Hannibal_
Flight distance : 297126 ft
Sorry guy’s
I am a bit confused… it all sounds soo complicated
I think there are 3 things:
1) connect the controller to the drone
No WiFi/Bluetooth setup needed, all is done by the controller and drone.
One time step by step connection setup via the app on the controller may be needed, after that, they should find each other when you switch on both.
2) connect the DJI RC to internet
If done on hotspot it is not shown in the list of available networks.
Manual config is needed (add network) :
On DJI RC:
SSID: name of hotspot on your phone including all spaces and stuff.
Encryption: choose highest encryption that works, WPA3/SAE works for me
Password: the password of your hotspot
3) connect phone to the drone to retrieve/download high quality footage to your phone for later use
For me works:
Drone is on, (I switch off the controller, but it is not necessary I understand) phone is on with fly app active (visible on the screen, startup screen):
You will get the question if you want to switch to the quick transfer mode (you do!)
During that process you can be asked if you want to connect to the drone’s network/WiFi (the app asks this and will take care of the connection! You don’t have to connect to the drones WiFi manually!)
Yes you want that for this purpose and the dji fly app knows the password, no worries…
You get the question if you want to view the album and again, yes you do.
In the album you can download the footage on the drone
Sometimes you need a second attempt if it fails to connect, just retry the switch to quick transfer mode question again.
No adapter needed although that should also work (but for my hands those little memory cards are too tiny and I don’t want to loose them in the field or so)
