Join the DJI Mavic Beta Project
123Next >
23275 115 2016-10-8
Pawan.jain.ca
Hello, I am getting stuck in product profile page. It doesnt move to the next page after I click the Save button.
2016-10-11
zach5150
Flight distance : 225148 ft
I've registered as a beta tester and my application is being reviewed. I ordered the Mavic Pro on Oct 6th so I have no idea when it'll arrive.
2016-10-11
Fulgerite
DJI-Autumn Posted at 2016-10-11 03:16
Hi sir, the status means that your application is under certificating. After approving it will cha ...
My status shows as "certificating" as well.
2016-10-11
ahr69
Flight distance : 83612 ft
Fulgerite Posted at 2016-10-12 05:08
I don't mean to be disrespectful but "certificating" ...
Great catch!!! You could be the Beta moderator. Got my vote.
2016-10-11
KLRico
Flight distance : 428448 ft
Fulgerite Posted at 2016-10-11 14:08
"Certificating" is indeed a word. Not a very common one, but still a real word.
2016-10-11
DJI-Autumn
My fault! Just realized the inconstency between main page and recruitment page regards this word.. Will count you in
2016-10-11
suttonr
Flight distance : 300302 ft
Anyone know if the places have all been filled of if they are still in the review process ?
2016-10-12
babblin5
Flight distance : 1558 ft
rick39 Posted at 2016-10-9 01:50
This seems to imply that the shipping date given of mid October isn't going to happen. The 14th Octo ...
Not true. It's for software and firmware revisions.
2016-10-12
zach5150
FYI to the Beta team:
I updated a couple of things on my profile, including 'extra detail you should know'. Also, there are 2 fields that do not seem to update properly. One is 'years of multi rotor experience' (less than 1), and years of photography experience (more than 3). When i select an answer in the drop down and click 'save', the selection clears and it appears I did not answer. I'm using an iMac with MacOS 10 Sierra and Safari v10.0.
2016-10-12
suttonr
zach5150 Posted at 2016-10-12 15:47
I updated a couple of things on my profile, including 'extra detail you shoul ...
same for me on windows I just left it in the end ?
2016-10-12
T_A_Rogers
Flight distance : 68537 ft
I also applied for beta. I'm hoping the DJI Go UI gets a new prompt to inform the pilot about "tap to focus" functionality.. Otherwise YouTube will be flooded with more people complaining about soft focus without having read the manual (which will almost certainly explain the feature in great detail).
2016-10-12
DJI-Ken
DJI Team
Flight distance : 1515312 ft
T_A_Rogers Posted at 2016-10-13 02:31
I also applied for beta. I'm hoping the DJI Go UI gets a new prompt to inform the pilot about "tap t ...
Who knows if the tap-to-focus will change. I played with it for a while today and indeed you need to tap to focus each time. There is a center auto focus that you can map to C1 or C2 but it's a one time auto focus and you need to press the button each time you want to refocus on a object if the distance has changed very much.
2016-10-12
thehippoz
Flight distance : 23 ft
Thinking stick a qfn microcontroller/volt divider and button to control a pseudo autofocus (maybe focus once every 1-3 seconds or so). Seems easy enough if it doesn't blur the footage while focusing.
I want to stick a cree led on the bottom of the drone too, with a small buck to power off the battery. If they had a way to assign aux you could control it too, morse code, strobe, beacon.
2016-10-12
suttonr
thehippoz Posted at 2016-10-13 06:34
Thinking stick a qfn microcontroller/volt divider and button to control a pseudo autofocus (maybe fo ...
If you can tap to focus there has got to be a software update that can put it to continuous focus on the centre. Same issue with the inspire. Got to love the Cree led's
2016-10-13
sbug206
Flight distance : 517848 ft
DJI-Ken Posted at 2016-10-12 22:55
Who knows if the tap-to-focus will change. I played with it for a while today and indeed you need  ...
I would hope it maintains focus in Active Track. Kinda useless to track a subject but not also focus at the same time.
2016-10-13
DJI-Ken
DJI Team
sbug206 Posted at 2016-10-13 21:07
I would hope it maintains focus in Active Track. Kinda useless to track a subject but not also foc ...
I'm sure it will since the aircraft follows the subject at the same distance. Now if you change the position closer/further during Active Track I'm not sure.
2016-10-13
johnlega
This has been asked but it may warrant re-asking since it was not answered. Is there an extended warranty (coverage) if we test out new firmware and as a result it crashes or keeps going? I'm not a pessimist, but since it is BETA software - anything can happen.
Thank you,
John
2016-10-13
Se7en
Flight distance : 4934 ft
Singapore
Looking forward to the beta test. Any 'hints' on what features are rolling out?
2016-10-13
T_A_Rogers
Se7en Posted at 2016-10-13 23:34
I wouldn't expect any new features this early on. They probably want people for UAT (user acceptance testing) to confirm new patches won't totally crash the Mavic, won't cause strange behavior in the GO app, won't cause connectivity issues, etc. While DJI has surely done plenty of field testing, it always helps to get feedback from the masses once this goes out in the wild.
2016-10-13
Se7en
Singapore
T_A_Rogers Posted at 2016-10-13 23:57
I wouldn't expect any new features this early on. They probably want people for UAT (user acceptan ...
