to the Photos app, all Exif data gets lost and the time stamp is the time of syncing :-(
When syncing into the fly app, the Exif stays intact.
PS: I connected the phone directly to the drone, with the controller being switched off.
2022-8-15
djiuser_f0fw8ssZU2ku
Yes turning off the cellular does the trick. I’ve just received it today and it has current firmware as of  19th August.
2022-8-19
djiuser_YeV5n37cpznE
Flight distance : 1007402 ft
Xtropy Posted at 6-2 04:04
Well after playing around with this over the last day, I tried something obscure that worked. Since the iPad worked fine, I thought "What if I disable cellular on my phone?" I disabled it and now I can transfer. When I turn cellular back on, I cannot. Not sure why cellular is being used in a peer-to-peer WIFI connection but hope this gets back to the app dev's to investigate further.
Note that the same process fixed both iPhones. Maybe something that's conflicting with my carriers APN data which is why the scope of the problem isn't affecting more users?
Thank you!!
2022-8-20
fans96491978
Flight distance : 95512 ft
Same issue, why does DJI continue to sell buggy drones and offer no solutions or support?
2022-8-25
Xtropy
Flight distance : 12625 ft
fans96491978 Posted at 8-25 05:40
I hear you. It's the only company I know that has a "if we don't acknowledge a problem it will go away" mentality. So much easier to say "We are aware of this issue and working on it". Places more trust in the company but not a DJI policy to do that. Maybe a culture thing? I dunno but frustrating...
2022-8-25
MacAgent
Flight distance : 90098 ft
Luxembourg
Hello people,
is there any fix or solution for this date and time changing?
It‘s really frustrating to have all the synced photos and videos in the photo library in the reverse order.
2022-9-19
Scheize
I'm having the issue when downloading files to my phone through DJI Fly app, all EXIF data is gone.
I never saw an option to download to the app and then to the phone, even though that's annoying and I'd rather not.
2022-9-20
djiuser_4TxMP9EYyq9K
Flight distance : 91827 ft
French Polynesia
I have the issues that after the download the DJI Fly App tells me the files are on my iPhone but I can’t find them anywhere. What can I do?
2022-9-22
MacAgent
Luxembourg
Scheize Posted at 9-20 16:00
Videos does not contain any EXIF data. I found a workaround for the GPS location…which is not perfect, but working for me.
I take  a Picture after the Home has been updated, This Pictures contains correct location data, then after transferring all videos to your phone (iphone for me) just copy the location data form the picture and paste it to all the corresponding videos.
2022-9-23
MacAgent
Luxembourg
djiuser_4TxMP9EYyq9K Posted at 9-22 00:29
Which app version do you use? Latest versions store the files directly in the Photos App, where older versions store the files into the fly app dedicated folder.
2022-9-23
djiuser_483ODU2QRiU0
Had the same issue. Tried your work around of turning off cellular on iPhone 13 and it worked.
2022-10-5
Scheize
MacAgent Posted at 9-23 05:38
Got it, thanks!  I mainly want the photo EXIF data.
2022-10-10
Scheize
Turns out the EXIF data is in the downloaded JPEG.  The timestamp is incorrect when downloaded but is in the "I" icon.   The timestamp is when you download it, not the real info.
2022-10-10
djiuser_ZObqmiVGLFg5
DJI Stephen Posted at 5-31 21:00
Hello there Xtropy. I am sorry for the trouble this has caused and thank you for reaching out. I will post some information below on how to properly use the QuickTransfer function of the DJI Mini 3 Pro. Thank you.
[view_image]
Hey Stephen,
I’ve done exactly those steps that you have posted about the mini 3 pro and still I cannot download any photos or videos from my drone.
I can connect, view them/watch them in low res but the moment i hit down load it just sits there, doesn’t download anything and then eventually just says a message about not being able to download. Help
2022-11-1
Yorkshireman
Thanks for this. First day with the drone and hit it right away. Solved. Cheers
2022-12-28
Yorkshireman
2022-12-28
MoJoMoJi
Flight distance : 251145 ft
Still having this issue in 2023. After disabling the cell, everything works perfectly
2023-1-7
djiuser_YNhNv7GSpbP7
Xtropy Posted at 2022-6-2 04:04
Thanks so much! Turning off cellular is weird but it works for me.
2023-2-17
djiuser_dzRcdzj5Hry6
That worked for me by turning off cellular, so thank you very much for your post!
2023-5-15
djiuser_WvKwTex7AXzL
Honestly thank you for this !! It totally works
2023-7-27
djiuser_UAE5rQHilKBr
Thank you!!! I turned off the cellular and the pics downloaded in less than 10 seconds! 23 total.
