New Firmware v1.4.0.70 for Inspire 1 Pro
123Next >
9924 92 2016-3-7
mikael
Flight distance : 24199 ft
Sweden
R&L Aerial  Posted at 2016-3-9 13:40
I'm sorry, misunderstanding on my part. You don't need to change a thing, the x3 will work even be ...
Thank you. Just what I wanted to hear.
2016-3-9
mikael
Sweden
nilsblix@gmail. Posted at 2016-3-9 19:50
YOU CAN SWITCH cameras without doing anything else.
Thank you for helping.
Mikael
2016-3-9
mikael
Sweden
DJI-Ken Posted at 2016-3-9 17:50
If you have the Inspire 1 case, you will need to do some cutting to get the X5 adapter plate to fit ...
I do have an OSMO as well. But Is there any way to get that camera to work? Its black so the color would match my Black edition I1P perfectly. If not I'll just buy a new one.
2016-3-9
DJI-Ken
Flight distance : 1515312 ft
mikael@ohlen.nu Posted at 2016-3-10 03:31
I do have an OSMO as well. But Is there any way to get that camera to work? Its black so the color ...
If your talking about the X5 on the Osmo, they're working on it.
2016-3-9
nilsblix
Flight distance : 23047543 ft
No you can not use your Osmo black X3 on the Inspire.
2016-3-9
DJI-Ken
nilsblix@gmail. Posted at 2016-3-10 05:05
Sorry, I thought he was talking about using the X5 on the Osmo.
But you are correct, you cannot use the Osmo Camera on the Inspire.
2016-3-9
Mike-the-cat
Flight distance : 22488593 ft
gybo102 Posted at 2016-3-9 20:08
Please dont take it personally, I do not mean anything by it. I said that based off of what DJI-Ke ...
OK - we're good. We all want to see a better product. Lets collectively push to this end
I think that overall this FW update is a good one.
2016-3-9
Stephen Marley
Mike-the-cat Posted at 2016-3-10 10:27
I thin ...
Just took my inspire pro for a fly, new FW seems good. Everything worked fine
2016-3-9
skyeyemedia.gma
Flight distance : 3042671 ft
Worse day ever. For anyone who still uses v1.0.0.30 and is serious about image quality... do NOT upgrade. I misread thinking I could go back to firmware .30, now I am stuck using .70...
Does anyone have any tricks to possibly get back to .30? I thought I could go V1.04.00.70 to V1.03.00.60 then to V1.00.00.30, but I get stuck at V1.03.00.60
Image quality of .30 is still superior to .70. The only benefit I see is the manual white balance is much better. Otherwise, the image is much nosier (all isos), more artifacting and MUCH less detail than 4k Cinelike D +2 sharpening in .30 (which is the most common setup we flew)
.70 Notes:
-Flickering has been improved. Although iso 400+ is so mushy I can't see myself ever giving it to a client. They have applied WAY to much noise reduction and the image has no detail. I would rather have more noise than this mushy mess.
-sharpness is the same now for normal, cinelike-d and dlog. At 0, the sharpness is almost perfect, except compared to .30 it still looks like crap because of artifacting and lack of detail.
-D-log is complete garbage and is un-recoverable in a grade.
-Still has the same issue as .40, .50 where at higher isos on the 12mm lens parts of the screen are smeared, for me its usually the whole left side of the image.
-Haven't tried 1080p60 as I am too sad I can't downgrade
Ken... do you have any suggestions how to go back to .30? We now have a $6000 paperweight, that is going to jeopardize a $40,000 project in the next few weeks!!!
2016-3-9
mark
Flight distance : 31705322 ft
skyeyemedia.gma Posted at 2016-3-9 18:58
Worse day ever. For anyone who still uses v1.0.0.30 and is serious about image quality... do NOT upg ...
SAME ISSUE HERE, Ken can I move back to .30  ??
2016-3-9
Davik
Costa Rica
Just upgraded to v1.4.0.70. update was successful, but have problem with gimbal yaw reset. Only horizontal gimbal alignment is reset, vertical is kept the same. So in case camera was looking up or down it is still looking same vertical direction after reset. Posted detailed description in separate post http://forum.dji.com/forum.php?mod=viewthread&tid=44884
Does anybody experiencing same problems?
2016-3-9
gybo102
Flight distance : 2426230 ft
Davik Posted at 2016-3-9 21:12
Just upgraded to v1.4.0.70. update was successful, but have problem with gimbal yaw reset. Only hori ...
