New Mini 3 Pro Firmware Released (07/23/2024)
130921 541 2022-8-17
hallmark007
Flight distance : 12400594 ft
CloudVisual Posted at 8-18 03:42
Ok, I can't win on this forum about the naming of this function.
Aperture priority on a camera means that the shutter speed can vary to adapt to different scenes. Yes, I know that this drone has a fixed Aperture and therefore in Av mode it will just have to stay fixed and then the shutter speed adapt, as it should.
Auto/fixed Aperture and Auto Shutter is basically P mode that all photographers are very familiar with.
But Harley is correct there is no Aperture priority on Mini , shutter priority is there and effective P mode.
2022-8-18
CloudVisual
Flight distance : 97545420 ft
HarleyFlyer Posted at 8-18 04:32
Ok - ( i am a professional photographer - master level) - what you are showing in that photo - and I assume asking for is something that I too would very much like - and that is Iso Priority.
The only things that you can change on the drone are the Shutter Speed or the Iso - and when you leave the drone in Auto mode it is changing a combination of those two things to create the perfect picture - however it's really annoying when you want to keep the Iso at 100 - and have the shutter adjust accordingly for the changing light levels - so this would be called an Iso Priority mode - and I would like it too please.
If I refer to it as ISO priority, I'm due a headache of replies and misunderstanding, but I'm glad we've agreed that this is a necessity.
2022-8-18
FedericoB
Flight distance : 140144 ft
Argentina
Henrik Olsen Posted at 8-18 02:02
No DJI RC Fly App 1.6.12?
Yesterday i recived a warning to update on adroid to 1.6.12, but cant replay any more the fly logs, so y get back to 1.6.10
2022-8-18
hallmark007
If you’re using manual shutter ISO will not change, in Auto yes it will but just change shutter to scroll wheel and its a very quick change.
2022-8-18
CloudVisual
hallmark007 Posted at 8-18 05:02
But we don't want to have to manually change this using the scroll wheel. The point of auto shutter is so that it changes with the scene and will abide by whatever the +/- EV setting is, meaning we can focus on hitting the shutter speed and trust that almost all of the shots will be correctly exposed.
It's more important for a faster paced environment than something like taking photos of a house etc. But even in those situations I like the auto shutter mode to just handle it all and I nudge the EV up and down if I have to.
2022-8-18
hallmark007
CloudVisual Posted at 8-18 05:05
It doesn’t make much sense its just as easy to move the SS up and down as it is to move EV this will also automatically move the EV’s. Lots of photographers use full manual mode but almost all of them use either SS or Aperture priority when shooting. Video users will nearly always use 180 rule so manually setting shutter is important to them . I don’t think drones are used much for Run and Gun shooting of photos so changing SS to suit shooting conditions manually is not going to be a big deal. Also if you require the correct SS in all conditions you really are better off having it attached to ISO.
2022-8-18
Mavic57pro2
Flight distance : 4212949 ft
PeterIOM Posted at 8-18 00:31
Thank you, I am aware this is not Facebook, by the way sarcasm is the lowest form of whit, but thank you for your help.
I agree about sarcasm, sorry, when you been on the forum for over 5 years, you do wonder some times if people actually read answers before asking questions. Happy flying.
2022-8-18
CloudVisual
Dirty Bird Posted at 8-18 08:42
How would aperture priority work on a drone with a fixed F1.7 aperture?
See above. Strictly speaking it's ISO priority I'm asking for.
2022-8-18
djiuser_N3Bys8VJn4Rf
When can we expect mastershots in portrait mode?
Where on the forum do you submit feature requests?
2022-8-18
MattCaz
Flight distance : 251358 ft
When will the RC remote Controller be compatible with the Air 2s?
2022-8-18
MySky
Flight distance : 364902 ft
Did fly 3 batteries with new FW.
Finally both compass views are now spot on for me. Befor the old view was always up 30 degrees off and the new view was so worse that it was unsuable on the DJI RC.
Flight log is OK. Hopefully DJI will not mess it up again with a FW update to 1.5.12 or above.
Sphere is much better now. Not finally perfect, but the gap on the top is very small now. So nothing to worry about except for perfectionists.
Over all everything seems to be as smooth as it should.
2022-8-18
Amit Dunsky
Flight distance : 1083205 ft
Israel
Only when using RC-N1.
For the RC remote, the fly app remains at ver. 1.6.9
2022-8-18
Gadget4
Unfortunately this update does not appear to fix the low resolution maps issue.
2022-8-18
Bashy
Flight distance : 2354357 ft
Mavic57pro2 Posted at 8-18 06:45
Actually, some do not, they tend to read the 1st post and then post their own answer and that generally echos the 1st one to three replies (if they are correct). Then there are the odd one or 2 that will just copy the consensus.
2022-8-18
Bashy
MySky Posted at 8-18 10:32
I have a theory behind that, this update initiated a full factory reset, this is what was needed before this update to get the RC compass working as it should.
But, i have also noticed that the RC compass still needs calibrating. Therefore a manual interference is needed using the magnet and it will allow a proper calibration, not the ultra fast performance that was required before, this time it let me do the normal calibration, i was actually able to do the turns about 3 times and twice at that.
2022-8-18
MySky
Bashy Posted at 8-18 16:50
My theory is that is that it was more related to one of the last AC updates than the RC updates, because neither a RC calibration nor a factory reset did help.
Also a AC calibration did not improve the pricision of the compass.
