Bashy
Flight distance : 2354357 ft
You can help mitigate these magnetic interference issues by turning on the drone whilst holding it as far away as possible from any steel source, if its encased in concrete this in itself helps towards the mitigation.
This is something that i do most times when powering on, after the initialising completes (gimbal dance) you can then place it where needed.
One practises that Labroides mentions and one that i always blooming forget to check, is to make sure that the drone is actually facing the same direction as shown in the Fly app, I think I've said that correctly? If there is a difference then you have magnetic interference and most probably will have issues shortly after taking off.
As you've already mentioned, the older DJI drones were more susceptible, later models, especially the Mini's seem more forgiving, i.e. some that i will not name, launch from their cars sunroof. I don't care what the drone model is, i learnt very quickly with my P4P, you do not launch from a car roof lol Having said that, the practise that i mentioned above, turning it on 20ft from the car and after the gimbals dance of its peoples, then it should be ok, again, still, I will never risk it again. |