2023-8-13
HikerWV
Same problem with my new Air 3.  I thought it was something a newbie like me was doing wrong, but it turns out I'm not the only one with this issue.  I turned off the cellular, and the transfer was smooth.
2023-9-6
djiuser_UxMF1Unrnsi8
Flight distance : 83304 ft
TURN OFF YOUR CELLPHONE DATA AND JUST USE WI-FI ONLY….it fixed my same issue
2023-10-4
djiuser_luRWkkNvfpyx
Thanks. I was stumped until I read this solution. I turned off cell data and it withers straight away. Appreciate you updating. Cheers
2023-10-29
djiuser_LpsiaKfo4wkc
Super easy to fix!
I did a video to prove it.
You thank me later.
Btw DJI should fix this issue
https://youtube.com/shorts/UQq_0uRVPKA?si=xZ8yPM65RM7W-e3V
2024-2-26
fans6081bfab
djiuser_UiOpbSlvbHqN Posted at 2022-6-16 09:44
I've had to turn off cellular since day 1 for it to work on my Mini 3 Pro.
+1 worked for me as well.
DJI 4 mini pro, latest greatest firmware, iPhone 14 Pro DJI Fly app
2024-5-19
fans160c10f2
Hawklclaw Posted at 2022-6-3 17:18
I am also having the same issue
Me too. Have spent hours trying to work this out.
2024-7-27
DJI Diana
Flight distance : 2408 ft
fans160c10f2 Posted at 7-27 17:45
Hi there,
Have you tried turn off the mobile phone’s cellular data?
Kindly please keep us posted for further assistance. Thank you.
2024-7-28
ResQU
I’m using iPhone 15 with Mini 3, I can not get the quick transfer to work. All the steps show I’m connected, the lights on the M3 begin to flicker as I select download bu nothing is happening.  I’ve turned off the cellular with no change.  I’ve delegated cache files, restarted both the M3 and the phone.  Still no change, transfer hangs up at 4%.  Is this thread monitored by DJI, or should I start a repair request?  So many have had success with the cellular toggle, I feel like I’m doing something wrong.  I know this is an older thread but I’m hoping someone will have another suggestion.  Thank you in advance!
2024-9-8
dewando
I'm having the exact same issue. I'm on IOS 17.7 and can't download any media to my phone. Hope they can suggest a fix before I leave for vacation next week.
Update!
Aftrer reading all the responses, if I turn off the cellular data it works.....weird.
2024-9-17
DJI Diana
ResQU Posted at 9-8 19:18
Hi there,
We apologize for the delayed response. Please confirm if the app version and aircraft firmware are the latest then follow the steps below:
1. Power on the drone, and wait until the drone self-check is completed. Quickly press the power button three times to switch the drone from flight mode to QuickTransfer mode. The aircraft status indicators will blink blue once switching is successful.
2. Enable Bluetooth and Wi-Fi on the smartphone. Open the DJI Fly app and select the drone for connecting when it prompts the available device list. (When connecting the smartphone and the drone for the first time, press and hold the power button for two seconds to confirm the connection.)
3. Tap “Connect”. If connected successfully, you can view the drone album and download videos or photos at high speed.
Let us know if the issue persists. Thank you.
2024-9-18
djiuser_QTbhhFzBwS22
Still have this issue over two years later and the workaround of turning off the iphone’s cellular data seems to work. Hopefully dji will address this issue
2024-10-13
PaulFowler
Flight distance : 760266 ft
On my Air 3S the Quick Transfer worked great to my iPhone 15. Then I changed carrier (in Australia I moved from Vodafone to Telstra) and it stopped working. I turned cellular data off and it worked. Must be dependent on the carrier. BTW, I turned cellular data off and it worked, then I turned it on and it kept working, hmmm very odd!
2024-11-19
djiuser_kp83BMVxPivp
Flight distance : 7661 ft
Downloading has always been very consistent. No issues ever! Now, all of sudden, “download failed” consistently.
2024-12-16
Andrew Scott
Flight distance : 578583 ft
This worked for me like a charm: put iPhone in flight mode, turn on Wi-Fi and connect to drone → QuickTransfer works! What a relief.
2024-12-25
djiuser_8fOdNH3fYueq
Just bought air3s and tried to transfer the pictures taken with 3s to my iphone13. Hit the same problem and the trick of dropping the cell data helps. Cannot believe DJI still does not fix the problem reported almost 3 years ago!!!
1-26 18:34
12
