Xtropy
Flight distance : 12625 ft
mkdp.photos Posted at 6-23 09:52
Ok so I tried that fix during my lunch break (work from home) and wow
It worked... I easily had 5 bars 1000m away and could probably go further but didnt just because we currently have 12m/s gusts
Glad it worked! It's really that delay in getting GPS.
I have contacted DJI support 3 times about this issue and I get a response explaining the differences between CE and FCC modes. If anyone has suggestions about how to get them to take this issue seriously, I am all ears. I linked the video and gave a thorough explanation, I got this in response:
---------- Forwarded message ---------
Date: Wed, Jun 22, 2022 at 10:04 PM
Subject: [DJI Support] : RE DJI Mini 3 Pro - Not in FCC mode in Canada (stuck in CE mode)
To: Brad L <xxxxxx@gmail.com>
Your request(#4334678)has been updated, please reply the email below.
Tom (DJI Support)
2022/6/23 GMT+8 10:04
Dear Customer,
Thank you for contacting DJI Technical Support.
We appreciate the time you provided to us and let us know your concerns, but no worries, we are here to assist and help you out.
DJI Mini 3 Pro has only one version of the hardware. the aircraft will automatically switch to the corresponding FCC and CE depending on the current country.
There are three concept before the main body:
1. Not every country’s certification belongs to one of the FCC/CE/SRRC, we just make sure that US using FCC, Europe using CE and China using SRRC. Other country just refer to the maximum transmit power of the remote controller of their country to find out which one among this three certification type to be the reference.
2. No matter which certification type the country is, it doesn’t mean we must use the standard of that certification. We just make sure the maximum transfer power of the remote controller applies with the local law, but won’t reach the largest permission. The maximum transfer power of our produce is decided by DJI and be restricted by local law.
3. Even in the same country, the certification of 2.4GHz and 5.8GHz can be different.
For example.
If you are in Canada, the maximum transfer power should be 26 dBm when using 2.4GHz and the maximum transfer power should be 28 dBm when using 5.8GHz. This is the standard of FCC.
If the you are in Europe, the maximum transfer power should be 18 dBm when using 2.4GHz and the maximum transfer power should be 14 dBm when using 5.8GHz. This is the standard of CE.
If you are in Brazil, the maximum transfer power may be 20 dBm when using 2.4GHz and the maximum transfer power may be 25 dBm when using 5.8GHz. Then the certification type in Brazil should be CE when using 2.G. The certification of 5.8 can refer to FCC, because 25dBm is more close to 28dBm of FCC than 14 dBm of CE. (The parameters are not real)
Thanks for your understanding.
Thank you for choosing DJI.
Best Regards,
Tom
Website:http://www.dji.com/support
Youtube:http://s.dji.com/DJI-Tutorials |
