hallmark007
Flight distance : 10017858 ft
CG1558 Posted at 10-7 19:25
I took off in my driveway exactly where I was trying to land. So, let's say there is something wrong with the compas. How do I fix / calibrate that?
There is nothing wrong with your compass, if you were close to magnetic interference at take off this can affect your compass, IE Rebar in concrete or close to any metal, your compass will reset so you just need to be careful were you take off from you don’t need to calibrate anything.
Below is for “ normal” drone but principle is the same.
Tip To Help Avoid compass interference and crash.
1/ Never calibrate Compass unless prompted to. Your compass will always prompt to calibrate if it needs it .
2/ start AC leave until you receive enough gps lock ,
3/ if you get Compass interference turn off AC and move to another location,
without interference.
4/ In bottom left hand corner on your map you will see small red/blue triangle, check to make sure that this triangle is pointing in the same direction (heading) as your AC, this will show good compass on the ground.
Raise AC to height of 8ft
Hover for 20 seconds
Fly forward 2ft
Backward 2ft
Left 2ft
Right 2ft
Up 2ft
Down 2ft
Yaw left
Yaw right
Each time returning to hover position
If you have a good horizontal each time, you will then know you have good GPS good IMU and good Compass, and your ready to fly.
This exercise takes less than 1 minute and is worthwhile doing before every flight,