I think there was a data calculation / gathering bug in the FlyApp after the implementation of the M3, which has been adjusted and solved with the current AC update.
2022-8-19
Bashy
MySky Posted at 8-19 00:06
Very strange, it worked great for me
2022-8-19
nOxxxx
Flight distance : 92427172 ft
Poland
I recommend that you be careful in rushing over new firmware. From him there is no return to previous versions. They changed the ARB to 2.
2022-8-19
Irish DM
Flight distance : 133110 ft
Nice job Dji.  Now how about fixing those wonky Sliders.  (I could not resist a chance to get that dig in.)
2022-8-19
djiuser_XfsaEbQlAq2z
Flight distance : 40312 ft
When will the mini 3 pro RC controller be updated to DJI Fly 1.6.12?
2022-8-19
djiuser_SAaPrNdpMNfe
Flight distance : 1299 ft
Oman
Hi I just got my DJI today and updated all the firnware. I took it for a get flight and everything was perfect. But when I came back to do the quick transfer I was not able to connect to the device.i was able to find the wifi and the Bluetooth of the drone. But when connecting it fails to connect. I have tried it with 3 other phone both android  ver 12 and iphone 12 all with the same issue.
I have ALS noticed in my profile on both my phone app and the DJI rc  the setting section I don't find the quick transfer option. Attached is a picture
2022-8-19
Blériot53
Flight distance : 6857651 ft
chillibadger Posted at 8-17 03:51
couldn't see an update for my RC controller even with DJI Assistant.
The update is for the RC Pro, not the standard RC
2022-8-19
Blériot53
hallmark007 Posted at 8-17 06:14
Good job, now I have a remote that works with 3 drones.
360 panos were the most interesting to me.  I tried one immediately after updating, in a break in the weather.  It was a calm day. The composited image has a stitching mismatch on the vertical axis at the start/finish line. The overall pano isn't bad, so I need to do some more testing to see if this was a one-off problem, or whether it's an issue.
2022-8-19
MySky
For those using the RC-N1 and Android devices.
https://forum.dji.com/forum.php?mod=viewthread&tid=272203
2022-8-19
iaesteman
Flight distance : 30187 ft
North Macedonia
With this update I got Compass and IMU error and not able to fly the drone. I also got Gimbal error it doesn't allow me to calibrate stays at 0%...  Please help.
2022-8-19
fans32a3cf6b
If I buy a new DJI Mini 3 Pro will I need to get a remote controller for it or can I go directly to the DJI RC Pro? Can I update the firmware on the Mini 3 Pro and the RC pro with my PC
2022-8-19
bjr981s
Flight distance : 139895 ft
Interesting. That it also includes a battery update?
2022-8-19
bjr981s
Amit Dunsky Posted at 8-18 02:01
So, just for the sake of clarification:
The Remote Controller firmware is updated to v01.01.0300, but the Fly App version remains 1.6.9 .
Can you confirm that?
That is indeed the case for the DJI RC still at 1.6.9. The RC Pro updates the Flyapp to 1.6.12.
I would assume that mismatched levels could cause issues.....?????
2022-8-19
bjr981s
fans32a3cf6b Posted at 8-19 16:48
Yes your PC can update the drone without having a controller using DJI Assistant 2 Version . V2.1.10
2022-8-19
nOxxxx
Poland
bjr981s Posted at 8-19 20:51
Yes, it includes new firmware for the battery.
2022-8-19
Amit Dunsky
Israel
bjr981s Posted at 8-19 20:55
Given that the major update introduced in 1.6.12 is the change of downloading from the drone directly to the phone gallery instead of downloading to the "app album", this is non relevant to the RC, so I guess there's no real reason for changing the version number for the RC fly app.
2022-8-20
SeehawerB
Flight distance : 5479006 ft
There is another version of 1.6.12 available:
1.6.12 (build 1610) vs. 1.6.12 (build1600)
2022-8-20
PolAir
Flight distance : 642073 ft
I appear to have lost the RTH button since the update. Anyone else had this issue?
The 'Land' option is still there, but not RTH.
2022-8-20
djiuser_eOYWWClpgB2G
Flight distance : 145666 ft
Israel
PeterIOM Posted at 8-17 14:10
Will I have to update all my 4 batteries at all? Read on a FB post you do but I am not sure that is right.
Definitely yes!! you need to update all your four batteries.
2022-8-20
GeorgeFoxCinematography
Flight distance : 31263717 ft
Greece
Works great! Thanks!
2022-8-20
djiuser_YjXzbARsWPUR
Will the Fly App in the RC Controller also be updated to Version 1.6.12?
2022-8-20
KlooGee
Flight distance : 16783757 ft
PolAir Posted at 8-20 02:49
Why do you need to use RTH if the drone is basically right next to you?  Fly further away and check again.
2022-8-21
KlooGee
djiuser_YjXzbARsWPUR Posted at 8-20 13:57
Nope, we are stuck with v1.6.9 forever now!
Of course the RC will be updated at some point.  The only question is how long it will be.  Quite honestly, based on the release notes, there really isn't any documented updates in 1.6.12 that RC users would benefit from.
2022-8-21
hallmark007
Are you in any of the features modes?
2022-8-21
Amit Dunsky
Israel
KlooGee Posted at 8-21 05:17
Most (if not all) changes in 1.6.12 are related to Phones (download photos and videos directly to the local gallery), and Android OS (version compatibility).
Given that, there isn't really anything related to the RC, so what's the point in upgrading to 1.6.12 when there's nothing to upgrade...???....
2022-8-21