For me, gimbal reset never did anything with vertical... only horizontal (x3 or x5)
2016-3-9
Aeromirage
Flight distance : 1778045 ft
I did the upgrade and have had a terrible time with it. I was reminded today when flying, a message came up saying my camera needed updating. So, on my return home I began. I have been at it for hours and now have questionable results.
First step: I downloaded the new firmware [v1.4.0.70] and put the card in the bird.
Ran it for 1/2 hour 'updating' then shut it down and put the card in my computer to check result file.
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
Second step: I downloaded old firmware [v1.3.0.60] and added it to the card. After running that, I got this:
Packet: WM610_FC550_FW_V01.04.00.70.bin, WM610_FC550_FW_V01.03.00.60.bin
Result: Forbidden.
Multiple version firmware bin files are detected. Please delete the redundant bin file.
Third step: I removed the new, leaving the old. After running that, I got this:
Result: Packet: WM610_FC550_FW_V01.03.00.60.bin
Upgrading ...
Result: Success.
Fourth step: I removed the old, and pasted the new. After running that, I got this:
Upgrading ...
Result: Success.
So, Yeah!! I thought. After rebooting the craft, I get a prompt that "Reformatting is suggested" This appears just to the left of the AE lock/AF/MF icons, where the camera settings normally are. Also, a note came and went that said that the camera could not detect lens. So, I shut it down and removed / replaced the lens, re-started and now it will focus and allow camera setting changes, but the Reformatting suggestion is still there.
What does this mean and how is it done??
2016-3-9
Aeromirage
So, after more research, it's got to be the SD card that needs re-formatting. I have had the app ask me plenty of times if I want to format the card, but never have I seen this message or in this place.
Is this change a result of the firmware upgrade?
I did a slow reformat with my computer and will find out tomorrow if that was what was needed.
2016-3-9
mikael
Sweden
nilsblix@gmail. Posted at 2016-3-9 22:05
Ok. Then i know. Thanks.
2016-3-9
fly8086
Flight distance : 601207 ft
Philippines
I've installed 1.4.0.70 but my olympus 12mm cannot use autofocus feature.
When I tab screen to focus  (in AF mode), it says "MF mode, auto focus disabled".
1) how can I resolve focus disability?
2) if I want to rollback to 1.3.0.60, how can I perform the rollback?
**updated**
After reboot and the message was gone.
2016-3-11
knarfboy
Flight distance : 494508 ft
fly8086 Posted at 2016-3-11 19:50
When I tab screen to focus ...
Install the Olympus on a Panasonic GH3 or GH4 an update the Firmware for the Olympus to v1.1
The Firmware update file you can found on the Olympus Support Homepage.
2016-3-11
Mike-the-cat
Singapore
Aeromirage Posted at 2016-3-10 11:49
I did the upgrade and have had a terrible time with it. I was reminded today when flying, a message  ...
Beyond checking the SD card, ask yourself if after the FW update the lights on the gimbal go off (previously blinking red and green) and the beeping sounds stop. If so, the update was successful. The .txt message does not say 'success' unless the aircraft is rebooted, shut down and the card removed.
You can also verify success of a FW update by looking the 'About' tab on the Go App.
Although the documentation says that the changes are in the X5, I've discovered (have two Inspires), that the aircraft also updates something. If you do not put a X5 with the FW update .bin in all your 'Pro' aircraft, you will see a 'Disconnected' error message on startup.
2016-3-11
domidragon90
Switzerland
I have some stupid noise. Like in the .40 firmware
https://drive.google.com/file/d/ ... Ws/view?usp=sharing
Please download to see it!
ISO100, F5.6, S1/50, 4k25p
Anyone else does have it?
2016-3-12
njabinc
Mike-the-cat Posted at 2016-3-12 02:56
Beyond checking the SD card, ask yourself if after the FW update the lights on the gimbal go off ( ...
With all due respect Mike it is obvious you have well and truly drank the DJI Koolaide but it's satisfying every now and then when you affirm exactly what others clearly see and articulate. DJI never tells the purchasers who spent handsomely for the privileged to pine for their due everything that their firmware updates contain. Hence the extreme distrust you now rail against daily. I should add, so your fur isn't rubbed backward, that it is as much your right to blindly believe all that DJI professes as it is mine to heavily distrust as they reap what they sow.
2016-3-12
skyeyemedia.gma
domidragon90 Posted at 2016-3-12 12:14
https://drive.google.com/file/d/ ... Ws/view?u ...
You have noise?
.70 is a disaster... and of course you can't downgrade. I am getting more noise at ISO 100 on V.70 than I was getting at ISO 800 on V.30.  CineD and DLog are also completely unusable.
2016-3-12
Davik
Costa Rica
gybo102 Posted at 2016-3-9 21:38
Really?
