BadBert
Flight distance : 89751 ft
I have posted this in other topics about this, and i will do it here.
once upon a time, drones (diy and rtf ) had the same FC error when hitting something, mostly the ground when trying to land, but landing with some forward/backward of sidewards speed would result in the FC freaking out, and flipping the drone. Sometimes it would go haywire full throttle.
In that case, you flipped the switch on your remot to DISARM, and the drone would disarm and just "fall to the ground".
The problem there was, the sensor input to the FC would go into a value the FC could not handle due to the shock.
Later on, this bug was fixed. It also sometimes had to do with a badly tuned FC.
This bug seems the same in the avata BUT with one important difference: the avata does NOT RESPOND to any input from the RC.
There are a lot of video's showing this, avata flies away, does not respond, crashes but keeps going at it at full throttle, NOTHING stops the avata other than pulling the battery out.
this is NOT how a drone should behave, FPV or non-FPV.
That the FC goes haywire is a but that should not be there, but in that case the drone should ALWAYS "listen" to the RC inputs.... always.
Saying this is normal for a drone to do on "impact" is just nuts and makes me think that person has no experience with drones whatsoever. |