Sounds plausible. Hahaha! i was just trying my luck. =p
I am kinda of excited about testing the drone. (^.^)  I feel this initiative from DJI is pretty awesome. Hopefully, we can get some juicy insights when the beta rolls out. Cheers.
2016-10-13
EpicLPer
Flight distance : 80272 ft
Austria
Just signed up for the beta! Let's hope it won't crash due to a bug haha ;)
2016-10-13
EpicLPer
Austria
Pawan.jain.ca@g Posted at 2016-10-11 15:28
Hello, I am getting stuck in product profile page. It doesnt move to the next page after I click the ...
No, that's normal. I was wondering what was going on too, but that's just there to set your profile up. You'll have to click on the DJI Logo on the top left then and click the Mavic Beta Program button below it to sign up then.
2016-10-13
EpicLPer
Austria
Se7en Posted at 2016-10-13 18:04
I am kinda of excited about testing the  ...
Same here, the Mavic seems like the ultimative drone for hobbyists and even "somewhat professionals"!
The features it includes already from the launch are awesome and something I wanted for a long time already, sad that they don't include a USB C cable in the package tho and you'd have to buy it extra
2016-10-14
Travis199
Flight distance : 144039 ft
I thought recruitment for this closed on the 14th? have they extended it?
2016-10-14
CaptumLux
Looks like they have extended recruitment to the 16th. My guess would be due to shipping/production delays? Can't really beta test without the hardware.
2016-10-14
zach5150
It could also have been extended simply because there weren't 100 users recruited yet.
2016-10-14
mdecker84
zach5150 Posted at 2016-10-14 12:29
Or they want add more users. A bigger sample space means more feedback
2016-10-14
jebrilhelawi
Banned
2016-10-14
thehippoz
suttonr Posted at 2016-10-13 16:36
If you can tap to focus there has got to be a software update that can put it to continuous focus  ...
Yeah thinking maybe even do a MT-G2. I designed a small buck that would be perfect for this. Night flight too.
2016-10-14
70challenger
EpicLPer Posted at 2016-10-14 00:55
There is two types of possible crashes being a beta tester - software crash & drone crash!
2016-10-14
bill.mcgraw
Completed the process with a DJI Mavic on order, with "onorder" in the serial spot.
It would be nice if someone could post a step by step process to change the serial number
Also one to let me "add" devices to my settings.
Don't see my name and avatar changes?
2016-10-14
2000vadasz2
rick39 Posted at 2016-10-9 16:50
We never know what might be the shipment problem. But I have a feeling Dji is rushing to get the Dji goggles out as soon as possible.
2016-10-14
Oldrider
2000vadasz2 Posted at 2016-10-14 21:16
We never know what might be the shipment problem. But I have a feeling Dji is rushing to get the D ...
Asked about the goggles as a "package", email says, not until the news release. I am hoping to get the DJI goggles also, I only have a mini droid as a visual, unless I use my cheap RCA 10", both are terrible in direct sunlight.
2016-10-14
ftVWqOC7qJzf
China
  Charging this matter may seem insignificant, but our daily work and life are dealing with it, and there are many stress areas. As long as a small investment in the charging device, you can get a very significant gains.
   Power Bank  QQPOW Ultrathin Power Bank 8000mAh
  My small partner and I bought a variety of mobile power, and finally reached the same conclusion: Do not blindly pursue large-capacity power bank, in most cases you just need to look at the emergency.
  We recommend QQPOW's new Ultrathin Power Bank 8000mAh capacity to the iPhone charge twice without any problems. More importantly, 230g weight and credit card size of the volume on the bag will not be any burden.
  The power bank supply is not only beautiful and a variety of options, but also universal power bnak, to support a variety of smart phones. It can well balance the relationship between capacity and volume.
    Ultrathin Power Bank  Output 5V / 1A / 2.1A, it is still equipped with PowerIQ technology, can automatically match the best output scheme. Measured with the QQPOW iPhone 7 charge current to 1.7A or so, faster than the original charger.
  If you have no special requirements for power bank, this Ultrathin Power Bank "portable small steel gun" is absolutely sufficient. It is currently very affordable price, like a friend welcome to  nquiry. http://www.qqpowerbank.com/li-po ... in-power-bank-.html
2016-10-15
Oldrider
thehippoz Posted at 2016-10-14 17:54
Yeah thinking maybe even do a MT-G2. I designed a small buck that would be perfect for this. Night ...
Light weight single or dual bulb, couple of 2025's to power it...
2016-10-15
petter.jens1
Norway
I'm down!
2016-10-15
Eldonbkh
Im also registered, now lets get my Mavic! lol.
2016-10-15
eric.vezina
rick39 Posted at 2016-10-9 04:50
Actually, if you look at the trial period it goes from Oct 16 to Oct 23rd. Hopefully they are planning to send the drone on time for testing on those dates!
2016-10-16
Eldonbkh
1. Has anyone got past the Certification stage?
2. Will the quote be adjusted soon?
Or will both change upon Receiving your Mavic and entering your SN?
2016-10-16
Guntert
Flight distance : 766260 ft
ftVWqOC7qJzf Posted at 2016-10-15 17:49
  Charging this matter may seem insignificant, but our daily work and life are dealing with it, an ...
tried to order one but there is now buy or anything
2016-10-16
123Next >