Quite strange, cause even in OSMO, when you double-push main button on the handle, camera is centered, by meaning X an Y axis.
2016-3-12
Linolens
Flight distance : 501250 ft
Macao
knarfboy Posted at 2016-3-12 10:18
The  ...
what if I don't have a GH3 or GH4?
2016-3-13
Mike-the-cat
New Zealand
njabinc Posted at 2016-3-13 01:27
With all due respect Mike it is obvious you have well and truly drank the DJI Koolaide but it's sa ...
'Trust but verify"
2016-3-13
skyvideoct
Flight distance : 1136230 ft
I downloaded and started the install for the wrong firmware on Friday. I have an upgraded Inspire 1 w/ X5 camera and had a "not so bright" moment. Anyway, it started to upgrade and stopped with a faceplant since I had the X5 mounted. Wouldn't go any further, so I tried to undo and go back one step with the latest X5 firmware version. No go, so I mounter the X3 camera nd all was fine.
Trouble is, I have to wait for the next X5 firmware to overwrite the partial, I guess in order to fly the X5 configuration.
2016-3-14
skyvideoct
fly8086 Posted at 2016-3-11 14:50
Note: The Oly 12 has the manual sliding ring that is either slid out or in. When slid back, it is manual mode only
2016-3-14
dir
Flight distance : 909 ft
how long it takes to install the new firmware?
2016-3-14
germac9
Flight distance : 1797297 ft
I updated with this firmware revision and when I check on the DJI GO app the Camera Version indicates Version 1.4.0.70.
However the Aircraft version shows 1.4.00.10+ and from what searching I cant determine if the aircraft revision is correct.
Can anyone advise?
Thanks
2016-3-17
richardhurst
Banned
Flight distance : 2342808 ft
2016-3-21
domidragon90
Switzerland
Ahh, the noise is only with ISO100!
If you choose ISO200 eveything is fine! (not perfect, but good)
ISO100 seems to be still buggy
2016-3-21
richardhurst
Banned
2016-3-21
adrian
Flight distance : 1751102 ft
New Pro arrived yesterday, needed an upgrade, fine. Upgraded, success noted in text file on card. As I have another Inspire 1 my App is already on 2.7.1, so how come DJI says App should be 2.6.0?? Also, although text file says upgrade successful, it stills aircraft upgrade required even thought it says I'm on 1.6.00.40, confused??
2016-3-22
adrian
All sorted, Heliguy says delete App and reinstall, did the trick.
2016-3-22
MichaelRoth
Flight distance : 288297 ft
Switzerland
DJI-Ken Posted at 2016-3-9 20:35
its working on it? i just tried and it wont fit ? any ideas?
2016-3-22
MichaelRoth
Switzerland
adrian@vancols. Posted at 2016-3-22 19:00
not worked for me, i still have 1.6.00.40 .... uninstalled the app, trying to install new firmware => abort (latest firmware is on) but it shows me the old firmware???
2016-3-22
MichaelRoth
Switzerland
i just downgraded to v1.3.0.60
and then again upgraded to v1.4.0.70
Aircraft Version: 1.6.00.40
this is driving me crazy ...
2016-3-22
DJI-Ken
adrian@vancols. Posted at 2016-3-22 16:53
New Pro arrived yesterday, needed an upgrade, fine. Upgraded, success noted in text file on card. As ...
The aircraft saying it still needs an update was a server issue and has been resolved.
2016-3-22
DJI-Ken
MichaelRoth Posted at 2016-3-23 07:02
The X5 will fit fit on the Osmo without the X5/Osmo adapter that will be available at a future date.
2016-3-22
DJI-Ken
MichaelRoth Posted at 2016-3-23 07:19
not worked for me, i still have 1.6.00.40 .... uninstalled the app, trying to install new firmware ...
The 1.7 Inspire update was only for the camera, so the camera will say 1.7 and the aircraft will say 1.6.
For an X5, the camera will say 1.4 and the aircraft 1.6It's also explained in the 1.7 release notes.
http://dl.djicdn.com/downloads/i ... _Note_en_160317.pdf
2016-3-22
dobmatt
Flight distance : 1831050 ft
DJI-Ken Posted at 2016-3-23 08:59
The 1.7 Inspire update was only for the camera, so the camera will say 1.7 and the aircraft will sa ...
Ken, the Inspire 1 Pro Release Notes (2016.03.07) says DJI Go iOS should be upgraded to v2.6.0. Is it just the typo since v2.7.1 is available? It installed on my iPad Air 2 automatically ...
2016-3-23
123Next >
