fgange57
Flight distance : 451175 ft
Norway
DJI Susan Posted at 7-8 18:26
You're welcome. We appreciate your feedback and completely understand your perspective. It's fantastic to hear you're not experiencing any issues with your drone. If you have any further questions or concerns, please do not hesitate to contact our support team.
Hi,
I just wanted to give you an update. first of all, I finally found the screen shot you asked for (enclosed).
Furthermore, I tested yesterday what will happen if the drone is closer that 5 meter from the perceived Home Point. It the totally disregards the precision landing and go straight down from where it is. Looking at the logs, the misses now makes sense, but the note in the manual saying that the drone will descend if closer that 5 meter to the home point could probably have been clarified with the fact that the precision landing then not is in effect and that you should be especially attentive if you are required to abort the landing (which I am anyway). :-)
This definition says 5 meter. In the first flight, the floght record says 1,8ft (3,3m) from the home point when Auto landing is registered. The second flight says 0,1ft (3cm). None of these were accurate compared to where the drone was at the time of initiating Return to home, but still within what to expect from a GPS point of view. The reason for precision landing was therefore du to the drones perceived distance to the Home point, so this is a point worth taken. The 5 meters cannot be taken at direct value. You have to consider at least as much as perhaps 5 meters more considering what the GPS conditions may be.
I have for many years been tracking myself during orienteering and it is there easy to see that the GPS can even miss with as much as 10 meters if the conditions are a bit poor (in dense forest).
I am happy anyway, because this learned me that in the right conditions, the drone is very good in readjusting when coming closer to the Home point. I had a screen recording where i can see the "Shadow" is about a meter off, and when coming closer, the drone adjusts and lands on the landing pad. The other lesson is that when you initiate Return to Home and is within a short distance of the Home point, you cannon epect precision landing.
