Burt37
Sean-bumble-bee Posted at 12-12 05:05
Correct me if I am wrong but didn't the opening posts around this "120m hard ceiling" thing refer to it appearing AFTER a FIRMWARE update, not an APP update.
If an affected person also has a Mavic Mini or mini 2 on old firmware it would, I think, be easy enough to check.
If it is a Mini 3 Pro firmware thing then, with the same app, I think they would find that the earlier drone would display a maximum possible height of 500m despite an affected Mini 3 Pro allowing only 120m.
I had a quick look back, and I think that I could be right.
The limitation of the 120 metre came in with the Fly app update 1.10.4 and then adjusted with the 1.10.6..
Bottom line is the limitation for the 120 metre has already being installed in most radios, and it will be triggered in January... |
